Nice. I went to the site and didn’t see an ETA listed. Hopefully they stay with that if that’s what you saw or were told.
Edit: I see Kitsune has it in stock.
Though they’re built as ordered.
THIS IS Special Order item - each RED DDC is built to order and once ordered the process begins and a typical production time is around 4+ weeks. Currently shipping is estimated 4-6days for shipping. Please agree to these terms or cancel your order now.
I’m curious as well but I’ve already built the use case to keep both. The Bliss has the preamp aspect that I can use for my Aeras and Stellaris. The CFA has both headphone and speaker outputs, so I can use it with headphones, speakers, and interface boxes. I could see a case where I end up selling the Bliss and getting a Serene instead. Time will tell, or it won’t.
I took off the bass shelf and left straight convolution only and it’s hitting the spot tonight. Brain burn, unit burn-in, mood?
First night, 3.3 db
Second night, same
Third, none
4th…
I’m guessing the higher output impedances on the 6.35/4.4mm connections are there for short protection. But if using IEMs for example and concerned about OI you could just grab an XLR to 4.4mm adapter and use that.
