New tube… I have a couple more on the way …so begins the tube rolling rabbit hole…
Did this change the noise issues you were experiencing?
Actually the noise turned out to be a ground loop with my mechanical keyboards LED lights…as soon as I turn those off, both my tube amps are pretty silent! The Cayin though with the Cayin stock tubes are pretty “noisy”…so I’m looking forward to getting my new tubes for it.
This RCA is nice…it did change the sound it seems brighter, with less low end. But I would need to do some more A/B testing.
It’s probably more that the tubes (or other elements of the circuit, but probably the tubes) are picking up the radiated switching noise from the PWM drivers for the RGB LEDs in your keyboard then. A ground loop would have to come via what they’re connected to, i.e. the PC/Mac, unless the keyboards have their own PSUs.
Regardless, I’m glad you got to the bottom of it!
ha yeah, it was process of elimination. I determined it was the keyboard, then tried seeing what would happen if I turned off the LED backlighting…and voila! no more buzzing! it is connected via USB B-C into the Mac Mini…
I now need to research PWM drivers and get myself learnt! I kind of want to go back to school/tech school for electrical engineering…it is fascinating! Too bad I dislike math… damn my brain
PWM is pulse-width modulation.
The hardware that drives RGB LEDs rapidly switches each of the individual R, G and B LED elements on and off to mix the appropriate colors. The relative on-off duty cycle for each color is what drives their relative intensity/brightness. More off-time than on-time results in a dimmer appearance for each color respectively.
So while software tells the hardware what the PWM cycle is for each color channel in each LED, it’s the hardware LED driver we’re talking about here. It is what it is.
USB-C, which implies USB 3.x, is also rather noisy. Early implementations were sufficiently bad that they could knock 2.4 GHz WiFi base-stations out of comission if placed too close.
Yeah I’m having issue with my Magic mouse and lag, and I’m pretty sure it might be this 2.4GHz noise causing it.
That’s probably something else.
I’m using a Magic Mouse (V2 … which given when you got your Mac is what you should have) in the middle of a bunch of USB 3.0 and 3.1 (mixed connector types) stuff, and it’s 100% non-laggy.
Try unpairing it and then re-pairing it.
How far is the mouse from the Mac Mini?
What’s between the mouse and the Mac?
Excuse the mess…and cable management… trying to figure out a better way of routing the shared DP port between my two computers.
Predicition … get that Mac mini laying flat, with no metal between it and the mouse, and your mouse-lag issues will go away.
But…but it looks so cool like that
I’ll try it tonight! After the lil beast monkey goes to bed
Crack Birthday Sale!
up to $125 off starting Friday, March 1st
https://bottlehead.com/?product=crack-otl-headphone-amplifier-kit
Oh boy it’s finally time! I’m giving the Crack with Speedball a first listen.
Running a Winged Thomson CFS Power tube with a Psvanne 12au7 [only 9 pin I’m familiar with]
An going to listen on the HD 800 first then move to HD 600
Ahh spoke to soon! It’s DOA <.< an no time to repair atm :[
What is your source for the Cayin? See headphones.com has it now and it’s so purdy. Wondering if it will add more color to the Clear.
I use my RME ADI-2DAC … But I intend to use the Massdrop R2R (if it ever ships lol). Be aware the Cayin like most/all tube amps benefits from some tube rolling, the stock tubes are fine, but you can get better ones. Also tubes take a long time to break in, and you will get “pings” that are audible…even when they are broken-in. Hopefully that didn’t scare you away, because I truly enjoy the Cayin, it looks awesome, and sounds good to me.
And source for music?
Ha, oops, I use Spotify premium, Qobuz studio, and FLAC files…sometimes I’ll hook up my record player also.
Oh man!! This adapter and tube has gotten rid of all noise except for when volume is maxed! 6SN7 adapter with Tung Sol 6SN7GTB tube… I think I like it a lot…now to find a cover for the adapter lol
Edit: I’ve been listening to this for the past couple hours and man…I am really digging it, less fatiguing then the stock 12au7…or the Tung-Sol 12au7 I had in it. I think it needs some more burn in but so far it is really good to my (imbibed brains ear receptors ).
After destroying a EC ZDT Jr this morning… I decided to upgrade my BHC with speedball (I needed a win after the EC fiasco)… First stage done.
So begins the final phase…
How did you “destroy” the EC ZDT Jr?
I ask out of a) morbid curiosity and b) just in case it’s something that can be fixed.
Good luck with the Speedball! Will be interested to see what you think with that installed.
