I’d be willing to bet that the effect of the Sbooster, if there is one, has nothing to do with the performance of the RME unit itself and is, instead, due to there being less noise fed back onto the AC supply where it might affect other components.
I say this for several reasons:
The first is that the very first thing that happens to your power after the power-input jack on the RME is that it hits a very-high-frequently SMPS inside the unit, followed by a series of regulators, level shifters and so on. While SMPS aren’t good for what happens to the upstream AC supply, done properly (which RMEs are), they’re almost completely immune to upstream power quality issues.
Having more power available to the RME unit (i.e. the higher current rating of the Sbooster vs. the included PSU) does nothing to its performance … the RME draws what it draws and it won’t draw the full 2A of the stock supply, let alone more.
I’ve measured the RME’s performance using a number of PSU options, ranging from a car battery with, and without ULDO regulation, a SotA lab-supply (which achieves better noise, rejection, stability and precision in practice than any of the “audiophile” supplies I’ve seen even claim) and various after-market supplies. Performance changed by less than 0.4 dB between best and worst … that was down around -130 dB, which is a) below any possible audibility and b) essentially down to variation in tests (a difference in how tightly the cables connected, were run, or how oxidized one part was, can easily yield such an error at such tiny levels).
Which is not to say you’re not hearing a difference, but it’s almost certainly not because the Sbooster is making any measurable or audible difference to the performance of the RME unit itself.
If you’re using AutoRef mode, to maximize the dynamic range performance of the RME, then this means you’re listening at about 50dB - 60 dB average level with the HD650. That’s pretty quiet … so much so that I’d be surprised if there was any slam to their delivery, and well within the region where using the “loudness” function would be useful to address equal-loudness-countour issues.
Beyond which, that’s a lot of digital attenuation, even for a software-volume control as good as the (42-bit precision) implementation on the RME-ADI 2 series.
On the filters …
My preference is also for the “Sharp” filter (which is a linear-phase filter). The “SD Sharp” filter (minimum-phase) messes with my perception of timbre, which I seem to be trying to subconsciously adjust to, and the end result is that listening gets fatiguing in ways that it doesn’t with the “Sharp” setting.
Curiously the “NOS” and “Slow” filters I don’t like at all. They don’t do much to address aliasing, which may or may not be the reason I don’t really like them … but perhaps not because the CYAN in NOS mode has aliasing issues that are the same, or larger, and I don’t have issues with that on the Holo Audio unit.
However, when fed from the Hugo M-Scaler, with the RME unit in “NOS” mode, well, now that’s an interesting proposition. Not a remotely worthwhile one, but there are audible (and measurable) differences that I did not expect to find.
