Headphones.com EQ Repository & Request Thread
Audio technica ATH-M0x, looking for a clean bass boost
I’ve tried this preset with my Clear OG and Roon EQ. It sounds fantastic! Like the HD650 mids but with bass extension and air in the treble, well-rounded soundstage, layering, and depth. I didn’t know the good ol’ Clear is capable of this. The EQ presets I tried before just sounded off to me.
Thank you so much for doing this!
Would you mind posting a preset for Mega5EST as well? The bass seems to be easy to reduce with just a low shelf, but I’m not sure how to how to fix the ear gain region.
Beyerdynamic TYGR 300R
Confidence: VERY LOW
Uses data from GRAS KB50xx
Preamp: -3.3 dB
Filter 1: ON PK Fc 20 Hz Gain 3.5 dB Q 1.000
Filter 2: ON PK Fc 180 Hz Gain -5.0 dB Q 0.600
Filter 3: ON PK Fc 800 Hz Gain 1.4 dB Q 1.400
Filter 4: ON PK Fc 3000 Hz Gain 0.5 dB Q 1.400
Filter 5: ON PK Fc 4600 Hz Gain 2.0 dB Q 3.000
Filter 6: ON PK Fc 5555 Hz Gain -7.5 dB Q 1.400
Filter 7: ON PK Fc 7000 Hz Gain 7.0 dB Q 2.000
Filter 8: ON PK Fc 10000 Hz Gain -8.0 dB Q 1.400
Filter 9: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.707
Filter 10: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.420
Adjust band 6, 7, and 8 to balance on-head treble peaks
Adjust band 9 for overall bass
Adjust band 10 for overall treble
FiiO FT-1
Confidence: LOWEST
Uses data from B&K 4128 and clone GRAS KB006x
Preamp: -2.3 dB
Filter 1: ON PK Fc 135 Hz Gain -5.0 dB Q 0.700
Filter 2: ON PK Fc 1050 Hz Gain -1.4 dB Q 2.000
Filter 3: ON PK Fc 1850 Hz Gain -2.7 dB Q 3.000
Filter 4: ON PK Fc 2850 Hz Gain -1.2 dB Q 2.000
Filter 5: ON PK Fc 3900 Hz Gain 4.0 dB Q 2.000
Filter 6: ON PK Fc 5300 Hz Gain -2.9 dB Q 2.000
Filter 7: ON PK Fc 16000 Hz Gain -6.0 dB Q 1.400
Filter 8: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.707
Filter 9: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.420
Adjust band 5 for scratchiness
Adjust band 6 for grain
Adjust band 7 for air/shimmer
Adjust band 8 for overall bass
Adjust band 9 for overall treble
Symphonium Crimson
Preamp: -3.3 dB
Filter 1: ON PK Fc 450 Hz Gain 2.0 dB Q 0.300
Filter 2: ON PK Fc 1900 Hz Gain -0.9 dB Q 0.800
Filter 3: ON PK Fc 3100 Hz Gain 2.0 dB Q 3.000
Filter 4: ON PK Fc 7000 Hz Gain -2.4 dB Q 2.000
Filter 5: ON HSC Fc 10600 Hz Gain -3.4 dB Q 3.600
Filter 6: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.707
Filter 7: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.420
Filter 8: OFF HSC Fc 8000 Hz Gain 0.0 dB Q 0.700
Adjust band 3 for clarity or shout
Adjust band 4 for harshness
Adjust band 5 for sibilance/glassiness
Adjust band 6 for overall bass
Adjust band 7 for overall treble
Adjust band 8 for overall air
Philphone
Preamp: -5.4 dB
Filter 1: ON PK Fc 20 Hz Gain 5.5 dB Q 1.300
Filter 2: ON PK Fc 150 Hz Gain -2.7 dB Q 0.700
Filter 3: ON PK Fc 500 Hz Gain 1.0 dB Q 1.400
Filter 4: ON PK Fc 1500 Hz Gain -4.2 dB Q 1.000
Filter 5: ON PK Fc 2750 Hz Gain 7.5 dB Q 2.200
Filter 6: ON PK Fc 3750 Hz Gain -4.5 dB Q 3.000
Filter 7: ON PK Fc 4900 Hz Gain 6.0 dB Q 2.000
Filter 8: ON PK Fc 5500 Hz Gain -9.0 dB Q 2.000
Filter 9: ON PK Fc 7250 Hz Gain 9.0 dB Q 2.000
Filter 10: ON PK Fc 9000 Hz Gain -5.0 dB Q 2.000
Filter 11: OFF LSC Fc 105 Hz Gain 0.0 dB Q 0.707
Filter 12: OFF HSC Fc 2500 Hz Gain 0.0 dB Q 0.420
Adjust band 7 and 8 for scratchiness
Adjust band 9 and 10 for sibilance
Adjust band 11 for overall bass
Adjust band 12 for overall treble
DMS Omega is one where I really don’t want to put out an EQ before I have data on another head, so stay tuned for that one.
