How do you generate this? Can you give a quick guide?
Iām a real newbie for Eq⦠can someone help me to create a similar curve in the Roon parametric EQ? Working on it so far looks like a dogās breakfast⦠
Iām working on a new EQ profile at the moment for mine - for those who have it, let me know if this is a better treble balance on yours.
Something that might be difficult to identify when looking at the measurements is that there may actually a 9khz peak thatās difficult to identify visually, followed by the 10khz dip that you do see. Now⦠to an extent this is all just concha interaction and it could be that itās just shifted towards 10khz, since the expected anthropometric pinna dip doesnāt always show up in the same place. But given that thereās some indication of a peak there, my goal with this is to make the treble overall slightly smoother, without drastically changing level.
Another thing is that the 5.8khz peak that shows up on the graph may not be as significant in reality as it looks - either that or itās quite well balanced by some upper treble harmonics, like maybe the stuff you see around 12khz. In any case, I think this may be another example of fixing one issue may potentially reveal others, and so I had to go down the rabbit hole a bit playing whack-a-mole. Ultimately it led me to make a few fine-grained adjustments in the treble, but also remove a number of earlier adjustments in the lower treble. So if you guys are able to try it out, let me know if itās an improvement, or if you hear the lower treble peak⦠because I sure donāt at the moment.
The main thing to listen for would be vocals, where the āSā tones come across strongly. This new profile sounds a bit more focused to me for those tones.
Is this still needed? Been away for awhileā¦
Hi Resolve
I run my headphones with a (fantastic) RME ADI-2 Pro FS R which āunfortunatelyā has only a 5 band parametric EQ. Is there kind of a logical scheme to adapt EQ settings from e.g 10 to 5 bands? Just skipping each second setting might be tempting but I believe it isnāt the right way. Any suggestions?
Curious question⦠why do you use such a low number on the preamp setting⦠when I play music and watch the Peak Value Meter I donāt see any clipping⦠but with such a low preamp number it makes you push the amp harder because you end up pushing the volume knob higher than it needs to be⦠not a big issue but just wondering⦠so with the ifi Diablo that has a analog volume control I like to keep the volume at around the 12 oclock setting, keeping the pot out of any potential mis balance⦠so with the gain on the lowest setting, volume knob at 12 oclock the pre amp setting is adjusted at 2⦠I see no clipping⦠not even close and it lets the amp reserve power for dynamic music passages⦠am I seeing it wrong ???
This may be due to digital volume being lower as well, or at least that would amount to a similar lack of clipping. The main reason to go lower is so that you ensure it wonāt with all your music. As I understand it, music isnāt all the same for dynamic range.
I have never actually played with the preamp setting⦠interesting as I was playing with the setting and to just see what it would sound like I moved the preamp to -30 and the rest of the adjustments to your EQ ⦠it changes the characteristics of the headphone⦠there is more body and slam when I put the preamp at -30, adjust the gain to the upper position (high) on the diablo⦠the volume knob at 2 oclock and the XC is amazing soundingā¦
Hey,
Iāve been messing around with eq on LCD-XC. I just want to disclaim that I am totally new to the hobby, but Iāve found a signature I like. Itās a simple 10-band EQ. If anyone has time to look at it, please do, take a listen and tell me if with this EQ i am losing something significant? Because at this point I feel like the sound is much fuller.
Thanks,
Milosz
@Resolve ⦠is there a video or article describing the equipment/software required to take the in ear frequency graphs you use when EQing⦠would like to measure both over the ears and in the ears units so I can dial in the EQ betterā¦
thanks in advance
We use an industry standard GRAS 43AG-7 with RA0402 coupler and KB5000 pinnae. The cost of entry to this stuff is upwards of $10k on the low end, so itās far too expensive to acquire for personal use. For in-ear headphones, however, there are some knock-off couplers that do a pretty good job of replicating the GRAS 0045 ear sim (the older one) that can be had for much less. I will say though, thereās not much point in doing that since you can just look at the frequency response from one of the many folks out there who have databases.
The reason for this is that youāre applying more gain at the amplifier stage, and more gain sounds punchier and more aggressive. When you manipulate digital gain, youāre not manipulating any of the complex interactions, impedances and curve of the analog section that actually powers the headphone. Youāre just getting a pure volume cut.
Itād be like having two faucets - one that sprays water at a consistent pressure no matter how much you turn the handle, and another that sprays harder the higher you turn it up, and loses pressure when you turn it down low. Letās also imagine you were running the first, very consistent faucet into the second, less consistent but potentially more powerful faucet. If you were to turn down the first faucet, you would need to turn the second faucet up to keep the same amount of water flowing. However because the second faucet increases in pressure as you turn it up, you end up getting the same amount of water but more pressure because the curve of the second faucet is affecting your final output.
Excuse my crummy fluid dynamics metaphor, but the principle is essentially that - the gainstage actually running the transducer will sound different than a digital volume boost or cut.
This does sound better to my ear. I hear the peak a little higher, around 9.75khz on my unit/ears. Nudged those frequencies up a bit and brought down the ~10khz bump a little, think I have a new daily driver EQ.
Big fan, keep up the great work
I normally use Jriver for playback and it has its own EQ⦠so you just type in the parameters and save it then it works only with Jriverā¦
Not knowing a whole lot about Peace EQ I down loaded it yesterday and installed it on my laptop⦠went and put in everything from Resolves EQ example and it all seemed to be easy⦠this morning I booted up the lap top and for what ever reason I could not get Peace EQ to work at all⦠so after a search I came upon this on redditā¦
You donāt have to reinstall it, just follow these steps:
- Open Peace Settings
- Go to Debugging and Testing
- Click on Equalizer APOās Configurator
- Check the Troubleshooting options (only use in case of problems) box
- Choose the device by clicking on the name next to its checkbox
- Click on the drop down menu in the bottom right, then choose Install as SFX/EFX (experimental) , then hit ok
- Restart Windows and youāre good to go!
It now works perfectly with windows 11⦠hope this helps someone else with this issueā¦
Hey mate, Iām a total newbie. Is this the correct way to set your EQ parameters in Roon you reckon? My curve looks very different to yoursā¦
You have āBand 5ā as āHigh selfā, I think thatās meant to be just a Peak/dip.
I just applied Resolveās profile.
Just WOW⦠thanks so much!
Iām new to editing EQs, so does anyone have Resolvesā EQ presets, just with a big clean bass lift in it? I thought the closed backs would have a bit more bass.
Figured Iād share this here since everyone is asking for EQ profiles. Once again the point is that theyāre a starting point at best, and you have to use your ears to dial it in.
Thank you Resolve for making that content and taking the time to post it. Iād like to reiterate that Iām new to this and didnāt realize that using the low shelf at 100hz to adjust gain values would be sufficient, just due to my ignorance on how low shelf filters worked. Baby steps and all that.
