iFi audio - xDSD Gryphon
I’ve seen @SebastienChiu use a small, portable, 3rd party Blutooth receiver, run it into an iDSD Diablo, and then run it into his car stereo. That was quite the workaround as well.
Hello All,
do you know if there will be soon a release of the Gryphon 2?
Not sure if is a great idea to buy current version right now
Thanks,
Ivan
iFi are always very tight lipped about new releases until they are actually announced.
I am not sure if it’s already discussed or a known issue/feature of this DAC. By mistake, I connected my 4.4 headphone on 4,4 line inputs. To my surprise, I was getting music through 4.4 mm line-in input as well :-). is it really possible??
It’s a feature :smiley:
It is both a line input and output, depending on what mode you’re in. I use the line out to feed my car stereo.
For what it’s worth, iFi routinely packs double features into one jack or switch. They also have proprietary names for various functions. As such, iFi products can be confusing to use without reading the manual.
