The Ultra Cheap IEM Thread
Impressions of the Earth-Budz, $14.99 on Amazon US.
Packaging - They use the “Semi” Environmental cardboard boxing that you see fairly often. A rough tan paperboard box with a clear film window & punch-out hoop to mount on a display peg. Inside are the ear buds and small + large tips in a white plastic tray. Basic for the price.
Build - The wood casing on the budz is nice. The cable is fabric covered with blue died hemp ( according to the sales liturature ) with metal clad plasitic fittings for the 3.5mm plug, microphone and cable split. The cable is mildly micro-phonic.
Fit - The included tips don’t allow me to get a good seal. I’ve settled on the smalls for now as they will seal with lots of fiddling. Their idea of small is closer to the mediums I have from my other buds & IEMs. Keep in mind that I don’t have the seal I want and will be experimenting with tips for these as I have time.
Sound - Listening was done with my LG K51 & NuForce uDac 5. Tracks used were from Star Wars : Empire Strikes Back soundtrack, Boston : Don’t Look Back & Enya : Shepard Moons all streamed from my ripped redbook flac library.
Bass is almost non-existant. I think this is mostly due to the flakey seal as I can substantially correct the issue by applying light pressure on the buds.
Mids are present and well defined.
Treble is abundant and can be overwhelming at times. This is from someone who LIKES treble, so take that with a caution.
Summary - The Earth-Budz are decent for the price. I have better sounding ear buds, the Moondrop Quarks for example, that didn’t cost much more. Toss them in the travel bag and hit the road.
Mark Gosdin
Unlike you, I obtained a perfect fit and seal with the pre-fitted tips and therefore got a good bass response. There is a decent sub bass rumble there. Mids are very well presented and the treble is well balanced with the rest of the range, of course you will have had a different experience if you did not get a good fit. I think these are amazing. There is a possibility that the Earth Budz model may be different from the Aydino version I have, the packaging is different.
Further to my last post, I found the Aydino/Earth Budz need a lot of power to perform well. After using additional amplification from my Topping NX1a the sound was transformed. My Sony NWZ-A15 on its own did not have enough power but the Xduoo X20 worked well, albeit at a higher volume setting than I would normally use. It seems extra power is mandatory with these.
AH! Neither of the two, my K51 or my uDAC 5, are all that powerful in the Amp section. I have a couple of other Headphone Amps that I can use that have much more juice to work with.
Mark Gosdin
OK. It will be interesting to hear your thoughts when you have more power and a good seal!
I continue to be amazed by the Aydino/Earth Budz. If you have them, check this track out, fantastic detail, timbre and soundstage:
Update : I moved the Earth-Budz to my FX-Audio DAC X6 Pro, more power, and could tell that they are now getting the Bass out more than what was present earlier.
Still I wasn’t getting the seal, so … I dug into the various extra tips that I have from the half dozen IEM purchases I’ve made. It ended up that the only ones that would fit on the somewhat large nozzle of the Earth-Budz were the extras from the Moondrop Quarks which also have a large nozzle.
With the Quark tips I finally got a good seal ( Pop! ) and playing thru the DAC X6 Pro the sound is much improved. Bass is now available in quantity matching the Mids. Treble was tamed some by the Quark tips, but can still jump up and tingle you. I’d love to see what a formal response curve would look like on these.
In any case I can recommend the Earth-Budz as a value buy with the note that you WILL want to tip roll until you get a good match. Not bad for $14.99, not bad at all.
Mark Gosdin
That’s good to hear. They are even better value from Amazon UK at £3.99 ($3.00)!
I keep checking the Amazon UK link you posted but it always says currently unavailable. Not sure if it’s because I am outside UK or if they are out of stock.
They don’t seem to exist on Amazon Spain.
Hello Senyor C
I just checked the link and they are apparently still in stock. Here is the link again:
Just ordered a pair of these. Seems a really silly price. Due for delivery on Wednesday so we’ll see.
Thanks, yeah, still shows “currently out of stock, we don’t know if these will become available again” for me. Must be because I am outside UK.
Great! I look forward to hearing your findings. Don’t forget to give them lots of juice. They really soak it up!
Not long arrived. The most bland packaging yet, but I’m not too fussed about that. I had to change the tips, the ones already on were dreadful and even changing to the larger size they were very uncomfortable and no bass at all. Put some RHA foam ones on that fit and still struggle to get them in my ears with any comfort and then after fiddling around they seem to settle.
