It most definately pairs well with my headphones. I have no inclination to change.
It really about will the Mojo deliver the current needed for A2C to get to the volume you want,
If you can support this you will be fine, 100 dB is loud, 85 dB average is plenty of volume
| Listening | Loudness | Voltage Needed | Current Needed | Power Needed |
| Safe | 85 dB SPL | 0.06 Vrms | 4.62 mA | 0.28 mW |
| Moderate | 100 dB SPL | 0.32 Vrms | 24.62 mA | 7.88 mW |
Hey everyone! So this post will be a little different than my usual ones, as it will be more of an impressions post, instead of a full-on review. In this post Iāll be talking about what my experience has been like so far with the Dan Clark Audio AEON 2 Open, which has been an interesting headphone to listen to for sure. Now, I will be posting a more detailed, full-review of this headphone later this week, but Iāll also be including a review and comparison with the AEON 2 Closed.
I suppose that as I would usually do, Iāll talk about its design and buildāwhich I think is great. Whereas most of the planar-magnetic headphones Iāve tried have been big, heavy or generally bulky (HiFiMan Sundara has been the only exception to this, really), the AEON 2 features a slick, lightweight, collapsable, and compact design. DCA also includes a very nice hardshell style case with the AEON 2, making them easy to carry around. Despite their small footprint, the AEON 2 is very comfortable. Its earcups have a unique shape, but they follow the human ear-shape very closely and the pads provide a good amount of room and depth, which allows for a good fit. Clamp force out of the box was pretty tight, but they did ease up quite a bit after about a week of use; I donāt think itāll really be a big issue. One thing I found sort of odd, however, is that despite being very portable, theyāre fairly hard to drive. The AEON 2 Open has been the only headphoneāaside from the HD 800 Sāwith which Iāve had to use the second gain stage on the Micro Black Label, and the High-gain mode on the JDS Labs Element II (thatās a lot of power!); so do keep this in mind if you were interested in them as a prospective travel companion.
Sound is where the AEON 2 Open is really funky. So, Iāll start off by pointing out some of the sound characteristics I like on AEON 2 Open. Its resolution I think is pretty good and about on-par with the HiFiMan Ananda; it offers a noticeable increase in clarity when going from something like the HD 660S and DT 1990 Pro. The AEON 2 Open, after EQ, has a presentation and timbre that actually reminds a bit more of a dynamic-driver headphone whilst still retaining the fantastic extension, and that controlled and tight-sounding quality that I like from planar-magnetic drivers.
Those, I think, are positive qualities of the AEON 2 Open. The problem, though, is that its stock tuning, and Frequency response doesnāt let you appreciate any of those qualities. Iād describe the AEON 2 Openās default tonality as V-shaped, but itās fairly awkward and sincerely off-putting. Now, it being V-shaped is not what detracts from the listening experience on the AEON 2 Open. The problem is that it is an extremely exaggerated V-shape with a rightward skew. This results in the AEON 2 Open having this really strange, harsh, boomy, congested, and undefined sound. I have given it a go with EQ, and I think I got it to sound pretty decent by toning down some of the more piercing regions in the treble and taming the bass, which was loose by default.
Seeing as this was originally a more V-shaped headphone, Iāve made two EQ profiles. One of them is closer to my personal preference target, which is fairly similar to the Harman Target, whilst the other one retains more of the headphoneās original Treble energy and bass warmth; albeit less piercing. The presets I came up with are these:
- AEON 2 Open āVā
Low Shelf at 110hz, +8dB Q of 0.7
Low Shelf at 300hz, -8dB Q of 0.7
Peak at 6500hz, -3dB Q of 4
Peak at 8500hz, -3dB Q of 3
High Shelf at 11000, -3dB Q of 0.7
- AEON 2 Open
Low Shelf at 100hz, +6dB Q of 0.7
Peak at 6500hz, -7dB Q of 3
Has anyone does a head to head comparison with the Aeon2 Open and the Ether2? If you have, how close is the Aeon2 to the E2 performance wise.
Dan Clark Audio AEON 2 Open/Closed Review and Comparison
Written by Chrono
The AEON 2 Open and AEON 2 Closed are portable, planar-magnetic headphones from Dan Clark Audio intended for audiophile listening. The AEON 2 Open and AEON 2 Closed both retail for $900 and are the successor to Dan Clark Audioās AEON Flow Open and Closed, and they feature improvements in their driver technologies that improve airflow, resolution, and dynamics.
The Amplifier/DACs used in this review were the ifi Micro Black Label and JDS Labs Element II connected via USB to my desktop computer. For the listening tests I used music from a wide variety of genres including Rock, Jazz, Classical, Acoustic, Hip-Hop, and latin. I played tracks from my own FLAC library as well as from Qobuz streaming service played via Roon (exclusive mode).
