This is the place to discuss all things to do with the Dyson Zone air purifying headphones.
This one is very strange, but I imagine there is in fact a use case for air purifying headphones. I’m taking a look.
Here are the measurements.
B&K 5128: Using DF + 10dB Slope
Raw
Compensated
Sound Profiles
GRAS: I got two common positions on the GRAS, so this may give an idea of how it may vary depending on the position it’s worn on the head.
We’re currently in the process of updating the KEMAR DF + Slope target so I’m showing them against Harman for now. Also Sean would want to see this ![]()
Position 1
Position 2
A coarse grained look at the tuning indicates it’s solid for bass and mids, just a bit too bright, and I’d take a downshelf to the treble by at least 4dB. There are also some noticeable fine-grained treble peaks that come across a bit sharp, in particular the one at 7khz, which is definitely audible.
ANC Performance:
Attenuation
ANC is good in the bass, but nothing special for the rest of it. One thing with the ANC, the app seems a bit glitchy with when ‘isolation’ is turned on, as it sometimes doesn’t toggle correctly. I’ll double check the measurements, but I expect the above is the actual result since it shows a clear difference with passive isolation mode.
I don’t think the glitchiness is down to the ‘on-head’ sensor not triggering since it occurs even when listening to the headphone.
The Mask
It’s more of a mouthpiece than a mask. The headphone intakes air through the cups through a filter and pipes it down into the mouthpiece, blasting you in the face with purified air. It’s… a unique experience.
Notes:
- The headphone has good build quality, but the mouthpiece is the worst feeling plastic of all time, likely to ensure it’s not too heavy.
- Comfort is decent but it’s also a bit heavy, creating a hotspot up top.
- Subjectively about middle of the road technicalities. Occasionally the treble gets a bit mushy and smears tones together a bit. Certainly not better than most other lower priced ANC headphones.
To me this is a device that is either highly useful for very specific niche situations, but apart from that, it doesn’t really need to exist.