Once the foam tips were on these make a nice sound. still a bit bass light for me but the bass is there and well defined, the treble is fine but at the moment these all seem about the mid-band which is quite warm and relaxed and quite pleasant. I’ve only had them on for some youTube favourites going through a Topping DX3 Pro for now but later tonight when it’s a bit quieter I’ll try them on the Mojo and RME.
Not totally convinced about the build quality but sonically, early impressions, are these are good, relaxing and a little safe sounding but then there isn’t really much you can buy for £3.99 delivered here in the UK so it seems it maybe difficult to be heavily critical. I look forward to giving them a more intensive listen later.
Good, I am pleased you like them. Do try a bit of tip rolling to get a good seal, the bass does improve a lot.
Here’s an interesting one:
Senfer DT6 MAX
No idea what is sounds like but at least it looks better than the original!
Well, I have one on the way. I will post my impressions as soon as I can. The DT6 original sounded good and the DT6 Pro improved on it in most areas except staging. I’m hoping for something like the MT300 sound! The packaging is very similar to the MT300, great accessories including 2.5 and 4.4mm adapters.
Senfer DT6 Max
The DT6 Max arrived. It is burning in. After 36 hours the bass, which was a bit overpowering, has become nicely in balance with the rest of the range. This is a very good IEM. Bass is solid and tuneful, somewhat north of neutral, no bleed. The mids are well presented, slightly recessed but becoming more forward with frequency. Treble is very extended, detailed and smooth with excellent levels of detail. Soundstage is very impressive being very wide with good depth and height. Separation and layering are very good, especially with electronic music. At the current price of $39 on Ali Express they are a bargain. Amazing packaging and accessories as well.
Ikko Opal OH02
After some time away from my review desk and a series of mini reviews, I am finally back to my normal set up and it is time to start making my way through a few things that have piled up while I was away.
The first on the list is the Ikko OH02 Opal, a set of IEMs that has been kindly sent to me by Hifigo in exchange for me publishing this review. As usual, the only request has been that I include links to the IEMs via their website, therefore my review will aim to be as unbiased as possible, although it is always good to consider the fact that these IEMs have not cost me anything.
You can find the (non-affiliate) links to the Opal by visiting the version of this review published on my blog here.
Presentation…
Starting off with how these IEMs arrive, I must say that the packaging and contents are quite impressive and are certainly original, moving away from the usual way in which IEMs in these ranges are usually presented.
The box itself is large and colourful, as you can see in the image above, with a sleeve that has a shaped cutout to allow the artwork to show.
Inside the box we get the IEMs, as is to be expected, placed in a foam cutout that also includes an Ikko branded pin in a combination of gold an black. Personally I have no use for a pin but I always mention unexpected contents and I don’t think I have ever received a pin with a set of IEMs before.
Also in the box we get a cable, which I quite like except for the black covering for the pre moulded ear shape (which detracts from the nice aesthetics of the cable in my opinion) and the fact that they use MMCX connectors. To be honest, the MMCX connectors seem to be of good quality and look like they will last fairly well, but I guess MMCX is just a personal phobia of mine.
Also included is a leather (imitation?) carrying pouch that is also different to any other pouch or case I have received in the past. It is actually more of a pouch that I would use for other things more than IEMs, and is closed by means of a leather string that wraps around the pouch. I can’t say that it is a great solution for IEMs but again, they deserve points for originality.
The last thing to mention as far as contents, other than the documentation that is in a nicely branded envelope, a couple fo replacement filters and a cleaning/MMCX extraction tool, is the amount of tips included. There are a lot. I don’t think that this is the most tips I have ever received but it is certainly the largest selection of uncommon tips I have received. As the nozzles are oval in shape (I’ll mention more about that in a moment), there is also a large selection of oval shaped tips included, with one set that is possibly the largest I have ever seen, along with a selection of hybrid foam/silicone tips. In total there are 9 sets of tips, so there should be something for everyone, well, maybe everyone except me, more on that in the next section.
Build and aesthetics…
As far as build quality, while all plastic (or at least I think they are all plastic), they do seem to be decently made and I see no issues with the build at all.