Power Requirements
Despite clocking in at an impedance of 13ohms, the AEON 2ās are rather power-hungry headphones. This makes more sense when looking at its sensitivity level, which is only 94dB/mw on the Open version, and 92dB/mw on the Closed. The AEON 2 has been the only headphone that has required me to run my ifi iDSD Micro Black Label in ānormalā (second gain stage) as opposed to āecoā (lowest gain stage). I highly advise that you listen to these with a discrete headphone amp, as listening to them straight from my MacBook made them sound compressed by comparison.
Whatās in the Box?
*Everything In this section applies to both the Closed and the Open version of the AEON 2
Included with the AEON 2, you get a couple of nice accessories. For starters you get what Dan Clark Audio calls their āDUMMERā cable that measures 2m in length and is made of a very nice, flexible fabric. For connections, the cable uses hirose connectors for the headphone side, and they terminate in 3.5mm for the amplifier side; a thread-on ¼ā adapter is also included. Also included is a custom-molded hardshell that is very compact and ideal for travel. Lastly, you get three different sets of filters that you can place in the insides of the cups to slightly refine the AEON 2ās sound to your taste by providing different levels of dampingāI will discuss their sonic changes more in depth in the sound section of the review.
Build Quality and Comfort
The AEON 2ās build is spectacular; both visually, and its construction. For a planar-magnetic headphone it is remarkably compact, lightweight (327g), and it also features a very good, collapsible, folding mechanism that further reduces its footprint. The earcups use a mix of metal and plastic, which gives them a light but very solid feel. The use of the metal alloy, nitinol, gives the headband a very durable structure all whilst remaining extremely light and flexible. I think the AEON 2 has one of the best builds and designs I have seen on a headphone, and I donāt really have any complaints about it; just very solid overall.
Comfort on the AEON 2 is also outstanding. The pads follow the shape of the ear, and whilst that makes them look a little narrow, I had no issues getting a good fit with them without touching the inner sides of the pads. They are also fairly deep, so I never found that my ears came in contact with the driver. The pads are wrapped in a very nice, protein leather thatāin my experienceāgenerated less heat build than I usually get when compared to lambskin pads. The only real issue I had was that the AEON 2 was a little bit on the clampy side, but they were definitely not as vicious as what you get with a Sennheiser HD 600-series headphone.
This is my first experience with Dan Clark Audio headphones, so I was not sure what to expect before listening to the AEON 2 Open and Closed. In each of their own, unique ways, the AEON 2ās really surprised me. Both headphones have similar traits, and the only visual differences are that the AEON 2 Closed has a carbon-fibre insert covering the area where the grills would be, and that the AEON 2 Open has partially-perforated ear pads. Yet, despite their similarities, one of these two nearly-identical headphones has me going āwoah, I like that,ā whilst the other has me thinking āwoah, I really donāt like that.ā
For this sound section, Iāll be discussing the tonality and technical performance of each AEON 2 headphone, drawing comparisons between them and also comparing them to other headphones around their price range.
I will start off by talking about the AEON 2 Openās bass because it is the more interesting of the two, and then I will cover the AEON 2 Closedās bass and how they compare.
I think that I would describe the AEON 2 Open as having a somewhat āV-shapedā sound signature, but with a rather exaggerated rightward skew. The AEON 2 Openās bass is remarkably overbearing; with a wide, mid-bass elevation at around 130hz in an excess of 8dB. This is undoubtedly one of the most problematic qualities in the AEON 2 Openās sound
signature as it makes bass notes sound very boomy, and bloated. Additionally, because it is a very wide elevation, the upper-bass bleeds severely into the lower mids and makes things like low piano, guitar and vocal tones between 250hz-500hz sound extremely congested and undefined. Now, detail in the bass is actually pretty good on the AEON 2 Open andāas expected from a planar-magnetic headphoneāit has fantastic extension that makes the bass sound very deep. However, I feel like those good qualities which the AEON 2 Open possesses in this region of the Frequency responses are easily shrouded by its bass tuning, which is simply out of control and makes for a rather muddy listening experience.
