…goes back to amazon.ca. Unfortunately, this was the very last.
Update: hmmm…or should I keep them. Channel balance is not great, though.
Fascinated by this thread-- it had never occurred to me that there might be interesting headphones available on AliExpress, and I appreciate all the scouting everyone here has done.
There is a part of my that twinges a bit at seeing headphones that are “heavily inspired” by companies like Campfire-- but I don’t think the markets between $50 and $500 headphones overlap that often.
Definitely tempting to roll the dice on a pair of KZs.
Get the ZSN. Its $20. What do you have to lose?
Granted, I am enjoying the $20 Focal Spark too.
I concur: the ZSN has a very refined sound (compared to other KZs such as even the much more expensive AS10). And it is literally quite a handful: very well built with a great symbiosis of metal (faceplate) and plastic/resin (rest of earpiece). Cable is great, too.
The ZSN has better haptic than, let’s say, the Brainwavz B400 or UE900s.
@Jaethan: Here the classic intro to Knowledge Zenith Earphones.
Some “old” purists still treasure the $5 single DDs such as the EDR1, EDR2, HDS1, and HDS3. I would never part with these.
@Brause @antdroid: you guys are a terrible influence, and I really appreciate it.
I’ll order some today-- as soon as I figure out what colour will sound best.
I assume you’re ordering the non-mic version?
Purple…purple sounds the best!
@Jaethan, your wallet can be glad for having missed the hype of the last few years – and the tens of models KZ and competitors have released in a short period of time. The craze with cheap multi-drivers started in early 2017 and the first classic, the ZS5, appeared a few months later…which is superseded now by the ZS7 (which I don’t have or intend getting).
As to colours: green sounds always good but “audiophiles” prefer a luscious brown or a fruity grey :-).
I used to order the mic versions but now, having a Shanling player, I rather go for the non-mic cables.
You guys are all sick. I’m buying 3 pair. One to keep if I like it, the other as gifts. I’m sure someone will want them. They have to be better than old Apple earbuds.
110% agree … if it’s available in purple, that’s always the version to get!
And if not, it’s just an opportunity for modding …
I have a recipe for 3 bean salad using one kind of beans and magic markers.
Yes, but what color are those beans?!
As long as you avoid the LH Labs Knockoffs there’s no need to feel bad! KZ at least has branched out from ripping off Campfire’s design on some models but it’s inevitable when companies source their parts from China there will be somebody that is willing to take the design and make something much cheaper. Grabbing a pair is a bit like having the appetizer before the main course!
Let us know what you think of them vs the Etymotics and Orions!
Purple, of course.
There are HFers that claim the purple one sounds better due to the different colored cable. I dont know if that’s true or not though.
Purple was tempting, but the silver metal looked “cheaper” in the photographs. Not sure if that holds in real life-- but the green ones will match my eyes.
@Jaethan…NOOOOOOOOOOOOOO…but…but…PURPLE!!
Great to hear. This guide defines you, @BenignScrambler. It was my first serious reading of Chifi and I still treasure it. At the time, I was just attempting to understand how such forums worked and I read your profile with pleasure…all the good “mysterious” iems and headphones you owned. It also made me order all of the early KZ ones that were still available…which I would never give away.
Hi B9Scrambler! Nice to see you here!
Nice guide too!
Below is my review of the CCA-C10. Let me know if I need to change anything to comply with forum rules.
INTRODUCTION/DISCLAIMER:
The CCA-C10 is an in-ear monitor with a hybrid driver configuration (1DD+4BA per side) that retails for approximately 28 at the time of this review. I purchased the C10 from the Nicehck Audio Store on AliExpress for .1 with the expectation of a fair and objective review.
SOURCES
I have used the CCA-C10 with the following sources:
Hidizs AP60II > CCA-C10
Windows 10 PC > JDS Labs The Element > CCA-C10
Windows 10 PC > Hidizs AP60II > CCA-C10
Xiaomi Redmi Note 4 Global > CCA-C10
Pixel 3 > Apple USB-C to 3.5mm dongle > CCA-C10
I have tested these headphones with local FLAC, Spotify Premium (256/320 kbps Ogg Vorbis), Youtube Music (256 kbps AAC), and Google Play Music (320kbps MP3).
PACKAGING AND ACCESSORIES
The CCA-C10 comes in a small rectangular white box. The box pictures the CCA-C10 on the front and gives the manufacturer’s contact information and technical specifications for the IEM on the back. Inside the box are the IEMs, a detachable .75mm 2-pin cable, 4 sets of eartips (1 generic black silicone, 3 KZ Starline-type [S, M, L]), a user manual, and a warranty card. The CCA-C10 does not come with a carry bag or case.
BUILD QUALITY / DESIGN
The cable is braided copper with aluminium housings for the 2-pin connections and a rubber L-shaped housing for the 3.5mm jack. The 2-pin housing have blue and red markings to indicate left and right. The cable has pre-formed ear-guides without memory wire. There is no chin-adjustment choker. The cable is very tangle-prone and seems to attract static electricity.
COMFORT / FIT / ISOLATION
SOUND
The lower mids are present and smooth without being either recessed or over-emphasized. Upper mids are more prominent without going overboard with presence. Detail retrieval is impressive for the price. There is a hint of sibilance on female vocals.
Treble is crisp, erring on the side of smoothness while still preserving an impressive amount of clarity. There is a good deal of air but not a ton of sparkle. Transients are convincing.
Imaging is realistic. Instrument separation is above average. Soundstage is wider and deeper than average.
MEASUREMENTS
AMPLIFICATION REQUIREMENTS AND SOURCE PAIRING
With a sensitivity of 108dB and an impedance of 32ohms, I do not feel the C10 benefits noticeably from dedicated amplification. The C10 does not hiss.
COMPARISONS
CCA-C10 (1DD+4BA) [$28] vs Yinyoo V2 (dual diaphragm biodynamic driver) [$49]
CCA-C10 (1DD/4BA) [$28] vs Yersen FEN-2000 (1 DD+1BA) [$24]
CLOSING WORDS
Despite a mediocre cable and accessory selection, the CCA-C10 represents a killer value for an entry-level hybrid, with good build quality, a balanced sound signature, and great detail retrieval.
