Initial (24H) Listening Impressions*/First-Day Summary
Despite my early reservations about minimum-phase, slow roll-off, filters, I really rather like the DragonFly Cobalt. And it is definitely the best sounding of the current DragonFly trio.
It is a clear, across-the-board, upgrade from the Black (and with significantly better drive capability/power), and a qualitative upgrade over the Red**.
The only other similarly sized, similarly capable, DAC/amp I can even think of, that will actually work properly from an iOS device, as well as the other major mobile and desktop platforms, is the NextDrive Spectra X (you would trade MQA for DSD there). The rest of the “competition” is either 4x the size (or more) and won’t run off most phones anyway due to high power-draw, or doesn’t measure up on the sound front.
At a high level, the Cobalt is more resolving than it’s siblings and, indeed, the Meridian Explorer 2 (the only other MQA-capable DAC/amp in this form-factor … and even that is 5x the size of the Cobalt). Detail is excellent, timbre natural, and the overall rendering is more vivid than its predecessors.
The early high-frequency roll-off makes for a signature that is easier to listen to without encountering fatigue issues. In fact, so far, I haven’t had any fatigue with the Cobalt. This does rob the thing of some sense of air and space, and music with an otherwise highly vivid projection of the space/acoustic of the venue suffers some (Cowboy Junkies’ “Mining for Gold”, “The Trinity Session” is a good example). And it can rob some pieces of their sparkle. Not all, just some.
A more specific breakdown/narrative in terms of “bass, mids, treble, dynamics, transients etc.” will come after more listening.
If you don’t need the extreme portability, broad platform compatibility and drive capability, then there are cheaper ways to get better sound, more options/configurability/flexibility, and better drive capability.
For example, the iFi Audio Nano iDSD Black Label has broader capabilities, including DSD support, can also render MQA, has an internal battery, lots more power, S-Balanced output, and is $100 cheaper … but this comes at the cost of it being 12x bigger than the DragonFly Cobalt.
A Modi 3/Magni 3, SDAC/Atom or Topping DX3 Pro would also give you much more flexibility and better sound. But you can’t run those combinations off a USB port nor run them from your pocket.
That does put a big of a question mark in the “value” category. Quality in miniature, in any endeavor, tends to cost more than the same thing in larger packages, but the actual value proposition here is going to be quite personal.
For something I can run off my laptop, my tablet or my phone, without extra power, and drive everything from IEMs to non-pathologically-demanding full-size cans, in an enjoyable and engaging fashion, there’s not really much I can name as serious competition.
*More detailed impressions/descriptions will follow when I get time to listen more and write things up properly; for now I am shooting for the “highlights”.
**Caveats here are simply that if you have tonally darker-tilted headphones or significant age-related high-frequency hearing loss, the Red might be a better bet.
