I would agree that the directivity of the speaker is a much more important cue than that of any instruments. My main point is basically that since your idea is derived from the DI of a speaker, an “idealized” version of that might translate better because of the different possibilities of how, and frequencies at which speaker directivity can change. It might be more effective at “closing the loop”. It’s not a substitute for preference though, and from what I’ve seen, the 10dB tilt doesn’t exactly excel in preference tests. Your idea might be better.
I’m going to finally have time to play this weekend. In Peace EQ, we should be using High Shelf filter (Q as slope), correct?
I see that Listener’s squiglink also has the Average All option to compute an average from multiple FR curves. Seems to work pretty well too. Great to see that.
Still no stock 5128 DF though. That would be another useful addition imo, because I still like to use the stock DF with a slope as a coarse FR reference for sorting the best headphone responses.
What do you mean by “stock” DF? Is the DF there somehow modified?
The stock DF is HBK’s original 1/3-octave diffuse field measurement of their 5128 rig. Which is different than the 5128 DF curve that Headphones.com uses.
I believe the Headphones.com DF curve was derived from free-field measurements. And it is higher in resolution than HBK’s DF measurement. But also has less “air” in the higher frequencies above about 10 kHz. And is probably also a tad more forward in the mids.
The stock curve has limited resolution though. It’s the equivalent of a 31-band curve, which is not an issue at the lower frequencies. It is too lacking in detail though for precise compensation/equalization at the higher frequencies (particularly above 15 or 16 kHz, where there really should be more of a dip between the ear canal resonances). So it’s only useful as a coarse reference in the treble, up to about 15 or 16 kHz.
For more precision, especially in the treble/HF, I suggest using an average of several good headphones that are close to your preferred response or target.
My takeaway from Dr. Olive’s remarks is that the Harman headphone curve reflects a preference for the in-ear response of neutral speakers that are flat on axis, but also well-extended into the sub-bass frequencies or accompanied with a sub-woofer. This seems to be reflected in the design of many recent (and not so recent) Harman products based on their research and target curve, including the AKG K371 and Mark Levinson No. 5909, among others.
A couple posts on ASR that might help to shed a bit more light on this…
This does not mean everyone will prefer/like this type of response though.
I personally seem to prefer a response that peaks in the bass somewhere around the resonant frequency of a kick drum, as opposed to one which continues to rise much below that. With a good seal, the F0 (sub)bass resonance of the AKG K371 is too low in frequency and too prominent for my taste, for example. And sounds over-emphasized.
I’ve tried this method with a few headphones I own. I started with my Focal Clear and Sennheiser HD800S. Using your 5128 Squiglink I EQ’d to DF using AutoEQ from 20-10k with 4 filters and Q < 3. Then I added 1 filter HSQ -3db 0.4Q. Then I loaded these presets into EQMac and A/B compared with my existing favorite preset. My Clear preset is based on your EQ preset in the EQ request topic. I don’t think I made any changes. The HD800S preset is based on the bass filters from the EQ request topic and my own adjustment for the 6k peak.
The results were good. I mean, I can say for sure that this technique doesn’t yields a bad result to my ears. Was it better than what I compared it to? Hard to say. I listened to a variety of music from my Equipment Evaluation playlist but never really determined a clear winner. It may boil down to personal preference. My existing presets were a bit warmer, and I prefer a warmer sound within reason. I ended up increasing the HSQ to -6db. The new presets present a bit more clear, but the sense of spaciousness and imaging did not seem to be affected.
Later I used the same technique to make a preset for my Hifiman Mini Shangri-La. I then made another preset using DF with a -10db tilt and no HSQ. Comparing the two, I definitely preferred the first preset - the one without tilt. I’m going to need to A/B it against the preset I developed some time soon. Problem is I much prefer listening to music over comparing EQ presets.
I finally had the opportunity to test my HD 490 Pro extensively with this new EQ method. I must admit, the improvement in sound quality is impressive. I transitioned from only using the mixing pads to the more comfortable producer pads, as the -5 dB high shelf significantly enhances the audio experience. The mixing pads are probably still better overall, but this EQ significantly closes the gap for me.
