Hey Everyone! I thought it would be a good idea to compile my EQ profiles into one place so that they’re easily available here on the forums for anyone interested in trying them out.
The EQ I apply brings headphones closer to my personal target, which is very similar to the Harman target. However, compared to the Harman target curve, it has a slightly lower bass shelf, a slightly cooler upper midrange (about 2-3dB less, varies per headphone), and a little more energy for frequencies above 10k (1-2dB more). I’d say it is generally on the warmer-sounding side of things.
The list will be in alphabetical order and organized by manufacturer (use drop down menu to see EQ profiles per headphone model). Headphones made in collaboration with DROP will still be listed under their original manufacturer.
I’ll update this list whenever I edit a headphone’s EQ, or when I’ve created a new profile. I hope you enjoy them! ![]()
Special thanks to @frkasper for helping me format the post so that it’s easier to navigate!
- 64 Audio -
EQ List
- Fourte -
Low Shelf at 75hz, +5dB Q of 0.7
Low Shelf at 700hz, -5dB Q of 0.7
Peak at 1500hz, +3dB Q of 1.41
Peak at 2500hz, -3dB Q of 2
Peak at 5000hz, -5dB Q of 4
Peak at 4500hz, -5dB Q of 5
High Shelf at 11000hz, -3dB Q of 0.7
- AKG -
EQ List
- K371 -
Peak at 20hz, -2dB Q of 1.4
Low Shelf at 100hz, -2dB Q of 0.7
Peak at 8500hz, -4dB Q of 6
- Audeze -
EQ List
- LCD-1 -
Low Shelf Filter at 115Hz, +3dB Q of 0.7
Peak Filter at 2000Hz, +3dB Q of 1.41
Peak at 3000Hz, -3dB Q of 1.6
Peak at 7500hz, -2dB Q of 2
- LCD-2 -
Low Shelf at 85hz, +1.5dB Q of 0.7
Peak at 1000hz, -3dB Q of 2
Peak at 3000hz, +4dB Q of 3
Peak at 4000hz, +3.5dB Q of 3
Peak at 6000hz, -4dB Q of 3
Peak at 9000hz, +2dB Q of 4
- LCD-2 Classic -
Low Shelf at 85hz, +2dB Q of 0.7
Peak at 1000hz, -3dB Q of 1.41
Peak at 4000hz, +3dB Q of 2
Peak at 6000hz, -6dB Q of 3
Peak at 8000hz, +4dB Q of 4
- LCD-GX -
Peak at 30hz, +1dB Q of 1
Peak at 1000hz, -2dB Q of 1
Peak at 4500hz, +2dB Q of 2
Peak at 6500hz, -2dB Q of 2
- LCD-X -
Low Shelf at 80hz, +3dB Q of 0.7
Peak at 4000hz, +2dB Q of 1.41
- Audio Technica -
EQ List
- ADX5000 -
Low Shelf at 35hz, +3.5dB Q of 0.7
Peak at 125hz, -3dB Q of 1
Peak at 4000hz, -3dB Q of 3
Peak at 6000hz, -2.6dB Q of 3
Peak at 10000hz, -2dB Q of 2
Peak at 13000hz, -3.5dB Q of 5
- Beyerdynamic -
EQ List
- DT 990 Pro -
Low Shelf at 50hz, +2dB Q of 0.7
Peak at 150hz, -4dB Q of 2.41
Peak at 700hz, +3dB Q of 2
Peak at 3000hz, -3dB Q of 1.8
Peak at 6000hz, -4dB Q of 4
Peak at 8500hz, -8dB Q of 4
High Shelf at 11000hz, -7dB Q of 0.7
- DT 770 Pro -
Low Shelf at 65hz, -2dB Q of 0.7
Peak at 150hz, -5dB Q of 2.41
Peak at 4000hz, +2dB Q of 4
Peak at 6000hz, -4dB Q of 5
Peak at 8000hz, -3dB Q of 5
- DT 1770 Pro -
Velour Pads
Peak at 150hz, -6dB Q of 1.41
Peak at 3000hz, +3dB Q of 1.41
Peak at 6000hz, -2dB Q of 3
Pleather Pads
Peak at 150hz, -4dB Q of 1.41
Peak at 8500hz, -5dB Q of 4
- DT 1990 Pro -
Low Shelf at 100hz, +2dB Q of 0.7
Peak at 250hz, -2dB Q of 1.8
Peak at 2500hz, -1.5dB Q of 2
Peak at 5500hz, -5dB Q of 4
Peak at 8500hz, -11dB Q of 4
- T5P Second Generation -
Peak at 150hz, -6dB, Q of 1
Peak at 4000hz, -4dB Q of 1.41
Peak at 8000hz, -8dB Q of 5
Peak at 1000hz, -3dB Q of 4
- Dan Clark Audio -
EQ List
- AEON 2 -
Low Shelf at 100hz, +6dB Q of 0.7
Low Shelf at 300hz, -7dB Q of 0.7
Peak at 6000hz, -7dB Q of 3
Peak at 8500hz, -5dB Q of 2
High Shelf at 11000, -3dB Q of 0.7
- AEON 2 Closed -
Peak at 130hz, -3dB Q of 1.2
Peak at 300hz, -2dB Q of 1.4
Peak at 2500hz, 3dB Q of 0.7
Peak at 6000hz, -4.5dB Q of 4
