Hi folks,
I just got a set of the Clears (“OG”) for an outstanding price, and I’m really, really happy with them.
I’d like to ask folks about cables for my use-case. The DAC/amplifier that I’m currently using is my first, the one and only Chord Mojo! I love it for desktop simultaneous play/charge use, and don’t intend to upgrade to a new DAC and amplification setup for some time. However, my first order of business is finding a new cable that is both supple/flexible and affordable in 10-foot-or-more length (to be able to lounge in my chair or in bed without having to move the iPad/Mojo station).
As many know, though, the Mojo’s output is not balanced. I’m still new, but from what I gather, this would render it incompatible with balanced cables? I like the Hart Audio cables for the price – however, in this case, the HC-9 appears to be the compatible cable for Focal Clears, and it is advertised in particular as a balanced cable. Any suggestions for how to proceed? (I also have a vague sense that perhaps this can be circumvented by using the Mojo’s line out, but I may be mistaken.)
Hart Audio cables seem to be the choice for many, and their prices are great. But for use with the Chord’s unbalanced 3.5mm outputs, am I limited to searching elsewhere for my cable(s)?
edit: Bear in mind that I am on a budget and not looking for ‘jewelry’ category cables – just a quality cable that works, and can be ordered in larger lengths for freedom around my room.
@Tchoupitoulas mentioned on my thread over at HF that the Hart Cables are extremely flexible in use,
Replacement, after-market cables are easy to find, though. I like Hart Audio cables, which are nice and supple and relatively inexpensive.
- (A key thing to know about the Hart cables is that you have to buy the headphones cable and then separate interconnects. It sounds complicated but is, in fact, a clever system: the headphone cables terminate to a female 4-pin mini-XLR; these you then plug into the correct interconnects you’ll need to plug into your source. The advantage of this system is that you can buy one cable and multiple interconnects for balanced or single-ended sources of different sizes or configurations, see here).
and so my question is, given some of my reading, are their cables – used conjunctively with various interconnects – actually capable of handling the Mojo → Clears chain?
Thanks so much, cheers.