The main difference between this and the diffuse field slope EQ that I had been using boils down to the bass. The transition from bass to mids is smoother and more coherent, which literally effects everything else above it as well. Bass lines and kick drums have proper definition but are no longer overly bloomy. I’m quite thrilled with the results here!
I’ve been meaning to try it with my Focals and other Sennheisers, but I am too distracted by how good the music now sounds with the producer pads. Sweeeeeet!
Glad to hear you and AudioTool are enjoying the experimentation!
As promised I’ve compared this new EQ method with the EQ I had previously developed for my Hifiman Mini Shangri-La. The result is that it has replaced the EQ I developed. It sounds more open and clear without being dry, really emphasizing the strengths of the MSL.
After some time with it, I did disable a PK -3db 3600hz 1.3Q filter just because I like the extra impact in drum hits this creates. I’m currently playing with a LS +3db 120hz filter for a bit more bass impact.
Also something odd happened. I found a Gras 43AG measurement of the MSL and used the same method to create a new EQ, but I did not like the results very much. I’m not sure why this would be unless the Gras is not be a good match to my ear in general. Maybe the Squiglink measurement or DF target were inaccurate to begin with.
Next step is trying it on my Meze Empyrean II, but it might be awhile as I am quite happy with the EQ I am already using.
Just seen this thread, but I did not understand everything, because english is not my natural language. But I would be interested in your EQ that you will create for the Meze Empyrean II, maybe you can share it with me, so I can A/B it with my existing EQ. That would be a great pleasure for me.
Which pads are you using with your Empyrean 2?
I use the hybrid pads.
This new method didn’t yield anything I prefer over the Headphones.com EQ Repository preset for the Meze Empyrean II. Some of that could be the measurement I used, but it could also be because I have very different goals for the sound of my Empyrean II vs my Hifiman Mini Shangri-La.
In fact, even with my MSL I’m somewhat torn between what this method created and what I had before. The new preset is a bit more spacious and instruments are more distant. Normally this would be an easy win but instruments also sound less detailed. This makes sense though. You hear more detail from a guitar right next to your ear than one across the room.
Not bad, maybe I have to add more bass
Since we do not listen to the ideal steady-state but one with varying amounts of DI increase in the treble, have you played around with an exact filter to add on top of the half-tilt filter to emulate variability in this region? Would this be the exact same as the Harman treble filter, or, given the half-tilt method, would such a filter differ from Harman? We know there is a lot of variability in preference in this region, which is why I have done multiple tilts across the frequency spectrum rather than a single tilt value. It requires a bit more work but results in frequency responses more akin to your steady-state adjacent half-tilt but accounts for varying DI treble tilt/roll-off, so it would be interesting to have an ancillary filter to make this process simpler (or two, one with roll-off for non-waveguided and one with less roll-off for waveguides tweeters). Just speaking from cursory subjective comparisons, this fixes my slight upper treble issues with half-tilt alone.
Hi! I’m sorry for what might be a dumb question, but what is “DI”?
I should read the OP a few more times and check out the references to make sure I understand the position being advanced, but my first reaction to the hypothesis is that you’re basically talking about something like the Meze Elite (setting aside for the moment whether you like or dislike it >6kHz): It is basically a DF-targeted headphone with a low shelf pretty close to 500Hz.
Which I was listening to all of yesterday and think sounds great!
It is directivity index, a measurement of how a speaker radiates energy in different directions. Due to the increasing directionality of shorter wavelengths, I.e., increasing frequency, dispersion tends to narrow the higher in frequency ones goes. This is why a speaker has a slope in a typical room. In a speaker without a waveguide or horn, this tends towards a roll-off after a certain point rather than a distinct slope. In a speaker with a consistent horn or waveguide, this tends towards a slope, though most still lose control at the highest of frequencies. This is all a touch reductive, but I’d say generally true.
