Compact Speakers for Desk Use
Right now I’m mainly considering the iLoud MTM MK2. They’re small enough and I want to try the built-in room correction feature. Other than this pair, the only other good options I know of are common recommendations like the AudioEngine A2+.
https://www.amazon.com/IK-Multimedia-compact-correction-emulation/dp/B0D5JY7ZG9
Anyone know some other good options to consider?
Check out this video. Erin is my favorite speaker reviewer and backs things up with data.
I bought the IK MTM Mk2’s a few months ago and have been very happy with them. I’m using a Universal Volt as an audio interface. I also have their subwoofer which is great but isn’t a total need unless you are making music.
Thanks I’ll look into his videos
That’s good to hear. You’re talking about the regular MK2’s and not the Precision model right?
I had the Audioengine 2+ for many years, and recently upgraded to Adam D3V, after checking out a few other desktop speakers. I liked the size, the linearity, tone, bass, and the switch on the front. It was also about 2/3 rd the price of the i Loud in Australia.
The D3V is on my short list. It has really good reviews. And yes, Erins Audio Corner is one of the best audio science sources online. He measures everything.
For desk use, I’d focus on nearfield speakers with a compact footprint rather than just looking at the smallest models. Good placement makes a big difference too, so try to keep them at ear level and angled slightly toward your listening position. Also, consider how much bass you need, since smaller speakers can struggle with low frequencies. A decent pair of compact active speakers can be a great setup without taking up much desk space.
