NEW - UNUSED - PURCHASED DIRECTLY FROM 64AUDIO (included in a bundled IEM purchase).
High-end Audiophile Cable for IEMs (0.78mm 2-Pin connector IEMs only).
Brand: 64 Audio.
Model: Premium Plus Cable - Pearl.
Connectors: 0.78mm 2-Pin.
Termination: 3.5mm - Gold-plated.
Wire: Silver-plated.
Design: Clear sleeved braided wires cable, metallic plug, bifurcation, and sinch.
From 64 Audio product page (Sells for $199):
Our new Premium Cable… One of our lowest resistance cables, features a branded straight 3.5mm metal jack, as well as a metal synch and branded metal bifurcation. Our classic angled 2-Pin connectors are situated at the end of an ergonomic curve in the cable to accommodate a comfortable fit around the ear without a memory wire. The new soft jacketing virtually eliminates tangling and microphonic noise.
Product Specifications :
-.78mm Pins
-0.23 Ohms Total Impedance
-7 x 7 x 4 Multi-Twist
- Silver Plated OCC Copper Wire
-26 AWG
The Premium Cable is only compatible with our Universal In-Ear Monitors
Pickup: Portland OR area.)
149 USD.
