The EQ settings can only be seen with Abo?
What do you mean by Abo?
The monthly access for 4.99 $
Can I put GraphWorks between Roon and HQP (and disable any DSP in HQP? (In Roon all is already disabled))?
Yeah GraphWorks EQ requires a Graphworks Access membership
You can’t run it inbetween Roon and HQP because HQP doesn’t have any form of virtual input, it can only capture audio from the system’s input/microphone devices. GraphWorks EQ has one, but HQP would be capturing the audio that roon is feeding to it, before any EQ/DSP is applied.
Graphworks EQ does have very high performance oversampling built in though so you can just use that instead of HQP
Question about GraphWorks EQ: in the Output Settings the default target latency in Engine Timing is 50ms. I understand 20ms shouldn’t be used because of the helpful explainer but what about 30ms? Any drawbacks? I hope your upcoming video goes through the various options but I don’t know how in-depth it will be so I might as well ask here.
A couple of additions that I would love: adding notes to created eq profiles (a simple notepad style window would suffice akin to the “Description and notes” field when saving in Peace APO). oratory1990 always leaves little bits of advice like “Adjust gain of band 1 to preference (bass)” on his profiles so it would be nice to have that information accessible.
The other request is a lot more involved but I would love some sort of tutorial on how to use the tools inside the program. As an example, getting into the test sweep mode and actually teaching the user how to use it to remove peaks and dips while pointing out what to listen for. In short, an integrated “How to EQ for Dummies”.
I know the same thing could be achieved through a YouTube video tutorial but it would be cool to have it be a part of the program itself.
Congratulations on the release and bless the soul that came up with the audio matching feature for A/B testing. That one is almost worth the subscription price by itself, simply fantastic.
Great question! For me the only limitation has been the processing power of the computer, so if your machine can handle 30ms without any clicking/popping (signs that the computer can’t keep up with the latency target) then you’re totally fine to use 30 ms! That’s what I usually stick with.
Love this idea, @GoldenSound add it to the list please, O Wise One!
Yeah this would take a lot more time, but I also like this idea. We’ll talk about it, because I think its something that would be useful to have (but maybe should be enabled only in a certain “Beginner” mode as to not annoy people with pop ups? Idk, we’ll have to discuss it).
Glad you’re enjoying it!
On most systems and with most programs 30ms should work fine. Generally my advice would be try it out and as long as you don’t hear any clicks/pops you’re good. 50ms was chosen as the default just to ensure that the software works cleanly out of the box for everyone unless something is really wrong with their system, but 30ms works on all the ones I’ve tested so far except for one program that was outputting audio in enormous chunks.
This is planned! It will likely be an article rather than a video, though could end up being both. In the meantime, happy to answer any questions ya might have here!
I’d also like to get a tutorial/first-run-walkthrough integrated into the tool, but that’ll be a bit more work so would come later.
I’ll see what I can do! ![]()
Thanks, but my whole listening environment of three rooms is build around Roon and HQP (distributed via 3 RPis and only in one room HQP) on my MacMiniM1 (mostly used headless) and all controlled via my ipad.
So not sure how to fit in Graphworks instead of HQP.
Just FYI, Tidal 2.46.0 broke exclusive mode on Mac for several devices including Graphworks EQ (can’t test on Windows) . I verified on multiple machines. When you select exclusive mode on the output selection, there is no error, but no audio is sent to the device. If you disable exclusive mode, audio resumes. So far, my Eversolo DMP-A6 G2 is still working on exclusive, but Graphworks and my Topping DAC don’t. Reverted back to Tidal 2.43.2 and the bug was gone. Updated to 2.46.0 again (released yesterday) and it’s back to being broken. Letting you know in case someone reports this as a bug.
I understand the motivation of “it’s perfect, so I don’t need to worry about it”. I also get the drive to make a perfect tool. Perfection often has its costs, though, so isn’t always the goal.
Do we think that GraphWorks EQ would sound demonstrably better than other established, good EQ software in a blind test? So, yes, it’s bit-perfect and Equalizer APO isn’t. Yes, resampling happens. I’ve tried resampling over and over again and not been able to find significant effects, though. Yes, it’s 64-bit with effectively infinite headroom and yes, doing lots of sequential math on 16-bit ints will lead to quantization error (which isn’t what’s done in things like EQAPO). Yes, it’ll be able to run at 768 kHz. But, given the limits of audibility, do these actually matter? I can run an analog interconnect between my gear that tests good to 100 kHz or one that tests good to 10 MHz. The second is “better” in that “I never need to worry about high frequency loss”, but I didn’t have to worry about it with the first one either. It’s issues are well outside what I can hear.
If these things do make a real difference, we have real progress. If they don’t, are we just fixing problems we don’t have? Does pushing for 64-bit, 786kHz not invite the next one to run 96-bit, 1024 kHz and start comparisons like “my SINAD is 130 and yours is a measly 125 dB!” that hasn’t done the field any good?
Don’t get me wrong, the work to do this is remarkable and it gets to tick the “this is perfect” checkbox. Perfection comes at a cost, as Golden pointed out, in the form of time and a mighty expensive kernel signature. It comes at a cost for users as well. Do those who can’t run it now have to think we’re missing out on some real, audible improvement to the sound? I can’t seem to pass a blind test across my various DACs and amps, but I’m middle aged, have a bit of tinnitus, and lived most of my audio hobby time under the idea that THD+N of <0.01%, aka -80 dB down was a reasonable number and that certainly anything beyond 95 dB was effectively not an issue. So, I’m likely not the one to answer this. To others, is it demonstrably, audibly better?
Is there any plan to add support for Linux as that would be greatly appreciated?
Yes! It’s being worked on now, no idea how long it will take, but stay tuned.
I don’t care about the bit-perfect stuff at all, I think it’s mostly there because… well one, I think Cameron does care more about that stuff, but also because its a serious value add to many people who care about it. The realm of software for handling bit-perfect playback is essentially confined to a few options (Roon, Audirvana, etc.) all of which are kind of terrible in their own ways, so even if this isn’t something most people should care about, for the very specific hyperniche of people who care, it may well be a godsend.
Nice to hear, looking forward to it!
Linux version for Graphworks eq?
Are you saying MusEQ is not bit-perfect, not EQ software, or you aren’t aware of it?
I sent ya a DM ![]()
messagetooshort20charlimit
By the way, this was fixed by the Tidal update pushed out this morning. GraphWorks EQ again works with exclusive mode.
