Hi Guys,
So iFi was kind enough to send me a Pro iDSD for a little while for review purposes. I’m not going to go into all the features as that would result in a 50 page thesis, so if you have any questions please just ask, and I will answer them to the best of my ability. The full review will dive deep into the workings of the unit.
I asked myself originally, why does this device exist, as they have the Pro iCAN, they just needed to concentrate on a solid TOTL dedicated DAC. Having used it for a couple days, I sort of get it now. However, there are a few caveats
-2.5mm Balanced out is dumb for this purpose. It should be 4.4mm. Supposedly this is in the works and will be available on future Pro iDSD’s.
-the 1,500mw power being available through the SE output is dumb, the full 4000mw that is available through the 2.5mm balanced jack should be available. If it can be done on the Micro iDSD, it should exist here.
-Thats it really.
Especially once versions are available with 4.4mm pentaconn, I can see this being the one device many could need. There isn’t really much need for anything else. IF you have hard to drive headphones sure, add a suitable amp (like the Pro iCAN) but apart from that, this pretty much does it all.
It sounds great, has all the features you could ever want, tubes, tube+, SS, headphone out, can be used as a standalone DAC in a system. It really is a very well thought through piece of gear, with the above caveats.
I answered my own question, I recall something about this being the new XLR replacement/standard…
