Focal Utopia Open-Back Headphones - Official Thread
The LEMO connectors that Focal uses on the Utopia are pretty robust, so you should be able to repair it without having to buy new connectors (and if you do buy new ones, you’re probably going to be stuck with silver, as the black ones are a bugger to get).
If you have to trim and remake the connections on the damaged side you’ll probably want to do the same on the other. If it’s just a case of resoldering the wires and putting the cable back into the strain relief (it’s a chuck/collet style fixing on the LEMO connectors, so it can be re-used) you may only have to do the one side.
Good news, everyone! Well cord not broken actually. It’s just the strain relief and metal bit got pulled up revealing the excess. When I took the good connector apart it looks like that, just not exposed.
The only thing left is to try and put this LEMO connector back together…these little metal bits…
Hey Torq, do you which pins need to go into which side of the connector?
I am pretty sure I inverted a pin when I put the connector back together and now bass is weird.
I also broke one of the metal pieces in the connector, which holds it in place. It should work with the one but this is why I don’t really trust myself to do these projects.
The pin assembly (the two-piece split-insert carrier, and the plastic insert/insulator with the actual pins in it that the carrier fits around) should only be able to go in one way.
If you’ve damaged/lost one of the split-insert carrier pieces, you’re likely to have alignment/retention issues, and won’t have that one-way keying behavior …
In which case, one of those the split carriers has a hole in it that should line up with a raised mark on one side of the insulator/pin assembly, and that should be on the side of the connector that has a red dot on the outside of the shell.
If you need more information, or to order new connectors:
Data sheet for the LEMO connectors is here. The connector Focal uses information starts on page 11.
Part number is: FGG.0B.302.CLAD52 (that’ll be the chrome finish, good luck finding black) - price floats between $33 and $45 depending on availability/demand. The plastic boots are $4-$5 each.
Hey Torq-
Thank you very much. That makes sense. I managed to also turn the cable on the other connector which had no issues which has both parts.it was horizontal after I put it back together but it seems I need to realign with that in mind.
I broke the bit with the hole. Will that connector come with those little metal bits/do think they work with the Utopia cable?
The part I linked will come with the collet, shell, insulator/pins and both split-insert carrier pieces. They should be interchangeable with the parts on the connectors you have, as they only differ in color (and the internals are the same either way).
It’s the same part I use for the Utopia on the custom cables I build (2nd from the bottom):
Note that the red and black strain relief pieces shown here are optional and a different part (they won’t come with the part linked above). You should be able to re-use the Focal connectors as-is and just take the split-insert carrier pieces from the connectors I linked.
Focal Utopia Review - The King of Detail
The Focal Utopia has been out now for some time, and when it first came out there was nothing else like it. Now, in 2019, there are a lot more flagships on the market to choose from, and the Utopia is often used as a comparison for new headphones. “How does it compare to the Utopia?” is a common question among audiophiles whenever a new flagship comes out. And so in this review I’m going to ask the question of whether the Focal Utopia is still worthy of being the headphone that all other flagships are evaluated against. Is this still the king of detail in 2019?
Specs
Type - Circumaural Open-Back Headphones
Impedance - 80 Ohms
Sensitivity - 104dB SPL / 1mW @ 1kHz
Total Harmonic Distortion (THD) - < 0.2% @ 1kHz / 100dB SPL
Weight - 490g (1.08lb)
Cable Length - 4m (13.1ft)
Connector - 6.35mm (1/4“) Neutrik® Stereo Plug
MSRP - $3999
Source
FLAC Library, TIDAL (HiFi and Master) - iFi iDSD Micro Black Label-> Cayin IHA-6 -> Focal Utopia
FLAC Library, TIDAL (HiFi and Master) - Focal Arche DAC/Amp -> Focal Utopia
Music
For the Utopia I’ve been using my usual collection of well-recorded jazz from Michael Wollny, GoGo Penguin, Molly Johnson and my sibilance test is Patricia Barber’s ‘Code Cool’, for anyone wanting ear pain (although I do like the music). I’ve also been getting into the new Opeth album In Cauda Venenum for heavier material, and while it’s not all that well recorded, it’s certainly the best of this current generation for the band. Additionally, I actually find Tool’s Fear Inoculum to be reasonably well engineered and mastered, in spite of the fact that there are a few occasions where the mic sounds a bit close for comfort.
