Hifiman Ananda Unveiled Review - ONE Big Problem
The Hifiman Ananda Unveiled is one of the more recent additions to Hifiman’s open “Unveiled” lineup—and also the most affordable. Despite that, it hasn’t generated nearly as much buzz as its siblings. This is a headphone that gets about 90% of the way to being excellent. Unfortunately, the remaining 10% holds it back in a way that’s hard to ignore.
What “Unveiled” Means
Like the Hifiman Arya Unveiled and the Hifiman HE1000 Unveiled, the Ananda Unveiled removes much of the outer grill structure, leaving the magnets—and even parts of the membrane—visibly exposed; it’s a design choice that prioritizes openness and minimal obstruction. Visually, you’ll notice a mix of rounded and squared magnet structures, which may differ slightly from the higher-tier Unveiled models. Structurally, the Ananda Unveiled shares more in common with Hifiman’s newer chassis designs like the Hifiman Edition XV and the Hifiman HE600.
Build & Comfort
Ergonomically, this follows Hifiman’s updated headband system with a suspended strap design, moderate clamp force, and large oval cups. For my larger-than-average head, clamp was noticeable but not excessive. The main issue is the strap compliance. When extended, it becomes taut and can apply pressure to the top of the head. It’s not outright uncomfortable, but it could be more forgiving. That said, most listeners should find it reasonable enough for long sessions.
Measured Performance: Mostly Excellent
On standardized measurement rigs, the Ananda Unveiled shows slight sub-bass roll-off, some jagged modal behavior in the mids, but zooming out its a reasonably balanced overall presentation. The modal wobbles we see in the mids are similar to what we’ve seen in the Edition XV—but these aren’t especially perceptually offensive. But once we get to the treble... that's where the problems start.
The 7–9 kHz Resonance
So, on my head and ears, there’s a sharp 10–12 dB peak around 7–9 kHz. Vocals that should sound natural top-to-bottom will sound fairly decent but then suddenly spike HARD on “S,” “F,” “T,” and “SH” sounds. Percussion also occasionally oversteps into harshness as well.
Unfortunately the feeling this headphone leaves me with is that everything is fine until it isn’t, because when that resonance shows up, it’s piercing. What makes this especially frustrating is that the rest of the tuning is actually solid. The presentation has a nice sense of space and clarity, detail retrieval, staging, overall resolution—most of it is genuinely strong. But that one treble spike can makes a large swathe of recordings fatiguing to the point of distraction for me.
Why Not Just EQ It?
In theory, this should be an easy fix, but after actually trying to fix it, it’s not. The resonance is very narrow, and slightly different in frequency between left and right channels for me, which means likely to shift depending on individual ear geometry too—you may not hear this peak when listening to this headphone.
That means EQing this headphone is going to require individual, precise, per-channel EQ adjustments tailored to your own head. This isn’t a simple “add a bass shelf” or “apply one wide treble cut” situation. It’s surgical. While the Ananda Unveiled would otherwise be a strong EQ candidate—thanks to its openness and decent extension—this particular issue isn’t predictable enough to offer a reliable universal fix. And that makes it difficult to recommend confidently.
Comparison to Arya Unveiled & HE1000 Unveiled
Interestingly, both the Arya Unveiled and HE1000 Unveiled are brighter overall in the treble—but they’re smoother, having fewer high-Q peaks and dips, and to me at least, that smoothness matters more than the level of absolute brightness. Even if they present more total energy up top, HE1000 Unveiled and Arya Unveiled avoid the sharp, uneven spike that causes fatigue for me, and the result is a cleaner, more refined high-frequency presentation.
Final Thoughts
The Hifiman Ananda Unveiled is frustrating because it’s almost great. For most of its frequency response it’s decently balanced, but that narrow, intense treble resonance makes it fatiguing in a way that’s hard to overlook—and difficult to correct reliably.
If you’re extremely tolerant of treble peaks—or comfortable doing detailed, channel-specific EQ work—it might still appeal to you. For everyone else, there are smoother options in this price range that are easier to live with long-term.
Final scores:
Sound Quality: 4/10
Overall: 4.3/10
This is a companion discussion topic for the original entry at https://headphones.com/blogs/reviews/hifiman-ananda-unveiled-review-one-big-problem
