After twice being a button-click away from buying these last year but deciding against, I am considering again (after an infusion of cash ).
Would love to know how the ANC does on flights. I’m used to Bose ANC doing very well on airplanes. Believe I’ve heard the Bathys is “ok” but not quite as good in this scenario (maybe 80-85% as good as a benchmark). Thanks in advance.
I don’t have anything to compare, because I had not found a convincing combination of ANC and good quality lossless play before. I just returned home (California) from Europe, used my Bathys in DAC mode, USB-C from my Pixel 8 Pro running USB Audio Player PRO, local lossless music library. I could listen to complex music with delicate passages without cranking up the volume, good experience. For just quiet without music, I could set the headphones to “silent” (maximum ANC) mode and switch them to DAC input, they served as a good sound block.
It amazes me when I run across a review of ANC earbuds that claims they are great on airplanes. No, they aren’t. They just don’t block as much ambient sound as over-the-ear ANC headphones. I don’t have the Bathys, but the Bose QC45 and an older set of Sony WH-1000XM2 are both much better than Airpods Pro 2 at blocking ambient noise in every situation.
Having used the AirPods Pro 2 on a flight last year, I will say I was surprised at how well they did, but you’re right that over-ear ANC have an inherent advantage.
Received my (Dune) Bathys yesterday (open box from Headphones.com). After some initial disappointment, I think they’re breaking in nicely and I’ve had some impressive moments.
One thing … I thought I could hook them up with the provided USB-C cable to my iPad Air (4th gen), which has a USB-C connection and use DAC mode. But, with Amazon Music, I’m only getting 24/48, so I seem to be doing something wrong. Adapter needed? Or maybe this iPad doesn’t support it?
I did connect to my Windows desktop and DAC mode works fine. Need to spend more time with it that way.
This OTG adapter enables DAC mode from my iPhone 12 Pro Max, which is nice. I would prefer to use my iPad (Air, gen 4), however. It has a USB-C connection; as mentioned before, connecting directly to the iPad in DAC mode doesn’t give me full resolution on Amazon Music.
Long shot … but wondering if anyone can comment on this OTG … only $9, so if there’s no feedback, maybe I just take a flyer on them. Worse case, I have some extra USB-C adapters in the drawer.
Maybe a silly question but do I need a mid end DAP with these ? I never listen to these outside as I have my Sony WF5s for gym etc and a Shanling M1S for LDAC duties with them if I sunbath. Inside I can use these wired to my iPhone 14 for lossless - I have just bought an IBasso DX180 but is there any advantage of that over my iPhone wired to the Bathys ? I presume there will be difference over BT between the iBasso and the Shanling but would there be much difference between my wired iPhone and the DX ?
When you feed analog from a DAP to Bathys, it goes through an internal ADC and then through the internal DAC. I can’t see how that would improve over lossless digital iPhone>Bathys. In my experience, phone>Bathys sounds better than DAP>Bathys (DAP is A&ultima SP1000M, not a slouch as a DAP).
I’m considering getting a Focal Bathys for travel and commute due to its ANC and over-ear design. I have Focal Clear. So I’m curious what differences I should expect in terms of sound quality and tonal signaures between these two? How far “behind” is Bathys from a wired open back headphone like Clear?
This, IMO, is more a question about use cases than sound quality. I have both the Clear and the Bathys, and given that both are at hand, I will always choose the Clear for sit-down listening. But if I am traveling and I care about ANC and wireless, then the Bathys is perfectly acceptable both during the commute and in the office afterwards - I’m not exactly doing critical listening, but rather listening for enjoyment in a dynamic environment. I.e., the Bathys supports more use cases than the Clear (or similar). That said, if you are in the Apple eco-system, the AirPods Max are pretty good too. And, in my case, those are what I travel with. I tend to use the Bathys in my home office for music and entertainment when I don’t want to be tethered (I think that the DAC capability is cool, but if I am going to be wired, why not listen with the Clears?). YMMV and all other relevant disclaimers apply.
The clear is better in nearly every way, but the most notable changes will be the mids are way more forward, vocals are right in your face, the bass goes a deeper and has more impact, it’s faster and doesn’t get incoherent in busy music passages.
On the negative end, the clear is heavier, the pads stain easily, the vocals can be too forward sounding like a radio voice, and it sounds metallic at times. Neither sound natural but the Clear sounds more natural outside of voices.
I’d say the clear is a more fun and engaging tuning, but it really is a love/hate thing. For a lot of people it’s their absolute favourite and others absolutely hate it, I had to EQ 1.5khz down and I love it now. The bathys is also great and especially so with Dolby, it’s the only headphone I like Dolby with.
I tend to purchase only Anker products through amazon. Not all converters and adaptors work, all made overseas. They have similar ones around the same price point due to competition.
Writing here to discuss some of my grievances with the functionality of the Focal Bathys. Discussions of its tuning, best ways to EQ it, etc., are good and all, but I think that the Bathys fall short on a number of simple quality of life aspects that leave me frustrated, especially given how good they sound. These are meant to be portable, to travel with you, and I hope that in its future iterations, Focal can further improve on these.
They must be turned on to be used in wired mode - no passive use is possible.
ANC can only be turned to active, soft, or transparent. You can’t turn ANC off.
That being said, I don’t want to see Focal to adopt the iterative, yearly release of incremental improvements that we see with Apple and Samsung. Bathys 2, etc… I’m sure I’m not the first to voice these concerns, and I wonder if they could be addressed with a simple firmware update (whether they would is a different question). I’m currently testing a pair of Dali IO-12 to see if they are a worthy replacement, and while they address the passive use and ANC issue, their ergonomics and comfort aren’t perfect. For the time being, I’m keeping the Bathys and just dealing with these slight annoyances.
There’s no direct analog path to the drivers that would support passive use, so it’s not a question of firmware. Analog input is first A2Ded and then goes into the internal digital path: DAC>amp>drivers.
I had the Bathys for a while. Returned them after I got the Dali IO-12. They’re not in the same league as good as the Bathys OG is–Dali is extremely clear even at higher volumes. With DAC mode Bathys does not maintain that clarity. For me price-wise Dali is worth $1k, Bathys $500. Bathys MG at $1,499 is some marketer’s pipe dream.
I was thinking of buying Bathys for a long time, but still hesitant because of the bass. I mostly lissen to hiphop and instrumental jazz so all kinds of bass is the big thing for me. Is it possible to EQ them to be more suitable for these genres or should I just go with other headphones(momentum 4s, px7s3, etc.)
P.S.:I really, really far from being an audiophile and have used either budget-mid range gaming headphone or samsung ear buds