The AEON 2 Closed, by comparison, still has a touch of added warmth in the bass around 130hz, but it is a lot more subtle and tasteful; which I think makes it pretty enjoyable on some tracks, as it also adds a slight mid-bass punch without feeling like it really upsets any of the other frequencies in the mix. I still feel as though the upper-bass creeps ever so slightly into the lower mids, butāagaināis nowhere near the same level as on the AEON 2 Open. This, to me, was actually quite surprising because I expected the AEON 2 Open to have a more balanced bass response, but it was actually the closed-back version that performed better in that regard; and of course it retains the great extension and detail that its open-back counterpart can present. Overall, I think that both the AEON 2 Open (after EQ) and AEON 2 Closed have very good articulation in the lows, but I still found the HiFiMan Ananda, LCD-2 Classic, LCD-2, and LCD-GX to be a little more refined and well-defined in this region of the frequency response.
Midrange
Starting again with the AEON 2 Open, it sounds to me as though the midrange can easily get lost on the mix when compared with the elevated bass and treble. The congested lower-mid tones completely overpower the rest of the midrange, and makes it feel quite stuffy-sounding; vocals lack presence, electric guitars sound very distant, brass instruments lack their bite, and it generally just feels as though the only thing letting you know all these different musical elements are there is their overblown harmonics and overtones in the treble region. I personally find this to give the AEON 2 Openās sound a very off-putting and unnatural tonality.
The AEON 2 Closedās midrange is not perfect, either, but it is presented in a way that I find to be much more enjoyable than on the AEON 2 Open, and it never strikes me as sounding particularly unnatural. As I mentioned earlier, it is not affected nearly as much in the lower midrange, so it does not sound congested in the way that the AEON 2 Open does. The midrange on the AEON 2 Closed sounds to me like it actually has better body and substance than its open-back counterpart, although it does have a wide 3dB-4dB recession in the upper-midrange between 1.5K-5K, which which took away some of the presence for instrument and vocal overtones in that region of the frequency response, and made the mids sound slightly hazy and less resolving.
I find both the AEON 2 Open (after EQ) and AEON 2 Closed to have very good midrange resolution, but after using EQ on both models I actually find that it is the AEON 2 Closed to have the slightly cleaner and more detailed midrange. When compared to other planar-magnetic headphones in its price range, I personally find the AEON 2 Closedās mid range resolution to be particularly great, as I think it is slightly more resolving in this region of the frequency response than the LCD-2 Classic, Ananda, and it is only slightly edged out by the LCD-GX; which I think is very impressive for planar-magnetic closed-back headphone that is as compact as it is. I also thought it was worth mentioning that I personally found the timbre for both the AEON 2 Open and AEON 2 Closed to be surprisingly reminiscent of that of dynamic-driver headphones, which I thought made them sound a little more natural than its planar-magnetic competitors.
Highs
The AEON 2 Open and AEON 2 Closed have some common characteristics in the treble region, but their presentation ends up sounding completely different. They both have peaks at around 6K and 8.5K, but they are significantly more exaggerated on the AEON 2 Open. The AEON 2 Openās treble peaks are excessively accentuated, as they are significant in magnitude and are also fairly wide in their rise. This excess in treble makes the AEON 2 Openās highs come across, to me, as extremely aggressive, sibilant and piercing. Also, as I mentioned earlier, the overtones and harmonics in this region are blown unnaturally out of proportion, which makes vocals, drums, cymbals, drum strikes, and brass instruments sound harsh whilst also introducing a strong, sizzle-like quality. On the other hand, the AEON 2 Closedās peaks are much narrower, and smaller by comparison. The AEON 2 Closed had a bit of glare as a result of the 6K peak, and whilst it did not sound particularly sibilant to me in that region, I do feel as though it adds a slight emphasis to the upper-midrange recession that precedes. The 8.5K peak on the AEON 2 Closed can occasionally add a little bit of pierce and make some consonants sibilant, but it was not anywhere near as bothersome as on other headphones like the DT 1990 Pro or AEON 2 Open. One quality that both headphones had in common, however, was that to me it sounded as though they had a little too much air in the region above 10K, so vocals and certain instruments had a little too much of that upper treble glisten. This was not an offensive quality, but one that I thought I would point out as, to me, it sounded just a little bit unnatural.
For resolution in the treble-region, I think that the AEON 2 Open (post EQ) and AEON 2 Closed perform really well, and once again I find that the AEON 2 Closed actually delivers a slightly cleaner image of the highs. To me, it sounded as though both of the AEON 2ās were a little more resolving than the LCD-2 Classic, but still lagged slightly behind the Ananda, LCD-2, and LCD-GX.
