SOLD: Dan Clark Audio Aeon Open X $399
Price: $399
Currency: USD
Ships to US, and Canada
Where to buy https://reverb.com/item/32805083-dan-clark-audio-aeon-open-x
Based on the Aeon Flow Open from Dan Clark Audio (formerly MrSpeakers). With a naturally appealing sound that’s both warm and punchy, plus excellent power response and ultra-comfortable fit, the Aeon Flow Open is close to perfect—close. To get it even closer, Drop worked with Dan Clark Audio to create the Aeon Open X. Featuring partially fenestrated earpads and reduced driver dampening, these Drop-exclusive headphones deliver a widened soundstage with the same punch and detail as the original.
SPECS
  • Drop + Dan Clark Audio
  • Open-back headphones
  • Individually serialized
  • Drivers: V-Planar planar magnetic, matched +/- 1.5 dB 30 Hz–5 kHz
  • Efficiency: 94dB/mW
  • Impedance: 13 ohms
  • Headband material: NiTinol memory metal
  • Earcup material: Plastic frame, genuine carbon fiber inserts
  • Earpad material: Japanese protein leather (removable)
  • Input connector: Hirose 4-pin
  • Cable: DUMMER 4-pin (3.5 mm) to ¼ in (6.35 mm) , 6’5" (2 m) long
  • Weight (without cable): 11.5 oz (326 g)
  • Made in San Diego, CA
This headphone was SOLD
