And just to close the loop. Been putting the SA6 and Andro 2020 through their paces. Different beasts, and I’ll end up keeping both as they kinda scratch different itches. The SA6 is a nice all-round performer, only niggle is fit on the right ear (though I think I’ve sorted the tip), just waiting on a Hart audio cable that should lighten things up and help. I find it to be not particularly harsh anywhere, and has enough warmth for my taste. Rock guitars in particular sound good.
The Andro 2020 is odd. It is smaller/lighter though a bit shallow, but again, I think I’ve found the right tip combination. It is lighter in the bass than the SA6 but isn’t harsh anywhere and if I want a bit more low end experience the xbass on the hipdac or zen dac v2 cover that. I usually leave it off though, as I like the detail that I get down low without a lot of upper-low push. There is something about the Andro 2020 that I can’t put my finger on but I like it a lot. I don’t know if it is the imaging or note attack/decay or good old confirmation bias
but I like it. They are really sensitive so the iPhone drives them no problem. I’m just figuring out if I want to run the IEMatch as they may be a bit too easy to drive. We’ll see.
So happy camper here. Now just waiting for the Hart Audio cables to get here so I can run the Andro balanced and drop some weight from the SA6. The listening continues, thanks to all here for their input.
That said, I still am curious about U6t. I suppose it never ends until you’re dead…
