The Fidelice (by Rupert Neve Designs) “Precision Digital to Analog Converter” is high-end DAC/amp and one of a trio of launch-products under the “Fidelice” brand, targeted at bringing Rupert Neve’s legendary studio engineering prowess and delivering a high-end studio listening experience directly to the music lover.
This is a full-size, desktop, all-in-one component, with a number of interesting features:
- 2x Analog Inputs (RCA and XLR/TRS combo)
- 3x Digital Inputs (USB and S/PDIF COAX/TOSLINK)
- 1/4" (6.35mm) TRS - Single-Ended Headphone Output
- 4-pin XLR - Balanced Heapdhone Output
- 4.4mm “Pentaconn” - Balanced Headphone Output
- Selectable Gain (High and Low)
- PCM support up to 24/384 kHz
- DSD support up to DSD512
- Switchable Fixed/Variable RCA & XLR analog outputs
- Input level attenuator (for consumer/professional signal levels)
- Selectable Digital Filter Options
- User-updatable firmware.
You can employ the “RNDAC” as an analog amplifier, DAC, pre-amplifier or all-in-one device, giving a great deal of parallel functionality. The all aluminum chassis is inlaid with wooden panel embossed with stylized “R” signature.
This is a high-end piece, available from headphones.com, with an asking price of $4,995.
Specifications
CONNECTIONS
Analog Inputs: XLR Balanced, RCA unbalanced
(+4 /-10dB operating levels switchable on the rear panel)
Digital Inputs: Coax S/PDIF, Optical S/PDIF, USB (Mac / PC / iOS / Android)
Analog Outputs: XLR balanced (fixed or variable), RCA unbalanced (fixed or variable)
Headphone Outputs: TRS unbalanced, 4-pin XLR balanced, Pentaconn balanced
Firmware Update: Micro USB
Balanced XLR Input to Balanced XLR Output (FIXED Volume)
Source Z = 40 Ω Balanced with 30 ft Output XLR
Input Impedance: 10 kΩ
Output Impedance: 40 Ω
Maximum Input Level (+4dBu Selected): +23.5 dBu
Maximum Output Level: +21.3 dBV
Noise @ FIXED Volume (10 Hz - 22 kHz BW): -101.2 dBV typical
Frequency Response (5 Hz to 116 kHz): +/- 0.1 dB typical
THD+N (@1 kHz): 0.0005% typical (10 Hz to 22 kHz)
Unbalanced RCA Input to Unbalanced RCA Output (2V RMS Redbook)
Source Z = 470 Ω Unbalanced
Output Impedance: 33 Ω
Maximum Input Level: +19.2 dBV
Maximum Output Level: +19.2 dBV
Noise @ FIXED Volume (10 Hz - 22 kHz BW): -109 dBV typical
Frequency Response (5 Hz to 112 kHz): +/- 0.1 dB typical
THD+N (@1 kHz): 0.0003% typical (10 Hz to 22 kHz)
Balanced Input to Unbalanced Headphone Output
Output Impedance: 0.01 Ω
Maximum Output Power: 1W into 16 Ω
Noise @ Max Volume (10 Hz - 22 kHz BW): -98.2 dBV typical
Frequency Response (5 Hz to 200 kHz): +/- 0.2 dB typical
THD+N (1W into 36 Ω Load @1 kHz): 0.003% typical (10 Hz to 22 kHz)
THD+N (1W into 16 Ω Minimum Load @ 1 kHz): 0.006% typical (10 Hz to 22 kHz)
DIGITAL PATH SPECIFICATIONS
Coaxial S/PDIF Input to Balanced XLR Output
(FIXED Volume, 192 kHz SR)
Noise (10 Hz - 22 kHz BW): -96.2 dBV typical
Frequency Response (5 Hz to 23 kHz): +/- 0.1 dB typical
Passband (0.5 Hz to 90 kHz): -3dB typical
THD+N (@1 kHz): 0.0004% typical (10 Hz to 22 kHz)
Coaxial S/PDIF Input to Balanced Headphone Output
(192 kHz SR)
Output Impedance: 0.02 Ω
Noise @ Max Volume (10 Hz - 22 kHz BW): -89.2 dBV typical
Frequency Response (5 Hz to 20 kHz): +/- 0.1 dB typical
THD+N (1W into 16 Ω Minimum Load @1 kHz): 0.008% typical (10 Hz to 22 kHz)
Coaxial S/PDIF Input to Unbalanced RCA Output
Noise (10 Hz - 22 kHz BW): -107 dBV typical
Coaxial S/PDIF Input to Unbalanced Headphone Output
(192 kHz SR)
Noise @ Max Volume (10 Hz - 22 kHz BW): -95.2 dBV typical
THD+N (1W into 16 Ω Minimum Load @1 kHz): 0.006% typical (10 Hz to 22 kHz)
This is the spot to discuss Rupert Neve’s “RNDAC” …
