Headphones.com EQ Repository & Request Thread
Audeze MM-500 please! Thanks!
I have to say here @listener – you’ve done a fantastic job on these. I’ve been listening to both your Hexa and HD560s for the past week and really enjoying them. Your approach to this clearly has something going for it. Kudos!
Would love to have K361 EQed.
Fantastic project. Thanks for this thread!
Sony MDR-Z1r
Uses data from GRAS KB50xx
Confidence: VERY LOW
Preamp: -8.9 dB
Filter 1: ON PK Fc 65 Hz Gain 2.2 dB Q 2.000
Filter 2: ON PK Fc 140 Hz Gain -5.0 dB Q 0.600
Filter 3: ON PK Fc 2815 Hz Gain 7.0 dB Q 7.000
Filter 4: ON PK Fc 3300 Hz Gain -12.0 dB Q 1.800
Filter 5: ON PK Fc 4050 Hz Gain 6.0 dB Q 4.000
Filter 6: ON PK Fc 4200 Hz Gain 12.0 dB Q 1.000
Filter 7: ON PK Fc 5000 Hz Gain -1.5 dB Q 3.000
Filter 8: ON PK Fc 9600 Hz Gain -9.0 dB Q 1.000
Filter 9: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.707
Filter 10: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.420
Adjust band 1 for mid-bass bloom
Adjust band 2 for warmth
Adjust band 4 for shout
Adjust band 6 for presence
Adjust band 8 for shimmer
Adjust and enable band 9 for overall bass
Adjust and enable band 10 for overall treble
DCA E3
Uses data from B&K 4128 and 5128
Preamp: -0.4 dB
Filter 1: ON PK Fc 1250 Hz Gain 1.0 dB Q 1.000
Filter 2: ON HSC Fc 2500 Hz Gain -2.0 dB Q 0.420
Filter 3: ON PK Fc 3900 Hz Gain -2.5 dB Q 2.000
Adjust band 2 for overall treble
Adjust band 3 for shout
Kiwi Ears KE4
Uses data from 5128 and Type 3.3 (Listener)
Preamp: -0.2 dB
Filter 1: ON LSC Fc 105 Hz Gain -0.5 dB Q 0.700
Filter 2: ON LSC Fc 380 Hz Gain -0.7 dB Q 1.410
Filter 3: ON PK Fc 3400 Hz Gain 0.8 dB Q 3.000
Filter 4: ON PK Fc 4500 Hz Gain -1.0 dB Q 1.000
Filter 5: ON PK Fc 15000 Hz Gain -7.5 dB Q 1.400
Filter 6: OFF PK Fc 2500 Hz Gain 0.0 dB Q 0.420
Adjust band 1 for overall bass
Adjust band 2 for note weight
Adjust band 3 for shout and clarity
Adjust band 4 for grit
Adjust band 5 for sibilance
Adjust band 6 for overall treble
Can only find one measurement of that on a head/from an operator I don’t really trust, sorry.
Meze Alba
Uses data from 5128 and 711
Confidence: LOW
Preamp: -0.1 dB
Filter 1: ON LSC Fc 333 Hz Gain -2.8 dB Q 0.900
Filter 2: ON HSC Fc 925 Hz Gain -3.2 dB Q 0.900
Filter 3: ON PK Fc 2850 Hz Gain 2.0 dB Q 3.000
Filter 4: ON PK Fc 6200 Hz Gain -3.4 dB Q 3.000
Filter 5: ON HSC Fc 12000 Hz Gain -3.6 dB Q 3.000
Filter 6: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.700
Filter 7: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.420
Adjust band 4 for glare
Adjust band 5 for upper treble shape
Adjust and enable band 6 for overall bass
Adjust and enable band 7 for overall treble
Can’t find any good measurements for it, sorry.
Can’t find a measurement for it, sorry.
I don’t yet trust the measurements I’ve seen from it, unfortunately. A friend has measured an R70x Refine but the results differ greatly from what Jude measured on his R70x Refine. Once we get one in here, we can hopefully revisit an EQ profile for this one.
I’d want 5128 and 50xx measurements on our systems for Omega before making a profile. Stay tuned for that!
Atrium is kind of a PITA because most measurements out there don’t have pads listed or use different pads. I’m likely going to avoid offering presets for ZMF headphones for that reason tbh, too much of a headache. Since it’s you, let me know if there’s a specific pad you use on it and I’ll see if I can track something down.
Audeze MM-500
Uses data from GRAS KB50xx, B&K 5128 and 4128
Confidence: MEDIUM
Preamp: -7.5 dB
Filter 1: ON PK Fc 23 Hz Gain 2.5 dB Q 1.000
Filter 2: ON LSC Fc 95 Hz Gain 5.0 dB Q 0.700
Filter 3: ON PK Fc 230 Hz Gain -1.2 dB Q 1.100
Filter 4: ON PK Fc 3150 Hz Gain -2.0 dB Q 4.000
Filter 5: ON HSC Fc 3600 Hz Gain 4.2 dB Q 0.700
Filter 6: ON PK Fc 4350 Hz Gain 3.0 dB Q 5.000
Filter 7: ON PK Fc 7000 Hz Gain -3.0 dB Q 2.000
Filter 8: ON HSC Fc 13000 Hz Gain -5.5 dB Q 1.400
Adjust band 1 for sub-bass extension/leak compensation
Adjust band 2 for overall bass
Adjust band 3 for warmth
Adjust band 5 for overall treble
Adjust band 6 for muffled quality
Adjust band 7 for sibilance
Adjust band 8 for treble extension/air shape
Honestly for that one I’d just use Oratory’s preset. He’s measured a lot of units and the target he uses is (rather obviously) reasonable. His measurement of this headphone is the canonical one, as far as I’m concerned.
In case you still want one based on his measurement but with DF features though, here it is.
AKG K361
Uses data from Oratory1990’s KEMAR with KB50xx pinnae
Preamp: -6.2 dB
Filter 1: ON PK Fc 145 Hz Gain -2.4 dB Q 1.300
Filter 2: ON PK Fc 400 Hz Gain 0.4 dB Q 0.500
Filter 3: ON PK Fc 1250 Hz Gain -2.0 dB Q 1.000
Filter 4: ON PK Fc 3960 Hz Gain 6.5 dB Q 3.000
Filter 5: ON PK Fc 9300 Hz Gain -9.0 dB Q 4.000
Filter 6: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.420
Adjust band 4 for muffled quality
This is great! Thank you for taking the time to do this.
The stock pads which are… hmm. As far as I can tell they are the Universe Lambskin Perforated.
ZMF’s ZMF measurements: Measurements — ZMF Headphones
If you download the measurement image, there is more resolution.
Unfortunately Zach’s measurements are taken on his (weird) AECM206 rig, and I don’t have confirmation of the Diffuse Field HRTF of the ear he uses, so I don’t really have a characterization baseline to start from.
Oh I didn’t read the page closely enough. I just assumed the Atrium measurement is from his B&K 5128, but only the Bokeh measurement is labeled as such. :frowning:
It’s no big. I quite enjoy the Atrium’s stock tuning. I really just wanted to play around with tuning the sub-bass a bit.
If you click on the HATS Measurements tab, that will show the B&K 5128 measurement.
Hi Listener!
Am looking to make my Bathys frequency as flat as possible. I know this is odd, but I want it as close to a flat line as possible.
Thanks!
