Share and discuss your impressions of different measurements in the new GraphWorks visualizer tool, whether you’ve actually listened to the headphones or not (which is normally taboo on most audiophile forums).
I have not listened to most of the headphones in this tool btw. So most of my impressions will be based on the 5128 graphs, and sometimes some virtual listening. So they should be taken with a grain of salt.
ZMF Bokeh Closed - Right Channel
Looks somewhat interesting. The response is not that smooth. But it forms a general downward slope toward the treble (which is good in my book). On these compensated graphs though, I expect a neutral response to elevate above a slope in some spots in the treble. Notably at around 6k, 9k, and 14k. So it looks like this tuning is a bit on the darker side there. The peak at around 14-15k is mostly missing though. So not much air there, it appears. There is also a bump or undulation in the bass that appears to need some smoothing out.
Warwick Aperio
Appears to have some asymmetry in the treble (left and right channels don’t match well there). It doesn’t look too bad in the Single Line and Percentile Trace modes though, with the two channels averaged together. The mids are a little too forward though, and upper mids around 2k maybe a bit too depressed. Overall though, the averaged curve doesn’t look too bad.
T+A Solitaire T in HQ Mode
Has a reasonably decent downward slope in the bass and mids, except for a little blip at around 100 Hz. Low treble is missing though. And it looks like there could possibly be some sibilance or excess brightness above 10k. The overall trends in this curve don’t look too bad though. The lack of low treble will probably have a noticeable effect on timbre though.
SJY Horizon Closed
Nice bass bump! Could maybe use a bit more warmth in the low mids though at around 300 Hz. And might be a bit sibilant around 10k, and possibly 6k. Might need a bit more air as well, though it’s a little hard to tell what’s happenin there.
Sennheiser HE-1
Decent slope in the bass and mids, until you get to the fairly sizable BBC dip. Treble also looks a bit too forward, though the peaks are in the right spots. The dip (or dips?) in the upper mids will probably also accentuate the brightness on top.