In terms of aesthetics, in my opinion they are also good looking. The set I have received are a dark green colour, with a small transparent green tinted window that shows a circuit board below. As with the packaging, the aesthetics are original enough to be different but without being so off the wall to look strange.
When it gets to comfort, here I wasn’t quite as lucky, at least with the included tips. As the nozzles are oval, as I mentioned above, they have also included oval shaped tips. In my case, no matter which way I tried to orientate the tips, and no matter which size, I never felt that I could get a proper seal and they never felt overly comfortable. The result with some of the other tips was better but still not something that I enjoyed too much. In the end, I opted for Azla Crystal tips and these solved the issue of seal but I still didn’t find them overly comfortable.
The angle of the nozzle just seems to be a mm or two away from matching my ear anatomy and I always feel like they are putting pressure on the front of my ear canal. I will say that they are very light though, so there is no sense of fatigue from weight, even after long sessions of many hours, just that little issue with the pressing on my canal.
Obviously we all have different ears and this is only an issue for me personally, I imagine that these will be extremely comfortable for most people.
Sound…
As we are back to my normal review format, I will mention that, as with all of my normal reviews, each track mentioned is a clickable link that will allow you to open the song in the streaming service of your choice. The measurement of these IEMs can also be compared with any other IEMs I have reviewed here: https://achoreviews.squig.link
Starting, as usual, from the lowest ranges, the Opal have quite a roll off in the subbass, however, due to a fairly boosted midbass range, they never seem to be lacking in the low end. If isolating the lowest notes, then yes, the roll off is noticeable, but I can’t say that it is something that I notice while listening normally.
Into the midbass, here there is a boost that does make itself the centre of attention in the low end. The mid bass is controlled fairly well and actually works ok for a lot of modern pop music, such as “Get Lucky”, but when moving to more acoustic focused music, I feel that the midbass focus makes it seem a little unnatural. Even with electrical based instruments as the focus but with simple songs, such as “Crazy”, I find that it is a little too present. In the case of this specific song, it causes a sensation of reverb in the midbass of the electric guitar and I can’t say that it sounds very natural.
Moving into the mids, there really isn’t too much bleed due to the fact that the midbass is fairly well controlled, meaning that while it is very present, it doesn’t interfere too much with the mid range. There is a slight dip in the centre of the mids and while the higher midrange doesn’t climb as much as it does on many other set, the vocals stay present for the most part.
I say for the most part as, depending on the instruments in play, the midbass boost can become a little overpowering and make the voices suffer a little to be present on certain tracks. This is something that I experienced on a lot of hip hop, such as “Bang Bang” for example, where that midbass can make the instrumental sound impressive but make the vocals seem to struggle.
One thing I will say is that voices do not come across as harsh, even “Don’t You Worry Child” is quite smooth in the vocal range (a track that I find harsh on a very large selection of IEMs).
Moving into the treble, there is actually quite a decent job done in this area to compensate for that midbass boost and not make the overall sound seem dark. There are occasions on which I find certain tracks to also be a little unnatural in the higher ranges but in general I feel that a good job was done to balance out the highs with the lows without becoming overly harsh in the upper ranges either.
The sensation of air and spaciousness is not bad, considering the low end boost, and while the soundstage is not large, more towards intimate I would say, it still doesn’t seem too cluttered, with things having space to breathe.
Last of all, detail. I don’t think that these can be considered highly detailed IEMs, yet they still manage to give a sensation of everything being in its place. I wouldn’t pick up these IEMs to find small nuances but at the same time, I feel that they can be enjoyed without the sensation of things missing.
Conclusion…
The Ikko Opal OH02 is its own thing. From the packaging, to the aesthetics, to the sound, everything is different to normal but not so different it is “off the wall”.
As far as sound, it’s like an IEM that manages to be V shaped without actually being V shaped. Depending on your choice in music, that midbass boost will either be very impressive or irritating. If you enjoy vocals on hip-hop, or on bass heavy RnB, then that midbass does get in the way. I also feel it can be problematic with some of the simpler vocal/instrument tracks. However, when moving to more modern pop, it can actually be the opposite and work quite well.
At a price of less than 80€, I feel that you are getting a good deal on these IEMs considering everything you get, but the sound signature will not be for everyone. They by no means sound bad, they are just different, and whether that difference is for you, only you can decide.
As always, this review can also be found in Spanish both on my blog (here) and on YouTube (here).
