Of course you can export separate EQ files from GraphWorks EQ for L/R specific adjustments, but I haven’t found a way to import. Other software uses a channel 1, channel 2 implementation in a single file with one listed after the other (as in Squig) but I wasn’t able to import a test file into GraphWorks EQ. Am I missing something or is that not a feature yet? Thanks.
That’s not a feature yet but should be a simple addition!
Admittedly I’ve not actually used a L/R preset import from other software before. Would you be able to send me an example one so I can check the formatting?
Thanks!
Sure, awesome. There are several “standards” out there. Qudelix uses one but Squig is slightly different (see below). I’m sure there are tons of others too. Honestly I’m not sure it matters if you use an existing format or come up with your own. You could also just allow import of separate L and R files if that’s easier. Super simple for me to chop up a single file into 2 or just adapt to a different format. Beyond just headphones, my use case is room correction for speakers. I have PEQ’s for my 2 channel setup I’ve adjusted to Harman In-Room as well as B&K targets. I know your focus is headphones but it’s very cool to be able to target my streamer from GraphWorks EQ with room corrected audio for the living room system. I can enter all the adjustments manually, but it’s of course easier to import. Once we get to the point you allow import of other targets, I could easily import my calibrated room microphone measurement (uncompensated) from REW and do my room correction directly in GraphWorks EQ. GraphWorks EQ’s UI is so much better than editing in Eversolo, especially when you have different corrections for audio, movies, gaming, etc. like I do. Love this software for the record…
Squig (If you make a common adjustment to both channels, it appears on both EQ’s like the first 3 lines in this example. Lines 4-7 were only made to the individual channels obviously.)
Channel: L
Preamp: -10.4996 dB
Filter 1: ON PK Fc 116 Hz Gain -8 dB Q 1
Filter 2: ON PK Fc 393 Hz Gain 9 dB Q 1
Filter 3: ON PK Fc 861 Hz Gain -8.4 dB Q 1
Filter 4: ON PK Fc 40 Hz Gain -10.4 dB Q 1
Filter 5: ON PK Fc 125 Hz Gain 8.8 dB Q 1
Filter 6: ON PK Fc 252 Hz Gain -13.4 dB Q 1
Filter 7: ON PK Fc 510 Hz Gain 11.3 dB Q 1
Channel: R
Preamp: -10.8422 dB
Filter 4: ON PK Fc 33 Hz Gain -4.5 dB Q 1
Filter 5: ON PK Fc 71 Hz Gain 5.1 dB Q 1
Filter 6: ON PK Fc 116 Hz Gain -6.8 dB Q 1
Filter 7: ON PK Fc 302 Hz Gain 6.4 dB Q 1
Some changes to make navigation/browsing easier went live on GraphWorks today.
The brand view is now much easier to navigate with collapsible entries per brand
The item view can also now be a list instead of a grid, and has filters for headphones/IEMs
Hello peepos!
Could anyone confirm if MIRE measurements are available for any of these devices? I want to try it out but I don’t see any MIRE measurements on the website (I think I need to have an active subscription?)
- Letshuoer S12 Pro
- Sennheiser HD 599
- Sennheiser HD 560s
Thanks, in advance! ![]()
No data for S12 Pro—we don’t do MIRE for IEMs—or HD 599, but I went ahead and uploaded my data for the two HD 560S units I’ve measured on my head.
I just wanted to say that the combination of the in house measurements, preference bounds, and EQ’s features makes for a very nice work flow, and for me personally, very good results. Today I took the dogs that are the Truthear x Crinacle Zero: Blue 2 and turned them into something actually pleasant. The resulting EQ curve by itself looks horrendous and I would never arrive at it if I used Hangout’s squig page and Crinacle’s measurement, but knowing where my personal preference lands on the graph, it took very little time to have it sounding good.
I have done an EQ for it before, using squig link, and it was OK, but I like where my treble ended up better after using Graphworks.
Some improvements to the site visualiser also went live today!
There are also a couple easter eggs in the site which I’m sure people will find soon ![]()
Thank you so much! ![]()
This visualizer graphing tool is comin along. Now you can see and select from a list of all the measurements, which is a great improvement. I wish I could load my own targets and compensation curves though. And maybe that’s included in the registered or pay version.
I am tending to use the No Averaging Trace Mode because it’s a bit easier to see the blue and red squigs in dark mode than the default purple color for the Percentile and Single Line modes (when both channels are available… some measurements only have a single channel though). And it also gives some idea of the headphone’s left-right symmetry.
I don’t use either the new or old pref. bounds. Neither is that useful to me on over-ear type headphones. And a slope is useful only up to about 5k with the default compensation curve imo.