Build, Design & Comfort
The Utopia is one of the most incredibly well built headphones I’ve ever had the pleasure of using. Everything from the pads to the grilles to the carbon fiber yokes feels remarkably sturdy, and while the material cost alone might not justify the price tag, this certainly looks and feels like a premium headphone. Comfort is also reasonable, however because the Utopia is so well built, and because it also came out before the design iterations from the Clear, Elegia and Stellia, it’s currently the heaviest of Focal’s high end lineup. This means that while the soft leather perforated pads feel luxurious, the top piece for the headband does weigh down on my head after a while. Still, this is much more comfortable than the heavy planar flagships from Audeze, and it’s only slightly less comfortable than the Clear and the Stellia, and the materials feel more premium on the Utopia than all of the rest of their headphones.
Build Quality - 9.5/10
Comfort - 8.5/10
The Utopia uses the same ‘formerless’ M-shaped dome style of driver that’s used throughout many of their other headphones, however the Utopia uses solid beryllium for the drivers instead of the aluminum-magnesium employed for the lower end models. My guess is that such a light driver system with the formerless voicecoil, coupled with the stiffness and rigidity of solid beryllium confers serious technical performance benefits that traditional dynamic drivers can’t match. Ideally, a dynamic driver has a diaphragm that has high stiffness and restorative force so that it can more accurately track and react to its signal - and solid beryllium material allows the Utopia to achieve precisely that. The drivers are also angled within the cup, meaning it should alter the effects of concha resonance amplification, or in other words the sound being produced should react differently to the physical properties of the ear. There are other examples of headphones doing this these days, and of course Focal has done this with the rest of their line as well. Interestingly this also may be responsible for substantial sound differences depending on the position of the headphone on one’s head.
Performance
I’m a big fan of the formerless driver systems that Focal uses, and in my mind they all enjoy performance benefits over similarly priced biodynamics - both for detail retrieval and speed. The one concern with these drivers is that for whatever reason they may produce somewhat of a metallic or artificial sheen to the music. So I’ve approached my evaluation of the Utopia with the intent to specifically listen for that quality.
Detail Retrieval - 10/10
The Utopia is of course the headphone that all other flagships are evaluated against when it comes to detail retrieval. I can confidently say that the Utopia is nothing short of exceptional when it comes to detail, and while other flagships are now able to get to the same level of detail ability, the Utopia is clearly still the best dynamic driver headphone in that regard. I have yet to hear another headphone categorically exceed the Utopia for detail.
Speed & Dynamics - 9.8/10
Here’s where the benefits of the ultra-fast driver show up. The attack is quite strong, also possibly the strongest for a dynamic driver headphone. The Utopia sounds punchy and tight throughout the frequency response, and also has excellent dynamic slam - not quite on the same level as some flagship planars, but still incredibly engaging. Microdynamics are also nothing short of exceptional here as well.
Stage & Imaging - 8.5/10
Structural definition for the images and positional accuracy are second to none on the Utopia, however the stage is considerably smaller than on other, less expensive headphones. It doesn’t feel claustrophobic, and it’s less of an issue particularly because the detail and speed are so good. Instrument separation is spectacular and every image can be pinpointed with complete surgical precision. I do wish this had a more ‘speaker-like’ presentation, but it’s a trade-off I’d be willing to make if that’s the price for the rest of the Utopia’s technical ability.
