The Softears RSV is a wonderful IEM, but falls short compared to the Moondrop S8 in the areas that matter most to me. I see it as a complementary pair rather than an improvement or replacement.
My full review is available on my blog:
I use the red TCM tips of size L with a 14mm diameter, without changing anything in the inner bore. This gives me a very good seal, with which the bass is presented excellently, and the remaining frequencies are presented in a very sparkling and lively manner.
As my preferred amplifier for the 900‘s, I personally use the Audioquest Dragonfly Cobalt, whose very good sound quality is in perfect symbiosis with the Sennheiser in my opinion.
Looking for IEM brands that, in general, have longer stems/nozzles on their products. Price range from €0 to €500.
I have noticed that some IEMs just have too short of a nozzle to stay in my ears. Like a Blon BL03 is impossible to get a seal or even to get it stay in my ear for more then a few seconds.
Tin T2 plus is a struggle but with double flange tips or XL sized tips (Spinfit CP100) doable. KZ’s fit fairly good with longer L tips (Xcessor/InAirs) and frequent re-adjusting (but not too often).
On the other hand, the Blessing 2 (Dusk) is great. I don’t get a deep insertion but with L tips I get a good seal, they are comfortable and stay in for multiple hours without issue.
I don’t think it’s the diameter but the length of the nozzle that creates the problems.
Also the semi-custom designs seem to fit best.
I have a relatively large inner ear canal, which is why the much-touted comfort of the new sennheiser models can only be achieved with tips with a very large diameter.
With one of these, the IE300 is of course also worth mentioning.
When it comes to comfort and sound, the iBasso IT00 has to be mentioned in this case, which also perfectly combines both categories (even more than the Fiio FH3 in my eyes / ears)
The IE300 was on my list, but looking at the very short nozzle I’m not sure these will fit my ears in any way.
Will surely check those Reecho & Peacock Audio IEMs out.
Can’t remember where but I saw some measurements on the iBasso and read a review somewhere. Not sure if those are for me. But I’ll look them up again.
edit: Looking at the Reecho&Peacock Audio stuff, I wonder if ThieAudio wouldn’t be a good fit too.
Because the housing of the IE300 is so small, they sit “deep” in the ears. Hence the nozzle does not need to be long. Maybe still worth a try, I find them very comfortable.
They’re called “Fidelity+” MMCX connectors, which just means the socket is a bit recessed. This doesn’t appear to be a Sennheiser proprietary thing, but rather a contract/collaboration/whatever with the company that makes the connector, and its purpose is structural stability. It’s the same MMCX connector more or less, but the cable-side connector housing needs to have a long enough cuff.
I got a Linsoul MMCX cable and it didn’t fit. My solution was to rip out the L/R indicator rings on the connector housings, and now they fit! It’s not the best, but until the Fidelity+ connector gets more options it’s perfectly acceptable, and worlds better than the cable that came with the IE300s.
I haven’t seen a graph of that IEM yet. So I have no idea what it could sound like.
It looks exactly the same as my KZ DQ6, so it should fit.
My tragus is covering quite a bit of the ear canal. One of the problems with short nozzles is that the IEM gets pushed out by the pressure against the tragus.
…I’ve got funky ears…
The picture is the “Spring” version?
Are they all the same color or does the pattern differ from set tot set?
Any sound comparison to more well known IEMs?
Sounds similar to mine, my right ear is evil and with the stock tips my tragus got super painful.
After some experimentation I found that the Spinfit CP145 were almost perfect, but they pushed the IEM body out just a little too much and eventually caused pain on the anti-tragus. For the past week or so I’ve been using Sedna Earfit Light Short tips, which have a lower profile to let the body sit deep, and they’ve been wonderful. If they had silicone as soft as the Spinfits I’d probably try the next size up for a slightly harder to break seal, but they don’t, so… eh.
Point is, the IE300s can sit deep enough to not be a problem even if your ears are filled with hatred, you just need the right tips.
Yes Spring 1’s, I believe they are all hand finished so although the colours are the same each set will vary somewhat…Here’s BGGAR’s graph comparison with the OH10, the Spring have a 2/3k boost giving vocals a slightly more forward presentation than the OH10 plus the 12-14k boost gives the treble an airy/sparkly quality.
Sedna eartips are hard to find here. Apparently Asla Sedna has some high demands on their distributors.
I’ve tried Spinfit CP155 but didn’t like them too much. Comfortable but not secure enough.
The CP145 might fit my current IEMs better.
I’m waiting for some more Xcessor tips. The ones I have now are quite good on the KZ.
The Blon will never fit my ears. There’s no tip that will help. It’s the combination of the angle of the nozzle and the length that make it impossible to keep them in.
I’m considering the IE100 just to try out the shape of the new Sennheisers. I think it’s an easy re-sell (brandname and price) if they don’t work.
Funny, I was looking at the same graphs. Those databases are so helpful.
Just got done trying out the Sedna Earfit light short small and they’re almost as good as the Spinfit CP155 Medium, but they just don’t seal quite as well. I think the Spinfits are the best for me.
Also still really enjoying the Blessing 2 Dusk. They’re super comfy with the spinfits and have a sound signature that is great for longer listening sessions.
I’ll try mine with the CP155 again. From my notes I conclude that I certainly didn’t dislike them. So giving them an other try could be interesting.
Right now listening to them with the stock tips. (DSOTM)
Would be interesting to hear what you think. IEM fit and tips are probably the most personal thing about audio, so it very well couldn’t work for you, but you never know.
