Good People, did anyone try EQing Final E5000 IEMs? I would like to know what EQ y’all using for the supposedly bassy IEM. ![]()
You could start with the values below and adjust the sliders individually to taste.
Preamp: -4.6 dB
Filter 1: ON PK Fc 31 Hz Gain -4.5 dB Q 1.41
Filter 2: ON PK Fc 62 Hz Gain -4.8 dB Q 1.41
Filter 3: ON PK Fc 125 Hz Gain -4.3 dB Q 1.41
Filter 4: ON PK Fc 250 Hz Gain -3.6 dB Q 1.41
Filter 5: ON PK Fc 500 Hz Gain 0.3 dB Q 1.41
Filter 6: ON PK Fc 1000 Hz Gain 0.8 dB Q 1.41
Filter 7: ON PK Fc 2000 Hz Gain 1.5 dB Q 1.41
Filter 8: ON PK Fc 4000 Hz Gain 3.7 dB Q 1.41
Filter 9: ON PK Fc 8000 Hz Gain 2.6 dB Q 1.41
Filter 10: ON PK Fc 16000 Hz Gain 2.5 dB Q 1.41
I use the Oratory values with the listed changes:
I reduce the 3080 value by -2.5 dB
I increase the 5500 value by only +3 dB
Helo. Does anybody knows how to put these settings for JamesDSP?
I have the Focal Celestee and the Focal Stelia.
Thanks so much.
Hello. What software would you recommend for Windows to equalize for my headphones?
Equalizer APO & Peace GUI. This is the way.
Completely agree. Free and easy to use.
Hello has somebody successfully equalized a Audio Digital Interface, specifically the Focusrite Scarlett. I have the 4i4 and it does NOT work. I tested other headphone connected to a normal 3.5 mm audio cable in a monitor, and it works great.
The equalizer worked on the XB32 device.
But not on the Focusrite Scarlett.
I tried the Monitor Outputs and the Headphone Output.
I have equalised interface’s in the past with Peace.
What are you playing back from (software)? Is it maybe set to Asio?
@SenyorC okay I was able to fix it. You have to select LFX/GFX
Looking for Hifiman he1000 Stealth EQ please
Any hope to get a EQ setting for the 660S2 maybe ?
Just listen and tweak to taste. Others may not have the same chain as you so theirs may not be what you like anyway.
