This is the place to discuss all things Fiio FT5:
Fiio were kind enough to send it over for me to check out. I did a live stream on them here, and also posted some measurements in a different thread for a comparison but figured it deserves its own dedicated thread for people to chime in on.
Here are the measurements:
B&K 5128: Leather Pads
Raw
Calibrated
B&K 5128: Suede
Raw
Calibrated
Not much difference between the two pads but subjectively I preferred the suede pads.
GRAS: vs Harman
The following metrics are usually not perceptually relevant and mainly indicate whether or not the headphones are well-functioning
THD @ 105dB (1khz)
Excess Group Delay (if we need to care about time domain information like CSD)
Driver resonance frequency & driver damping:
EQ (leather):
Adjustment:
EQ Result (leather):
There are quite a few fine-grained features in the treble that will need to be adjusted by ear, since positional variation shifts things around a bit. But this should be a good start. It sounds much better with this EQ applied.
My general thoughts on this one:
- I find it very well built, reasonably comfortable - the pads sort of just hug your head, it’s nice.
- Tuning is definitely on the strange side of things. It’s got a lot of warmth and lower mid bloat that obscures a lot of the rest of the clarity. The dip in the mids on its own isn’t that bad but the contrast with the lower mids is extreme. So it’s simultaneously thick, hollow, yet peaky and harmonically imbalanced presentation overall.
- Good performance for all other metrics. Low harmonic distortion, minimal driver damping, low resonance frequency (imperfect seal won’t kill all the bass), no weird issues with excess GD to note. Just odd tonality.
- Subjectively, for whatever reason this sounds quite compressed to my ear. I actually recommend this one for anyone wanting to study this quality, whether it’s a function of frequency response or something else.
