Advice on a Headphone Specific System
If its DAC is so good, then you can pitch your Topping.
It’s DAC is good. The Topping is fantastic.
I just couldn’t resist. I’m happy with my Schiit Bifrost 2/64 for the main, the Schiit Modi Multibit for work. I frequently use the Audeze Cipher cable with my LCDi4, but if I’m using ROON, switch to a standard cable and the Luxury & Precision W4.
On occasion I will use the Fii0 K9 Pro ESS, which I think is pretty good as a combination unit and is luggable. When at the house in State College, I’m fine with a Sabaj A20d. (Unless I’m on the very portable stuff). I find that once you get to a certain level, the differences become subtle to my educated but decidedly grade B (but large) ears.
I made the early decision to take a lifetime membership to Roon. I am glad that I did!