This is an interesting set of categories, because both AEON 2 Open and AEON 2 Closed perform almost exactly the same. The AEON 2 Open is a very closed-sounding headphone, and has a very intimate presentation that feels only ever-so-slightly wider than the AEON 2 Closed. Dan Clark Audio claims that soundstage has been improved from the original AEON Flow models, but I cannot comment on that as I have never heard either of those headphones. Still, I can compare to other headphones that I have listened to, and I can say that they are very narrow in their soundstage width and they have a less spacious presentation than that of an HD 600-series headphone; so they are definitely a little underwhelming in their sense of width. Imaging on the other hand I think is quite good, I find that the AEON 2 is able to depict soundsā sense of direction extremely well and has no gaps; sounds are able to pan very smoothly from left to the center and to the right. Instrument separation and layering is also excellent. The AEON 2 Open and Closed play within a very small stage, but every instrument and element in the music sounds very well-defined and has its own, well-defined space. Overall, I really enjoy the soundscape that the AEON 2 Open and AEON 2 Closed present, as it is intimate without ever feeling cramped or claustrophobic.
Dynamics
The AEON 2 Open and Closed, unfortunately do not possess the most impressive sense of punch and slam, as Focal and Audezeās offerings both outperform in delivering that satisfying, physical sense of impact in the low-tones. Now, whilst things like drum kick impacts will not have as much weight on the AEON 2 Open and Closed, they are still able to very nicely reproduce that top-end attack behind drums, piano keystrokes, xylophones, and the tension of string instruments in a realistic fashion. Overall, whilst they do not have the most impressive, most engaging dynamics I still think they perform better than headphones like the Ananda and HD 660S; which I think is worthy of merit considering that the AEON 2 utilizes an extremely light-weight, single-sided magnetic array for their driver.
EQ and Filter/Inserts
As I mentioned earlier the AEON 2 Closed and Open both include a couple of different filters with varying levels of damping. The included filters are a set of foam filters (lightest), black filter (medium density), and white felt filter (densest) and they all aim to allow users to adjust the treble to their preference. From my experience, it seems like they target the 8.5K peak the most and they do it fairly well, but it does have some effects on resolution. When using the filters I feel like the bass and mids in particular lose just a little bit of their cleanliness, and how much resolution is sacrificed increases with the level of density; an unfortunate trade-off incurred by front-damping the driver.
For EQ, I will start with the AEON 2 Open as it is the one that needs it the most desperately. I use a combination of low shelf filters to tame the bass into more normal levels and reduce the lower-mid bleed that congested the AEON 2 Openās tonality. Additionally, I use some pretty drastic peak adjustments at 6.5K and 8.5K to quell the treble down a bit. After using EQ, the AEON 2 Open sounded a lot more natural and balanced to me. Now, whilst the EQ I used made the sibilance, sizzle, and pierce go away for the most part, the AEON 2 Open still seemed to retain a bit of a strange harsh quality. If you are interested in trying out my EQ for the AEON 2 Open, the settings I used were:
AEON 2 Open EQ
Low Shelf at 300hz, -7dB Q of 0.7
Peak at 6000hz, -7dB Q of 3
Peak at 8500hz, -5dB Q of 2
The AEON 2 Closed I do not think needs EQ, but I did want to relieve some of that 6K and 8.5K peakyness, as well as the upper-midrange recession between 1.5K to 5K whilst bringing it closer to my personal target (which is fairly similar to the Harman Target. If you would like to try my EQ preset for the AEON 2 Closed, these were the settings I used:
AEON 2 Closed
Peak at 130hz, -3dB Q of 1.2
Peak at 300hz, -2dB Q of 1.4
Peak at 2500hz, 3dB Q of 0.7
Peak at 6000hz, -4.5dB Q of 4
Peak at 8500hz, -2.5dB Q of 6
High Shelf at 11000Hz, -3dB Q of 0.7
I think it is strange that, in a way, the AEON 2 Closed feels to me like a refinement in every way when compared with the AEON 2 Open. From my experience listening to both, I was really hard-pressed to find anything that the AEON 2 Open offered over the AEON 2 Closed. They both offer a fairly energetic tonality, with accentuated highs and very present, warm bass; however, the AEON 2 Closed is able to present that sound signature in what I think is a much more tasteful and enjoyable way that does not sound oddly dark and shrill in the way that AEON 2 Open does.
Having said that, there are a few takeaways for me after listening to both of these Dan Clark Audio headphones. The first thing is that, knowing how the Closed-back performs and sounds, there is no scenario in which I would find myself recommending the AEON 2 Open; the AEON 2 Closed overall performs better and I find it to be significantly more enjoyable with or without EQ. The other thing I wanted to mention is that if you are looking for a planar-magnetic headphone in the $700-$1000 range, I truly believe that as long as you are willing to sacrifice some dynamics and soundstage the AEON 2 Closed should be a strong contender in your shortlist amongst headphones like the LCD-2, Ananda, and LCD-GX; as it offers the most unique package among them with great tonal and technical performance delivered in a comfortable, portable, lightweight, closed-back package.
