This is the place to discuss all things to do with the HiFiMAN HE1000 Unveiled:
I’ve posted my impressions of it in a different thread already so I’ll add them here, along with the measurements.
B&K 5128
Raw
GRAS & HpTF Variation
Folks know that I hate the ‘unveiled’ concept, but on this one the implementation is a lot less anxiety-inducing. There’s actually a lot less surface area of the membrane exposed to the world compared to the Susvara Unveiled, meaning it’s less likely to get punctured by various things one might have lying around.
As far as the sound quality is concerned, this one is one of the more balanced egg-shaped HiFiMAN headphones out there. It has noticeably less treble compared to the Arya platform, and even the HE1000 platform. So the ear gain is kept in line a bit better with the rest of the response. Also importantly the typical HiFiMAN midrange dip around 1.5khz is a lot less here than on their other models.
I liked this headphone a lot, especially with binaural recordings from Allison Krauss that they had there (this is a wtf experience if I ever had one, my goodness). If I had one critique it’s that for me there might be a bit of excess 4khz, causing a kind of ‘clenched’ presentation to certain tones - but it’s really a nitpick since the rest of it was quite balanced.
If you can handle the ‘unveiled’ concept, I could see this being someone’s endgame headphone - and they also improved the more modal response of this series (the jaggies in the midrange are lessened), so it’s a great platform for some EQ as well.
EQ
You’ll note some extra treble peaks up there still, I could’ve gone a bit further here but this ended up sounding decent enough to me and I don’t want to use my HRTF to prescribe adjustments for other people. So you’d need to do that by ear. Remember that headphone behavior, especially in the upper frequencies, will shift from head to head.
The information below is far less impactful for sound quality, do not try to read the tea leaves from these metrics
Harmonic Distortion
95dB
100dB
105dB
This result is better than many moving coil headphones but not as good as what you find with certain other planar magnetics. Note that these large ovoid planars from HiFiMAN typically don’t have the best harmonic distortion performance.
It’s still below audibility at normal volumes and you won’t have any trouble making adjustments with EQ. The only thing to note here is that when you crank it, you do see some 3rd and 4th order products showing up, but it’s still below 0.5%.
Driver Fs:
This shows driver behavior when seal is broken. So no worries if you have glasses or don’t get perfect coupling.
