EQ for both iOS & Mac
eqMac is definitely the way to go. BUT… for some of the features, there’s a subscription for Pro. Fortunately, it’s only $3/month which to me, is very much worth it.
You can solve both problems by using an EQ audio unit plugin with SoundSource. I use DMG EQuick. There is also Apple AUNBandEQ which is included in macOS.
eqMac is a fine product but even the pro version only applies EQ to the system output.
Or use Roon to play Tidal, which has its own parametric EQ.
I don’t know the details of the micro IDSD but that’s possible. Or it could be boosting bass after the DA conversion which could still make the amp clip if you crank the volume close to max. I suppose SoundSource could automatically adjust the gain but I don’t think it does. In fact every EQ software I’ve used has made me adjust the gain manually.
@orrman @AudioTool Thanks for the suggestions. I’ll try both eqMac and EQuick and see how it goes.
I recently bought SoundSource and it seems to work for what I need it to do, which is have easy access to AutoEQ settings without having to think about it. eqMac arguably looks nicer and has more functionality, but there seems to be some kind of issue where the whole application can lock up after the computer wakes from sleep. I’m not sure if it’s the app or some kind of issue on my end. I’d probably go back to it if there was a fix.
Somebody already sort of said this, but I just wanted to weigh in and say that I believe SoundSource can do everything you were hoping for. You don’t have to use predefined settings, you don’t have to script anything, you can tinker while you’re listening, and you can assign different EQs to different apps. The secret is that when you click “add effect” you then select “Apple” and you have a whole bunch of different EQs to work with. I use AUNBandEQ, which allows me to create just about as many bands as I want at any specific frequencies I want, and I can adjust as needed. I’m not sure I’ve ever used the Pro version of EqMac, but I just wanted you to know that if you purchased SoundSource, I believe it has the goods. You just have to know how to access them.
Click “Add Effect” then “Apple.” So simple, yet I never clicked it. Or, I probably did to get the Audeze Reveal plug-in.
I didn’t know this existed. It seems the width value is equivalent to the bandwidth value you’d see in the Oratory profiles? I’m not really all that familiar with EQing and just getting into it. If I use the AUNBandEQ and the profile for my newly acquired Aeon 2 Noire I’ve been trying out, it sounds good, but different than if I choose the profile from AutoEQ, so I’m wondering what the difference is.
The difference is that one is a preset made by oratory1990 and one is a preset made by the AutoEQ algorithm. Both presets are based on a frequency response measurement made by oratory1990, which is why both are labeled “oratory1990”.
Oratory1990 has nothing to do with the AutoEQ project, actually. In fact, oratory1990 does not like the AutoEQ preset feature in SoundSource because SoundSource is profiting from their work without licensing it. I prefer the non-AutoEQ oratory1990 presets anyway.
I wonder who else is using AutoEQ presets without licensing it? Wavelet? Qudelix? Seems like a Pandora’s box of legalize might need to be opened.
That makes sense. In this case I prefer the manual setting (which I believe I did correctly) to the preset one as well.
It’s a thorny problem. Oratory1990 allows anyone, including AutoEQ, to use their measurements as long as they do not profit. AutoEQ allows anyone to use their presets. Companies use the AutoEQ presets without even realizing they are technically violating oratory1990’s measurement license.
Does anyone besides myself have use for a non-jailbreak iOS app with no streaming capability but with parametric EQ? Oratory1990 recently pointed out the existence of one called Studio Music Player ($4.99).
Only works on files local to the device. It provides its own file/track handling interface with some basic Fx but importantly a somewhat crippled form of parametric EQ. While it provides a long list of EQ presets, they’re limited to budget mass market stuff from 5 years ago. And it’s not possible to simply type in the vast majority of Oratory or AutoEQ profiles due to some of its limitations. it is, however, possible to work around those limitations. I’m happy to help anyone deal with the EQ quirks, if indeed there is anyone left who hasn’t totally gone over to the streaming side of the force.
I see I have some reading up to do. The whole idea of the measurement guys licensing their measurements is a new idea for me that I need to get a good grasp of. As for his own EQ profiles, he publishes all of them in PDF format. It is left to most end users to manually enter them into fields in the software.
As far as who is profiting from AutoEQ profiles generated from Oratory1990 or Crinacle or rtings, etc., I imagine there can be a contractual understanding between that project and the measurers. What that would look like is a complete mystery to me.
Is SoundSource still the best tool on mac? Is there any quality loss compared to Roon or APO?
Sorry, but I don’t have a QR code to log back into my account. I’ve been trying to contact the administrators to no avail..
I use SoundSource and it fits my needs. On reddit I have found another EQ-Tool:
I have not checked it yet, but it is for free, so you can test it.
I will test it out, but I am bit worried that the quality will be worse.
I’ve tried CamillaDSP on rpi and it sounded worse than APO+PEACE.
I also really like/use SoundSource, it’s an excellent app. I use it to also manage a couple of plugins from Goodhertz, CanOpener Studio and Ghz Tone Control, which I find very useful for some recordings.
CanOpener Studio ia a highly customizable cross-feed plugin, which works very well. Their stuff is worth checking out if you have SoundSource, https://goodhertz.com .
They have various sales throughout the year, and I know they have “Pi day” sales each March. :+1:
SoundSource is fine, but I hate how their trial works.
It adds noise on top of the sound after 20 minutes, you can turn it off and on and then it works again, but I have -6db pre, so sound gets a lot louder.
So, what would IT guy with Claude Code do? I’ve started vibing a solution for this. Tool that detects an upgrade popup, turns down the sound, restarts the app and turns it up again.
I also plan to add an option to detect a silence between songs and restart the app, so I almost never hit that 20 minute limit (damn you prog songs).
It’s a fun little project, I will buy a license when there is a sale.
What are you using with SoundSource? Is Nova better than the apple effect?