Focal Hadenys
Confidence: LOW
Uses data from B&K 5128 and GRAS KB50xx
Preamp: -3.4 dB
Filter 1: ON PK Fc 20 Hz Gain 3.5 dB Q 1.400
Filter 2: ON PK Fc 155 Hz Gain -2.1 dB Q 0.700
Filter 3: ON PK Fc 525 Hz Gain 0.5 dB Q 1.000
Filter 4: ON PK Fc 1100 Hz Gain -0.8 dB Q 1.400
Filter 5: ON PK Fc 2600 Hz Gain 2.4 dB Q 2.000
Filter 6: ON PK Fc 3650 Hz Gain -3.4 dB Q 3.000
Filter 7: ON PK Fc 5000 Hz Gain 1.8 dB Q 3.000
Filter 8: ON PK Fc 9000 Hz Gain -3.6 dB Q 2.000
Adjust band 6 for harshness
Adjust band 7 for grain
Adjust band 8 for sharpness
The Elegia is a closed back headphone with both significant unit variation and significant on-head variation, such that I’m really not sure if any EQ I can provide would be helpful. However, I’ll provide one nonetheless. Just make sure you tweak to your liking.
Focal Elegia
Confidence: LOW
Uses data from B&K 5128, GRAS KB50xx, and HeadAcoustics HMSii.3
Preamp: -10.3 dB
Filter 1: ON LSC Fc 71 Hz Gain 3.2 dB Q 0.800
Filter 2: ON LSC Fc 200 Hz Gain 1.4 dB Q 1.400
Filter 3: ON PK Fc 1850 Hz Gain -2.0 dB Q 3.000
Filter 4: ON PK Fc 2150 Hz Gain 3.0 dB Q 4.000
Filter 5: ON PK Fc 4150 Hz Gain 10.0 dB Q 2.000
Filter 6: ON PK Fc 6900 Hz Gain 2.4 dB Q 2.000
Filter 7: ON HSC Fc 12000 Hz Gain 3.6 dB Q 1.000
Adjust band 1 for bass extension/leak compensation
Adjust band 2 for warmth
Adjust band 3 for shout
Adjust band 4 for clarity
Adjust band 5 for scratchiess
Adjust band 6 for sibilance
@listener
Can I possibly have EQ for Sony MDR-Z1R
Thank you in advance.
Has there been an EQ for the Dan Clark E3? I know it doesn’t need much but it’d be neat to try out.
E3 is probably smack dab in the middle of the prefference curve lol.
When DMS measured it he actually showed a bit of extra energy in the ear gain area, though it was still in the preference bounds. Oratory’s measurements are somewhat similar.
Subjectively, I can hear it. The headphone seems to benefit from some reductions above 2.5k.
Would it be possible to get the EQ for the Kiwi Ears KE4? Especially interested in seeing how you change the mentioned earlier rise for the upper midrange :slight_smile:
test this @Lindholdt :
Preamp: -2.2 dB
Filter 1: ON PK Fc 23 Hz Gain -2.9 dB Q 0.400
Filter 2: ON PK Fc 650 Hz Gain -0.8 dB Q 1.700
Filter 3: ON PK Fc 2000 Hz Gain 1.7 dB Q 1.800
Filter 4: ON PK Fc 2400 Hz Gain 0.7 dB Q 2.000
Filter 5: ON PK Fc 5000 Hz Gain -1.3 dB Q 2.000
Filter 6: ON PK Fc 6100 Hz Gain 0.7 dB Q 2.000
Filter 7: ON PK Fc 7300 Hz Gain -1.6 dB Q 2.000
Filter 8: ON PK Fc 8000 Hz Gain 1.6 dB Q 1.000
If you could do one for the Philips SHP9600 that would be great :smiley:
@listener
Hi! would you do your magic on the Meze Alba?
Thanks in Advance
Is the Sennheiser HD 558 doable? They do not get much attention in the EQ world it seems
Would it be possible to create a profile for the somewhat maligned Aeon 2 Open?
I’ve found that it responds well to eq and would love to see your recommendations.
Thanks for this thread. Very helpful.
Requesting the R70x Refine!
Very good EQ! This has replaced Oratory’s EQ for the Elex (modified by ear) as my baseline.
My modifications:
-1 dB at 185 hz (cut 1 dB less)
+3 dB at 4800 hz (boosts 2 dB less)
-1 dB at 5900 hz (cuts 1 dB less)
-1.5 dB at 9000 hz (cuts 2 dB less)
All very well within the realm of the baseline EQ.
I’ve noticed in general that I like a little more warmth/mid-bass, and am also sensitive to the 4k ish region. Some headphones EQ’d to Harman OE can sound super glary to me (but not all).**** Also not as averse to upper treble as some :stuck_out_tongue:
What the heck, I’ll request
  • DMS Project Omega
  • ZMF Atrium open
