@Torq Isn’t great that we all have options to achieve the desire outcome! Audio is like a braided stream, multiple ways to navigate downstream. Thanks for the dialog! All the best…
Anyone have any idea why with the Holo Spring 3 KTE I can get it in run in Exclusive Mode with the ASIO Drivers but I can if Wasapi?
All other DAC work in Exclusive mode by default using ASIO drivers but the Holo Spring doesn’t. Only works in Exclusive mode if I turn it on in Wasapi drivers.
Not sure if it matters a lot … as ASIO bypasses the Windows Mixer anyway, and unless you assign another device to the same ASIO output it’ll be effectively exclusive.
Don’t know why it is different to your other devices; could just be the driver itself.
