Do DACs/Amps matter?
That’s hilarious!
You mean correlation does not imply causation? :laughing:
The problem with the way blind tests get thrown around in audio is significantly worse than that, whether or not you have a statistically relevant result is only one part of the issue.
The tendency even when it’s done right is to draw broad conclusions from very narrow tests.
lets say on two DAC’s a single person does 100 random A/B tests of 5s duration each, and you get no statistically significant variation.
All that implies is one person can’t tell the difference between the 2 tested DAC’s inside 5s. It says nothing about the broader population, or any other DAC’s or tests anything you might detect after more than 5s.
There are a lot of examples in the medical field (where blind testing is done very carefully) where drugs considered to be a failure in initial tests, were later found to be very effective on narrowed groups of the population.
Yeah, but even though I’m not in Maine, that chart proves it’s better to butter up the spouse.
maybe we can stick to audio examples. I’ve been a Dr involved in research, and imho what you note is rare at best, after YEARS of research…
Not a comparable research case.
I’m a firm believer in crap in…crap out.
Indeed. It all starts with the recording, and unfortunately there’s no recording standard that the studios abide by, so…
The source and the amp are both important. Digital has come a long way over the years. Headphones really bring out any shortfalls in the playback chain. For me, the Benchmark DAC was my introduction regarding what improvements could be had by DAC’S.
Once I heard Chord DAC’s, that became my new reference. Once I heard the M-Scaler/Hugo-TT2 combination, that was it. The Headphones finally started to sound right.
Amps also are important, but would give the nod to the source/DAC. The amp may also not be a good match for a given headphone. Some amps may have enough power, but can make a given headphone sound bad. I’ve run into this issue.
The budget split is never straightforward as it depends intrinsically on the difficulty of making a “good” version of the device in the first place. There is an entry cost to any device and then an escalation ramp which may be steep and then roll off as performance gains become more difficult. It may have lumps and bumps as one step may involve substantial cost whereas the next step may be much less. For example a crossover component at a few $ may not give any noticeable gain with the existing mid unit but after spending $ hundreds on a new drive unit that same improved inductor could give massive benefits.
On measurements, all measurements are numerical or graphical models to represent the signal we are analysing. They look at certain factors and apply a model to represent the outcome. They are never a true representation of our ear-brain process and therefore can never accurately represent the difference we may hear. The brain does not process the whole signal literally it changes as we focus on particular patterns or signatures. It is why we can pick out a conversation in a crowd. The listening experience depends on our state of mind (mood) and on our focus, both the ear and the brain are active filter systems. Just ask anyone how they feel in a true anechoic chamber it is very peculiar when noise is removed. All these factors add to the reason why even if we did reproduce the exact sound we heard at a live concert, we still would not hear it the same. We could not match the state of the bodies biochemistry and the input from our other senses, all of which alter what we are hearing.
Personally, I think that each component in the chain can make a difference in the overall sound, and it’s important to find a balance between all of them.
While a clean measuring source is important to reduce distortion, it’s also worth considering the tonality and character of the source. Some sources may sound better with certain transducers than others, and vice versa. It’s also worth considering the quality of the DAC/amp, as a poorly designed or low-quality unit can introduce its own distortion or coloration to the sound.
Of course, the transducer is ultimately the most important part of the chain, as it’s what directly produces the sound. But I think it’s worth investing in a high-quality source and DAC/amp to ensure that the transducer is receiving a clean and accurate signal.
Well, I think they certainly do matter but the laws of diminishing returns apply. I am considering upgrading to an endgame set up, but likely the differences are at the law of diminishing returns.
My question to the Headphones.Com review staff, and I mean this in a friendly way, is if amplifiers and DACS really don’t matter, why do some of you own $3,000 plus DACs and amps?
I’d be perfectly happy with a dongle for most of my headphones. But to do my job I need to be able to test the edge cases as well, and the equipment I use allows me to do that.
I have the Violectric 280. I’d be curious to your impressions of the 550? I’m hoping to get a listen at CanJam NY in March.
It has lots of power, low OI and low noise. That’s really all I have to say about it. It doesn’t ‘have a sound’ in any meaningful way so there aren’t any impressions to give really. I like the knob.
Thanks! My 280 is warm and almost tube-like. It’s enjoyable quite forgiving with a lot of the rock and metal enjoy, but lacks some impact to my ears. It has a somewhat laid back nature. The treble feels slightly rolled off compared to my GSX-Mini. I’ve thought of upgrading at some point and I’ve thought about the 550. Some say it’s more neutral and “refined” and I like a certain amount of grunt and slam. I would imagine it’s highly resolving.
I don’t know enough about the 280 - for all I know it could genuinely be causing that effect - but I gotta be honest, I have a hard time with descriptions like that of solid state source equipment because the vast majority of the time it’s either down to the suggestibility of the person giving the report, or it’s some sort of output impedance thing. When you control for those factors people can’t really tell one from another.
With that said, Lake People have made source equipment in the past that has deliberately ‘conserved’ low order harmonic distortion to create a tube-like effect - or at least they claimed it was intentional. So I wouldn’t be surprised to learn of something like this here as well. I just typically associated that with their Nimbus line.
  1. Unclear what is “the cleanest measuring source”. I guess the most common answer is SINAD, and no, I don’t think that’s the right measuring parameter. If we use something much better like df-metric, then yes.
  2. No. I think you can get perfectly reproducing DAC/amp for as little as €50 so no need to allocate percentages. So, no.
  3. They matter. As much? If we compare pricewise, not as much. So, no.
I would say, “group 1” with the added caveats.
The car/tire analogy only stretches so far—source gear can genuinely change what the transducer receives, not just how well it’s gripped. That said, the 50/50 split seems reasonable as a starting point, though it depends on how revealing the headphones are. Your point about live shows is the part I keep coming back to: the volume and channel balance at most venues I’ve been to is all over the place, which makes chasing some idealized live sound tricky. Maybe the realistic target isn’t duplication but a chain that doesn’t add its own color.
