I ordered them as soon as they became available, and I’ve been switching cables back and forth all day.
My dilemma is that I just recently got the Meze 109 Pro, which not only sound great but are also well built, comfortable and just overall awesome.
Trouble is, the Aune AR3000 sound just as well, maybe even that extra bit better. I lack the words of a professional reviewer, but they have that extra bass punch, and seem somewhat airier.
Listen to the same songs on both and compare. Then, dedicate individual time which each; no limits, just time spent enjoying each headphone however you choose. Your heart and gut will tell you which to keep.
It can be difficult to decide between two headphones, especially if they have a similar sound profile or are EQ’d to the same target. It takes time. Don’t be in a hurry unless you need the funds soon. You may end up using one for one genre and the other for another genre.
I intend to check the Aune AR3000 out in the next few months and post my impressions here.
Got mine yesterday. I can say for certain that they are tuned exceptionally well. Only a few filters were needed to make the headphone darn near perfect for me tonally. Only notable features for me were a narrow dip at 6k and a peak at 10.5k. Great bass without distortion, good tonal balance, if not a little bright-tilted for me.
Personally, I will probably be returning them. Although they sound better tonally out of the box than my 6XX with a more modern, fuller bass profile—there are significant issues for me in terms of comfort and consistency. Comfort is self-explanatory, I’ve tried plenty of headphones and the 6-series chassis just feel weightless on my head with a Capra strap. These are just too bulky with too little clamp force for my liking. Additionally, they look sillier on video calls than my 6XX. They also move around a lot on my head which is unfortunate because of my other issue with these cans.
That issue being consistency. If you look at the 5128 measurements on graphworks, you can see that there is significant seating variation between 1-2kHz. I feel like this is understated by all of the reviews that I have seen for the product. If I move the left headphone back a little bit, suddenly the entire center image shifts to the left, and vice versa +/- ~3dB (can you imagine a 6dB channel imbalance throughout the mids in the worse case?). This is presumably due to the tilted driver. I need to expend energy keeping the headphones perfectly centered on my head as not to collapse the entire soundstage to one side. Additionally, if I move the headphones too far forward, the mids become scooped in the same region.
The low clamp force along with the seating inconsistency makes the EQ’d AR3000 sound less natural and stage-y than my EQ’d 6XX despite having a more natural out-of-the-box tuning overall that works better for my head when properly seated. I really wish this wasn’t the case because I absolutely love the bass, mids, and treble on these headphones.
Here’s what I would suggest for you if you wanted to maximize your long-term enjoyment presuming you use EQ. If you were to only choose between the 109 Pros and and AR3000 as a daily driver, choose whichever headphone works in the areas that cannot be changed with EQ. If the consistency issues that I wrote about are not a problem for you, disregard that and choose based on comfort. I’m interested to hear if anyone else finds these issues as detrimental as I did, or if I am just particularly anal about this kind of problem. Maybe I just have a small head and this is more of an issue for me than others? I do find that the 6XX works on my head with very little need for extension of the arm mechanism.
Edit: The seating problem can be partially aided by ensuring the front of the pads are well-compressed to the sides of your head. Still, this design doesn’t completely fix the issue relating to seating variation if you are moving around in them or head-banging, and they still don’t just fall into place like the 6-series design.