Timbre - 8/10
In general I find the Utopia a bit on the sweet side, and that’s actually my preference. There’s no ‘dry thud’ that I’m always worried about. I was also specifically listening for a slight metallic edge or sheen to the Utopia because that’s been a common concern or criticism from some listeners. If it exists, it’s not significant enough for me to confidently be able to pinpoint exactly where in the frequency response this shows up. It’s certainly less noticeable than the distinction between balanced armature and dynamic IEMS, where there is a risk of a noticeable metallic smearing effect to certain frequencies. It’s only when I compare the Utopia to my ZMF Vérité that I really start to notice a less natural timbre and even then it’s likely just the different tonality that’s responsible. My instinct is that the perception of a metallic timbre has more to do with the knowledge that Focal headphones use beryllium or aluminum-magnesium drivers than it does actually being bothered by the timbre - our experiences are often influenced by countless subconscious expectations we’re unaware of at the time.
Tonality & Frequency Response
Measurements done using the MiniDSP EARS rig, which is not to be taken as an industry standard measurement system. The following uses the HEQ compensation, which is similar to the target developed by Olive and Welti.
Looking at how the Utopia measures on the MiniDSP EARS rig, I’m reminded again of how inaccurate this system is. The visually striking dip around 5khz doesn’t actually show up there on more precise rigs, and it’s also not as dramatic. Interestingly, pretty much all Focal headphones that I’ve measured have some form of dip there, and this makes me think it has more to do with how headphones with angled drivers interact with the EARS rig’s pinna and concha than it does the actual tuning of the headphones. Still, it’s interesting if only for comparison’s sake. Compared to the consumer oriented curve the Utopia is a bit bass shy, as it sits somewhat lower than the midrange. It’s also slightly counter-clockwise tilted. While it might look a bit uneven on this rig, the treble is some of the absolute best out there. Cymbals in particular sound incredibly realistic. The consonant peak at around 8.5khz also thankfully isn’t at all sibilant and that’s also partially due to the Utopia’s remarkable detail ability. There’s simply no grain or etch to be found with this headphone.
The following shows how the Utopia measures on the HPN compensation, which is closer to a diffuse field target.
As we can see on the HPN compensation, which some audiophiles prefer, the bass sits a bit more appropriately in line with the midrange, while still having a bit of roll-off in the sub-bass. I find that frequencies below 30hz aren’t particularly audible, but still if I had to nitpick, it could use a bit more elevation in the sub-bass. This is again where planar magnetic headphones often have the edge. Overall though the Utopia has excellent tonal balance - there’s no withdrawn qualities to cymbal hits where the tonal focus is pulled back in favor of overemphasized ‘air’ and sparkle above 12khz like was the case with some other flagships I’ve evaluated lately. This allows the treble to remain focused and consistent with how I hear things in real life. There’s still completely sufficient treble extension and air quality, allowing the Utopia to sound open and airy, in spite of the slightly smaller stage.
The bottom line for tonality is that it’s almost exactly my preference, sitting carefully between Harman and diffuse field targets, and if I had to change anything about it would be to boost the sub-bass by a few dB.
Score - 9/10
Audeze LCD4 - The LCD4 is a planar flagship that in my opinion is far too heavy for regular use, however from a strictly technical performance perspective, the LCD4 is truly amazing. The Utopia is very similar in terms of detail capability, but if I had to give the edge to one over the other it would be to the LCD4 for bass detail and texture and to the Utopia for detail throughout the rest of the frequency response. It’s likely the case that the LCD4 is technically slightly superior, however its tonality obscures a lot of the detail throughout the upper midrange and lower treble. Effectively this means that the Utopia does do a better job of representing details in the mix. Moreover, the Utopia’s tonal balance is far superior to that of the LCD4, especially in the treble. The bass slams a bit harder on the LCD4 and it has a bigger stage, however I still find the Utopia to be slightly more surgical as far as its image presentation is concerned.