Iāve been waiting for months for these two Aeonās to be reviewed⦠alone and in comparison to one another. Very, very helpful.Thanks.
Also, but off the subject, I have two RME ADI-2 DACās and donāt know how to use their Parametric EQ functions. From this post and others, it seems you know a lot about that. Any chance you could do a post for ābeginnersā on what the various terms mean (in plain English) and how to do the Parametric EQ setting on the RME (again, in non-technical language thatās easier to understand and actually use)? Thanks in advance if you can. Donāt know how many would admit it, but I think many of us on this site would really like to have that information. Thanks againā¦Lee
thank you for checking out this written review, and Iām glad to hear that it was helpful!
Also, yeah, I think thatās a great idea, Iāll try to make an introductory post on EQ later this coming week.
Thanks again!
Thank you Chrono.
Your Aeon review saved me buying the Open and being unhappy with it. Previously Iāve looked high and low on the internet, for hours and hours, searching in vain for a top flight review of the Open. Yours is a welcomed first. Lots of reviews out there on the Closed. But none on the Open. And none comparing one versus the other. So thanks again.
As for the EQ post, Iād guess there are dozens of us on this site who own the RME ADI-2 and suspect the vast majority only know how to make basic bass and treble adjustments with the two control knobs on the face of the unit. In other words, weāre missing out on a huge capability of the RME, and that loss is multiplied over and over again for the multiple headphones that most of us have in our collections. So your EQ post will truly be a very big deal.
This was also sort of true with the first generation. I own the original AEON Flow Closed, and am still happy with it. The first Open had loose and thick bass. The story at the time was the Open sounded like a closed headphone while the Closed sounded like an open headphone.
My thinking is that the AEON drivers donāt generate bass very well ā Dan Clark seemed to use the natural reflections of the closed cups to bring up the bass response in the Closed. In contrast, the Open just struggles to sound natural.
Great review Chrono.
Do you have a RME ADI now?
Cheers.
Thanks for checking it out!
No, at the time Iām still using my Element II amp/dac combo as itās still my favorite source from the ones Iāve tried. Iāve been very curious about RME, and I know that it has built-in EQ bands available; but I canāt buy one at the moment hahaha
Cheers!
Ohh, OK⦠So thatās going to be 50% of his request then. ![]()
Another fantastic review. Well done sir!
If I decide I need a closed-back planar, Iāll give the A2C a hard look.
Thank you for checking it out! And yeah, I was actually really surprised by the A2Cārather nice headphone.
Impressively comprehensive review as always @Chrono. Itās going to be really helpful to anyone thatās in the market for either of these headphones. Great stuff.
I know you said the dynamics on the A2C were a little lacking, but how does it compare to something like the AKG K371? I own the latter, and while I like the sound overall, I find them a little thin in the upper bass and lower midrange as well as lacking real bass slam/punch (dynamics). Is the A2C a step up over the K371 in those areas?
Hmm I think that to me they are about on-par for dynamics. I did not personally find either of them to be particularly punchy; specifically in the bass region, as youāve mentioned.
Well after almost 6 months with the A2Oās I sold them. Sad. But with all my stuff they got the least useage and most of what has been said I have found to be pretty accurate.
Out of the box they didnt really sound that greatā¦and they do sound conjested compared to other cans I have or have had.
As I stated and many others have they do get better with age, but IMO they hit a wall and it is what it is.
One of the nicest things for these cans is they are one of the most comfortable headphones everā¦simply a beautiful soft cushy feelingā¦very nice. Compare these to Grados or my HEDDS!!
WIth all the tuning pads included IMO I was thinking that these would be on the bright side, and the pads were there to tame the high end somewhatā¦but the cans never seemed bright to meā¦and they worked very well with acoustic guitar, strings etcā¦
The best amp with them was the Schitt Magni 3! It made them wake up!
So after a 100+ hours I decided to part with them. This doesnt mean they are bad headphones, they are still pretty nice, and I wish I had tried the closed pair as wellā¦YMMV.
All the best
Alex
The mighty Magni 3 did the same thing with my LCD2-C!
I assume you tried the A20 out of your Lyr 3 and Jot? I ask because I found the original Aeon to be congested; Iāve heard it said that the congestion is a result of being underpowered, but Iām a bit skeptical. I doubt the Jot wouldnāt have the oomph to power them sufficiently.
Chrono, did you happen to try the closed with the openās perforated earpads? On the DCA website, they say that the perforated pads bring the closed a little closer to the harman curve. Which might be good for resolving the recessed upper mids, but bad for the bass and lower mids (which are already elevated)
