Audeze LCD-XC over-ear planar magnetic Headphones - Official Thread
Hi @Resolve ,
My LCD-XC headphones just arrived today. I’m seeing @Resolve all over the web re EQ settings for Audeze LCD-X and LCD-XC headphones. And here you are! I’m not certain how to enter these numbers in Roon.
For instance, in Band 1 is it:
30Hz ; 0 db GAIN ; 2 Q
or is it
30Hz ; 2 db GAIN ; 0 Q
and which bands are High Shelf, Peak/Dip or Low Shelf?
Sorry to be such a NOOB.
Thanks for your help. I want to start with a tried and true recipe first before creating my own signature.
I should do a roon conversion video. dB = amount changed, Q = how wide or narrow the adjustment is. That’s about as simple as I can explain it for now. Maybe you can paste an image.
Hi @Resolve , thanks for your quick reply.
This is the EQ preset I created in Roon and Roon Arc MUSE from, what I understand of, your Audeze LCD-XC table. Could you let me know:
Do I have each band entered correctly with regard to Low Shelf, Peak/Dip and High Shelf (is there a high shelf?
Where in Roon do I add the -6 dB GAIN for Preamp?
Thanks again.
That would be overall level slider. Honestly I’m not familiar with roon anymore as my subscription expired. So maybe someone who uses it can chime in. @Torq do you use roon?
@Resolve are all my other settings correct concerning the " Low Shelf, Peak/Dip and High Shelf" designations?
I do!
There are two ways to do it:
  1. In the Parametric EQ filter, there is a slider on the far right of the band display. Click and drag it to change the “Preamp” gain. The value is only shown while you have the mouse on it and the left button clicked.
or
  1. In your presets, add the “Headroom management” filter. In there you can set a negative amount of pre-gain just by typing in the value.
    You can (and should) also enable the “Clipping Indicator” here, which will make the “Signal Path” indicator turn red if you wind up with any samples clipping during playback (so you’ll know if you need to reduce the pre-gain/change the headroom reduction further).
Hi guys, I’m new here. I have an AK SE 180 and some Audeze lcd-xc. Do you have any appropriate equalization for this system? I would like to get the most out of the headphones, thank you.
Great question, but I can really only comment on Equalization approaches or tailoring for the XC. In my experience the sub bass( 30 to 90k) needs quite a lift. Upper and lower mids need to come down to reduce shouty’ness and honk. The treble I find on the XC is absolutely fine. I don’t touch it but your mileage may vary. Anyhow. Please pass along what you end up doing on your SE 180. I’d be curious.
Another thing. The LCD XC is a bit more demanding than listed power wise. My KANN MAx I find does not pair well with the XC. Just saying. Even on super duper gain. :face_with_spiral_eyes:
Hi to everyone!
First time posting here, but long time since following Resolve and The Headphone Show :slight_smile:
May I ask if anyone knows if @Resolve measured LCD-XC Leather or Leather-Free?
I want to replace earpads on mine cause i feel really low sub and needs approx. 10dB boosts to be good.
Many thanks in advance!
I believe leather. Yeah that’s the issue with closed-backs in general, they don’t seal consistently across different heads, and that’s particularly consequential in the bass. I recommend boosting that with EQ if possible.
Many thanks for your answer!
Ended up boosting a little further on 20-50Hz region and replacing with new pads and now it seems to be better.
That could also explain little inconsistency between L/R Bass Quantity.
I think that pad wear on this pair it’s a major problem and after i replaced them, its now better.
Dreamed to measure them, don’t know if i could buy a clone IEC rig with pinna or need to inform for a payed measurement service in EU.
By the way, thanks to you and the team for every useful information and the consistency of.
EDIT:
I’ll leave my EQ Presets for FabFilter Pro-Q 3 and MAAT thEQorange here.
Both of those are linear phase.
I am a huge fan of the LCD-XC. These became end-game closed back headphones for me after I found the perfect EQ settings.
Resolves EQ settings from Dec 2021 are stellar in my opinion. I absolutely loved the improvements those settings provided, but I found what to my ears are the perfect EQ settings when I mixed Resolves EQ settings from 2810 kHz and above with 3 EQ settings that on their own already sounded great with these headphones. Your mileage my vary.
I only used Resolves 7 EQ settings from 2810 kHz and above. Below that I used these 3 settings…
20Hz Peak +9.0db, q 0.15
400Hz Peak -1.4db, q 0.15
2000kHz Peak -1.9, q 0.20
Preamp -9.5db.
Like many others here, I’ve found the LCD-XC is great with EQ. (I’d not been an EQ user until buying the JDS Labs Element recently, but it is so easy with their Web-based interface I thought I’d try.)
Two very simple adjustments are great: +5 dB at 60 Hz (Q=.707), -3 dB at 1.5 kHz (Q=1). The latter seems to bring out spatial effects. The former I could probably increase, but it seems fine for classical right now.
Is there any difference in tuning between the leather and leather free pads?
Yes, there is an audible difference. I have had both. To my ears the leather free pads have slightly less (maybe 2db) sub and mid bass. Also, slightly more energy in the treble around 8-10k (maybe again maybe 2-3 db). I use EQ, so no biggie for me. Though the leather pads feel waaaay nicer, so I use those anyway. Without EQ the differences would be certainly noticeable as this headphone in stock tuning lacks midbass and is very airy already.
I’m gonna have to buy leather pads then, I bought a lcd xc and didn’t realize it was the leather free pads until it arrived lol.
wow this hasn’t aged well…
Hah! Yes - though it’s still technically true. If you don’t know what the compensation is it’s kind of useless. Also, in our case we’re not actually compensating to any target, rather the transfer function of each measurement rig. Think of it like doing mic calibration to get a consistent baseline rather than compensating to a target.
Haha yeah I know, there is more nuance to it. But I was just reminded that measurements have come a long way. We all had reservations when it comes to actually using a “staight line” but you guys kept eliminating them one by one. I’m sure there are still some issues to address. What do you think about this transition? Would you say it was a smooth ride until now?
Well we’re technically still not doing a straight line. The purpose of this compensation is that flat is not preferred. Rather, just like with speakers, a downward tilting response is preferred, which is what the overlayed preference bounds represents. As for how it’s gone… a lot of people have built up their understanding of headphone measurements using raws, our community included. So it is difficult to try to retrain people to think about this stuff in terms of the broader picture. Still, even those of us who are hardcore into measurements… like the nerdiest among us, prefer to use it this way. And that’s because it prevents the common legibility errors imparted by the sine illusion.
So, it’s come a long way but there’s a lot more to go still.
