Can We Make HD 800S Sound GOD-TIER in 5 Minutes? - EQ Profiles & Discussion
We did a video where we tried to EQ the HD 800S to sound as good as possible to Andrew in 5 minutes with no help from typical EQ tools like AutoEQ or dynamic visualizations that show the results. If you want to check out that video, you can watch it here: Can We Make HD 800S Sound GOD-TIER in 5 Minutes?
The profiles we made are posted below!
Profile 1 (Cameron):
LS 75 Hz +1.8dB Q: 0.8
PK 150 Hz -1dB Q: 0.8
PK 3000 Hz +2dB Q: 0.8
PK 8000 Hz -2.5dB Q: 1
Profile 2 (Oratory1990):
LS 40 Hz 3dB Q: 0.6
LS 100 Hz 4.5dB Q: 0.707
PK 210 Hz -2.2dB Q: 0.9
PK 1000 Hz -0.9dB Q: 1.41
PK 2100 Hz 3.8dB Q: 0.9
PK 2600 Hz -1dB Q: 4
PK 5400 Hz -3dB Q: 6
PK 6100 Hz -2.5dB Q: 5.5
HS 9000 Hz 1dB Q: 0.707
PK 11000 Hz -3dB Q: 6
Profile 3 (Griffin):
PK 20 Hz +3dB Q: 0.3
PK 270 Hz -4.5dB Q: 0.3
PK 6000 Hz -4.5dB Q: 1.41
PK 12500 Hz -3dB Q: 0.707
Great video, would love to see a version of this or at least a small post here for the focal clear. Love the out of the box sound signature but am curious what small adjustments could do to improve upon the kind of sound it is presenting. I have been having a weirdly hard time on my end finding one, and am not nearly proficient enough to do it by ear. Regardless keep up the good work!
Wish I owned the 800s , Konstantine’s High Q Changes are pretty interesting to look at least on paper
Very cool. I will give these a shot today
Since in the video you asked us for our HD 800S presets:
Preamp: -8.52 dB
Filter 1: ON PK Fc 20 Hz Gain 1.8 dB Q 1.4
Filter 2: ON PK Fc 71 Hz Gain 1 dB Q 1.4
Filter 3: ON LS Fc 82 Hz Gain 5.5 dB Q 0.6
Filter 4: ON PK Fc 190 Hz Gain -2.1 dB Q 0.7
Filter 5: ON PK Fc 5000 Hz Gain 2.4 dB Q 0.5
Filter 6: ON PK Fc 5900 Hz Gain -6 dB Q 2
Filter 7: ON PK Fc 7800 Hz Gain -2 dB Q 5
There should be a post in this thread with a Focal Clear preset.
Cool video - well done, guys. It would be fun to see this done again with a headphone most people hate in stock tuning form to see if it sounds subjectively “good” after EQ. Perhaps the HD 820 or Sundara closed.
Don’t tell me Konstantin actually came up with those four high Q filters, among others, in five minutes, one of them for a 1 dB change too. That’s mad skills for sure.
Would have to watch the vid again, but I think the Oratory1990 filters probably came from his HD800S PDF presets here. That doesn’t mean he does not have god-like skills though. :slight_smile:
That’s all fine and dandy for the HD800S. But, what headphones are recommended which need NO EQ right out of the box? Trying to EQ my Verite open backs is maddening. Please send me links for EQing them.
I don’t doubt it. No sub-bass. No upper mids or air. And a nasty peak right where it’s likely to inflict the most pain at 5-6 kHz. Good grief, Charlie Brown! :slight_smile:
Probably has a nice warm sound though.
I’d suggest shelving filters for both the sub-bass and upper mids/treble. Or you could use one peak filter with a negative gain and a very broad bandwidth (low Q-factor) to reduce the lower midrange.
And use another negative peak filter to dial back the spike at 5-6k.
An FR plot on the HBK 5128 rig might make it somewhat easier to recommend a better and more precise EQ curve. I don’t see any around in the usual places though.
You’ll probably have to make due with the notch at 3k. It’s likely due to a cancellation effect. And probably can’t be fixed very well with minimum phase EQ.
Hopefully some of the ideas above will get you going in the right direction though.
Since you’re well above my price bracket, I’ll leave most of the suggestions of more neutral headphones to others. It kooks like ZMF makes some better tuned headphones now than the Verite though. Focal, DCA and Meze probably also make some decent higher end headphones that may be worth a look.
There are probably also a few good options worth considering in the sub-$500 range as well. Some open headphones I’m looking at in this price range include the Sennheiser HD550, HD6XX, and HD490 Pro, Fiio FT1 Pro, HFM Sundara or Edition XS, and possibly the Moondrop Para/Para 2. the video below has some pretty good thoughts on these and more…
I loved this video! I wish Andrew could share his EQ profile for the HD800S as well if possible :folded_hands:t3::sparkles::headphone: thank you again for everything you all do!
I liked the video.
In my opinion, EQ makes the HD 800(S) one of the most compelling open-back headphone packages money can buy.
Generally, I vibe with the stock colorations of my 800 S on most tracks. Though, I prefer the HD 6XX or APP2 out of the box.
But, I have multiple EQ profiles for days when I want to hear something different. It’s great.
I use USB Audio Player Pro with dongleDAC for my Senn HD560S. I’ve fluctuated between 7-8 different PEQ profiles. For my own sanity, I’ve deleted all but 1 (autoEQ on Squig to Harman). I feel the call again from reading these discussions. Or to buy…..
@listener how would you modify this lovely EQ but for the HD800?