Peak at 8500hz, -2.5dB Q of 6
High Shelf at 11000Hz, -3dB Q of 0.7
- AEON 2 Noire -
Peak at 100Hz, -4dB Q of 1.41
Peak at 2000hz, 1.5dB Q of 3
Peak at 3500hz, 1.5dB Q of 3
Peak at 6000hz, -2dB Q of 4
High Shelf at 12000hz, -1.5dB Q of 0.7
Peak at 14000, -4dB Q of 8
- Ether Flow 1.1 -
Peak at 150hz, -3dB Q of 0.7
Peak at 3500hz, +2dB Q of 2
Peak at 6000hz, -3dB Q of 4
Peak at 8500hz, -2dB Q of 3
- Final Audio -
EQ List
- D8000 Pro -
Low Shelf at 35hz, +2dB Q of 0.7
Peak at 1000hz, -2dB Q of 1.41
Peak at 2500hz, +4dB Q of 1.41
Peak at 4500hz, -1.5dB Q of 4
- Focal -
EQ List
- Celestee -
Peak at 2500hz, -2.5dB Q of 2
Peak at 3000hz, -1.5dB Q of 3
Peak at 5500hz, -3dB Q of 3
- Clear -
Peak at 1200hz, -3dB Q of 1.41
Peak at 4000hz, -1dB Q of 2
Peak at 6000hz, -3dB Q of 3
Peak at 9500hz, -4dB Q of 2
- Clear MG-
Peak at 1500hz, -3dB Q of 1.41
Peak at 4500hz, +3dB Q of 4
Peak at 6000hz, -2dB Q of 5
Peak at 8500hz, +3.5dB Q of 4.5
- Radiance -
Peak at 2000hz, -2dB Q of 2
Peak at 5500hz, +3dB Q of 1.41
- Stellia -
Peak at 1000hz, -2dB Q of 2
Peak at 2000hz, -2dB Q of 3
Peak at 4000hz, 4dB Q of 1.41
Peak at 6000hz, -2dB Q of 2
Peak at 8000hz, -1dB Q of 4
High Shelf at 11000hz, +3dB Q of 3
- Utopia -
Low Shelf at 100hz, +3dB Q of 0.7
Peak at 1500hz, -4dB Q of 2
Peak at 3000hz, -3dB Q of 4
Peak at 6000hz, -3dB Q of 6
- HiFiMan -
EQ List
- Ananda -
Peak at 200hz, -2dB Q of 2
Peak at 1500hz, 3dB Q of 2
Peak at 3500hz, -1.5dB Q of 2
- Arya -
Peak at 1500hz, +2dB Q of 1.41
Peak at 3000hz, -2dB Q of 3
Peak at 5000hz, -3dB Q of 3
Peak at 7500hz, -2dB Q of 3
- HE400SE -
Low shelf at 85hz, +4dB Q of 0.7
Peak at 7000hz, -3dB Q of 2
- Sundara -
Low Shelf at 100hz +1.5dB, Q of 0.7
Peak at 2000hz +2dB, Q of 1.41
Peak at 3500hz -2dB, Q of 2.5
Peak at 7000hz -2dB, Q of 2
- Susvara -
Low Shelf at 85hz, +4dB Q of 0.7
Peak at 1500hz, +1dB Q of 1.41
Peak at 4000hz, -2dB Q of 4
Peak at 7000hz, -1dB Q of 4
- Meze -
EQ List
- Empyrean -
Low shelf at 85hz, +3dB Q of 0.7
Peak at 200hz, -4dB Q of 2
Peak at 11000hz, -7dB Q of 0.7
- Liric -
Peak at 120hz, -2dB Q of 1
Peak at 2000hz, +1dB Q of 3
Peak at 6000hz, -2dB Q of 1.2
High Shelf at 11000hz, -4dB Q of 0.7
- Philips -
EQ List
- SHP9600 -
Peak at 130hz, -5dB Q of 1.41
Peak at 2000hz, 2dB Q of 1.41
Peak at 3000hz, -1.5dB Q of 2
Peak at 6000hz, -4.5dB Q of 3
- Rosson Audio Design -
EQ List
- RAD-0 -
Peak at 200hz, -2dB Q of 0.7
Peak at 6500hz, -2dB Q of 4
- Sendy -
EQ List
- Peacock -
Peak at 750hz, -2.5dB Q of 1.41
High Shelf at 2000hz, +2.5dB Q of 0.7
Peak at 3000hz, -3dB Q of 5
Peak at 6000hz, -5dB Q of 4
Peak at 8000hz, -4dB Q of 5
High Shelf at 12000hz, -2.5dB Q of 0.7
- Sennheiser -
EQ List
- HD 560S -
Peak at 5500hz, -4dB Q of 3
Peak at 8500hz, -1.5dB Q of 4
- HD 58X -
Low Shelf at 80hz, +2dB Q of 0.7
Peak at 150hz, -3.5dB Q of 1.41
Peak at 3500hz, -1.5dB Q of 3
Peak at 5500hz, -7dB Q of 7
- HD 600 -
Low Shelf at 85hz, +3dB Q of 0.7
Peak at 3500hz, -3dB Q of 2
- HD 650 -
Peak at 200hz, -3dB Q of 1.2
Peak at 3000hz, -2dB Q of 2
- HD 660S -
Peak at 150hz, -1.5dB Q of 1.41
Peak at 5500hz, -3dB Q of 5
- HD 800 S -
Low Shelf at 100hz, +5dB Q of 0.7
Peak at 5500hz, -3dB Q of 4
- ZMF -
EQ List
- Vérité Closed -
Auteur Lambskin Pads:
Auteur Hybrid Pads:
Eikon Lambskin Pads:
Peak at 5500hz, -2dB Q of 3
Universe Lamskin Pads:
Universe Hybrid Pads:
Peak at 5500hz, -5dB Q of 3
Vérité Lambskin Pads:
Bass shelf at 100hz, +3dB Q of 0.7
BE-2 Lambskin Pads:
Bass shelf at 100hz, +1.5dB Q of 0.7
I’m a mild purist (aka lazy and don’t like spending time EQ’ng things, would rather just listen).