ZMF Vérité - The Vérité is the closest I’ve heard a dynamic driver headphone get to the Utopia. It’s detail retrieval isn’t quite on the same level as that of the Utopia and it’s also not quite on the same level when it comes to image definition/distinction, but it’s very close on all of those fronts. Where the Vérité has a clear advantage is in the soundstage. It’s a much larger and more ‘concert-like’ experience with bigger images as well. The Vérité has what I can only describe as a “controlled wall of sound” character to it that the Utopia doesn’t have. And while the Utopia does perform better on the attack (more punch, tighter), the Vérité has more intensity when there’s a lot going on in the mix. In my mind it’s a trade-off, if you want strictly the best detail, the Utopia is the better choice - but if you’re okay with ‘second best’ detail but on a bigger stage, the Vérité is likely a better choice.
Focal Clear - There are two key differences between the Utopia and the Clear. The first is that the Utopia has substantially better detail capability with the benefits of the solid beryllium driver. The second difference is that the Clear actually has what is in my opinion a more agreeable tonality with the added bass energy. Apart from that, the Clear has a slight edge to the consonant range at around 8.5khz, while the Utopia sounds a bit smoother to my ears. That again likely has to do with the superior technical performance of the Utopia. I quite like the Clear, but in my opinion the Utopia is just categorically superior, and ultimately more enjoyable.
HE1000se - This one is difficult, because while the Utopia has distinctly superior tonal balance for the treble (not as splashy above 12khz), the HEKse does also have incredible technical performance. Detail retrieval is very close between the two, but the stage and imaging for the HEKse is in a class of its own. Instrument separation is also superior on the HEKse, and that’s likely just because it’s a planar, but the overall experience is truly incredible once you EQ down some of the over-emphasized splashy quality above 12khz. With that said, the Utopia has better build quality and a more traditional design where the cups don’t protrude down your neck like they do for the HEkse. These are both incredible headphones, and I’d be happy with either, but for those who don’t want to EQ anything, the Utopia is much more realistic sounding.
Focal Arche DAC and Headphone Amp
I was able to test out the new Focal Arche amplifier with the Utopia and the closed back Elegia. The Arche uses a balanced design that features the AK4490 chip, as well as a voltage and current hybrid configuration. Focal has added a number of presets in the amp for each of their headphones, and while I initially thought this was some kind of DSP or EQ, after trying it out it’s clearly not the case. In fact, while I did hear a difference, I wasn’t able to detect any difference in the frequency response when switching between the different presets. When you select a preset, two things happen, you hear a click (almost like a relay switch), and you get a change in volume for the headphone by a few dB. It’s possible that there are other audible qualities, but nothing nearly as dramatic as applying an EQ would do. My guess is that it’s either changing the op-amp, switching between voltage and current, or applying a DAC filter (or any combination of these).
Interestingly, the most dramatic difference I found when amping the Utopia was with the 120 ohm output from my Cayin IHA-6.
The teal line the Utopia on the Arche, and the blue line is how it measures on the 120 ohm output of the IHA-6. Both are using the HEQ compensation.
While I don’t recommend using it for this (the Utopia is only an 80 ohm headphone), this resulted in a dramatic bass boost - to the point where it’s too much. But at the very least this was interesting to see, and for those who are looking at the Utopia and are concerned that it might be a bit bass light, it is possible to change the frequency response in the bass without using EQ. It’s a much more expensive way to change it, but it is doable. You just need to find an amp that has higher than 10 ohm output impedance. Personally I’d stick with the Arche, or another low output impedance source and just apply a bit of EQ - but then again the Utopia doesn’t really need EQ beyond guilty pleasure appeal the way some other headphones do.
If it wasn’t already clear by now, I love the Focal Utopia. It’s been a few years since it was released, but in 2019 it’s still worthy of being the headphone that all other flagships are evaluated against - at least for detail. Other flagships may now be able to reach the same technical performance, but so far it’s been a challenge to find one that also doesn’t compromise on any of the intangible qualities that the Utopia also nails, such as comfort, weight, design, build quality and so on. In fact, while I’ve been impressed by many flagships, the Focal Utopia is one that I personally would love to one day own. It’s the gold standard for detail retrieval and engagement while simultaneously being a headphone that I can use comfortably over the course of the day and makes zero concessions when it comes to build quality. Moreover, it also gets the tonal balance right, especially for the treble, and while I’m generally happy to EQ, it’s comforting to know that with the Utopia I don’t have to. For those who are able to afford it, the Utopia is amazing, and it gets a glowing recommendation from me.
