I possibly just missed it but I can’t find a way to “unhide” an output. I accidentally clicked on “hide” from the dropdown. I uninstalled/reinstalled to clear the settings and that works of course, but a bit dramatic. Maybe just a “restore hidden audio devices” button in settings or something similar?
In settings toward the bottom there is a “hidden devices” option and you can restore them from there. In the newest update I’ve also added a “show hidden devices” option to the bottom of the output selector dropdown so it’s easier to find too
Ahh, found it. Thanks!
GraphWorks has been fantastic on macOS in my experience, and has seriously expedited and leveled up my EQ process (was able to finally correct my AirPods Max and Azurys via tone gen with the help of the visual aid from from yalls FR database). Loving it, so thank y’all!
I saw it mentioned on another thread, but implementing a LosslessSwitch type function for Apple Music on macOS would be killer and something a lot of folks would appreciate.
Also, just found out that iOS 27 finally allows for system-wide EQ. PragmaticAudio developed a killer app and recently dropped it (PragmaticAudio PEQ). Has been a game changer. Would you guys be able to implement an iOS version of GraphWorks at some point?
One more, would be great to pin imported FR graphs to their respective EQ profiles
The losslessswitcher functionality is planned, hopefully won’t be too long!
An IOS version would be great, though atm I have no IOS devices so would need to sort that and take a deeper look into it
I echo the request for a lossless switcher feature that works with Apple Music please. That’s the only thing lacking that’s holding me back from switching to Graphworks.
iOS functionality would be a godsend too but I think you have your work cut out for you there.
Feature request: per-channel EQ, per-channel delay, and REW import (speaker use case)
Hi team,
I’ve been using GraphWorks EQ with my headphones, and I love it, especially upsampling. I’d like to move to it fully, but right now I still need Equalizer APO for my speakers, and I suspect I’m not the only one running both headphones and speakers off the same PC.
My setup: PC > SMSL SU10 DAC > SMSL H400 > Nilai 500 amp > Technics SB-C700. I measure each speaker separately in REW with a UMIK-1. The Left and Right corrections end up different.
What I’d need to switch to GraphWorks completely:
Independent EQ per channel
Separate filter sets for L and R. -
Per-channel delay
A delay value per channel for time alignment when the listening position isn’t perfectly centered. -
Nice to have: import REW filter exports per channel
REW can export its generated filters as text. Being able to load one file into L and another into R would make GraphWorks EQ an easy home for room correction.
Thanks for the work you’re putting in!
Per channel EQ is already in the tool, just click the “L/Linked/R” buttons in the bottom left to choose what you want your bands to apply to.
(you can also then click the L/R icon in the band list to swap a band’s channel(s) )
The per-channel import and export is also already in
Per channel delay is something I could possibly add, though atm I’m planning more of a fully featured speaker correction pipeline at somepoint so it may come as part of that update. That’s a big one though so will probably be a little while down the line, but something I’m eager for myself!
Amazing!~ I wasn’t quite clear about that because I imported the config file, and the R/L values didn’t come across. However, making each filter one by one from scratch did the trick! As for the delay, I just moved the spaker to compensate, and I’m off to the races! Thank you for getting back to me so quickly!
Would you be able to DM me a paste of what you were trying to import? It may just be slightly different formatting in which case I can make sure it works in the next update
Please could you submit this as a bug report in the app itself? That sends us logs so it’s a lot easier to track things down when reports are sent there
The silence is due to the bitrate change FYI. If the next track is the same bitrate, there is no silence. If there is, then you get the 1 second or so silence so you miss the first few notes of the track while it “syncs” or whatever is happening. If I turn off Tidal exclusive mode, then no issues since it’s a constant 44.1.
I hope here’s fine. I don’t have DMs on my interface: maybe I’m too new of a user.
Channel: all
Preamp: -6 dB
Channel: L
Filter 1: ON PK Fc 194.0 Hz Gain -9.50 dB Q 6.039
Filter 2: ON PK Fc 287.0 Hz Gain -2.40 dB Q 5.000
Filter 3: ON PK Fc 592.0 Hz Gain -2.30 dB Q 5.000
Delay: 0.03 ms
Channel: R
Filter 1: ON PK Fc 141.5 Hz Gain -7.50 dB Q 7.334
Filter 2: ON PK Fc 289.0 Hz Gain -2.30 dB Q 5.000
Filter 3: ON PK Fc 418.0 Hz Gain -0.70 dB Q 5.000
Filter 4: ON PK Fc 577.0 Hz Gain -4.10 dB Q 5.000
Filter: ON PK Fc 1050 Hz Gain -1.5 dB Q 2.5
(Minor) Feature request:
Hello Cameron @GoldenSound, just a minor thing, but could you please add a volume key step option of 2 dB as well (in addition to the current options of 1 / 3 / 6 dB)?
I find 3 dB steps too big, and the 1 dB one unnecessarily small.
In Graphworks EQ, is there anyway I can adjust the rig data (via the existing EQ filter capability) that gets imported into the software? I want to start with rig data as a baseline, then use tone gen to perceptually adjust the measured line to match how I actually hear the headphone on my head.
That seems like a much more useful baseline to start to EQ from.