Overall Score - 9/10
You can check out my video review here:
Please man. I have the Clear. Don’t tempt me into the Utopia!
Such a pleasant and easy read. Thanks for such an objective (even with some subjective-based analysis) and straightforward review along with useful comparisons. Keep up the great work.
Really great review as always. I would love to own the Utopia. Detail is perhaps the quality I look for when testing new gear. The Utopia seems like the king of detail, at least in the Bio-Dynamic realm. It’s also a stunning headphone to look at. I want one. Just need to win lottery now.
Great review! And regarding the “metallic” timbre thing, the way I interpret that is that the transient edges are really sharp. I think that’s why it sounds so clear and detailed, like a sharpening filter in photography. But that’s why it sounds metallic, it is too sharp and not smooth enough like real life. And that’s also what I mean by “timbre”. My definition of timbre is that it’s the quality of sound/tone (different from FR) of real instruments. Not sure if you play instruments or not, but I notice this timbre issue a lot when I listen to instruments I play (piano and guitar). Like if I listen to a recording of my own guitar with Utopia it doesn’t sound like it does in real life. Sennheisers and ZMFs tend to sound how I hear these instruments in real life. That’s why I like Verite so much, it has the same speed and dynamism that Utopia has, but I feel like its transient edges are just a little rounded in attack which adds a smoothness and coherence that Utopia lacks.
Yeah I think you’re right about the transient edge thing. Although my analogy would be more like turning up the clarity slider in Lightroom, rather than applying a sharpening effect, because I normally associate that with grain and the Utopia doesn’t have any to my ear. And yeah the Verite definitely has a more natural tone to it, and that’s why if I had to choose one over the other I don’t know which I’d pick. The Verite also does a few other things better than the Utopia, like stage, image size and that controlled wall of sound thing.
Hey @Resolve after obsessing over the Utopia for a while and checking out all your youtube reviews I just wanted to say thanks for taking the time to review this!
I’m wondering if you might answer something for me as a Clear owner. I really love the overall feel and punch of the bass on the Clear. Would you say that the Utopia can match it if it’s EQ’d properly? Or is it more of a case of more clarity/resolve with the Utopia with less “oomph” if that makes sense.
You could EQ a Utopia to sound like a Clear with some bass boost (just a touch). While the Utopia does gain benefits to clarity from its tonality, the technical performance for detail has more to do with its solid beryllium driver. Another example of this is the Stellia. It’s tonality is much more bass emphasized than that of the Utopia, but it still has superior detail capability over the Clear. If you’re just looking for a more ‘fun’ sound with a bit more bass emphasis, consider the Stellia as well.
Thanks for the detailed response, this is exactly the information I was looking for in considering the Utopia. Good to know it’s still the benchmark after all these years. Cheers :slight_smile:
Yeah the clarity slider is probably the better analogy. I agree Utopia doesn’t feel grainy or harsh at all. It just has that “truer than real life” type of vibe, which I think can be a good thing. That’s why I absolutely love Utopia with most pop/electronic types of music. Anything that has that “produced” sound is just incredible on Utopia and I would choose Utopia over Verite in those cases. But Verite excels in genres with acoustic instruments/vocals like jazz, folk, country, blues, etc; and especially music that has a real stage and performers occupying a physical space.
I can’t remember, have you heard Verite closed yet? I think VC almost bridges that gap between Utopia and Verite open and falls in the middle.
Very interesting! I haven’t heard the Verite C yet, although I’d love to one day review it side by side with my Verite Open.
As someone just finishing up just such a review (probably post today) … plan on lots of time just lost in the music with sod all else getting done! :wink:
Concur, the VC is pretty amazing, I can’t wait to see what my pair will look like!
@Torq As someone currently addicted to reading every single Utopia review I can find online, I’m looking forward to your review!
