The general advice I’ve found online is to max out your volume (or 97%). This most closely resembles the high levels of a dedicated line out, and best preserves the content.
Cool. That makes sense.
Thank you
2 volts is the standard line in that schiit bases there performance specs upon. Don’t know what voltage is associated with your soundboard but I’d contact customer support and let them know what you’re trying to accomplish. Only reason I know this is that I was using a earstudio dac/amp for a bit as an experiment. Under no load the output could be set to 2 volts into the magni. Than I just used a 3.5 to rca into the magni. Might not be a bad dac to look into down the road. Lots of flexibility with it as it can make any amp into a LDAC bluetooth amp and then any headphone BT compatible. Their app is also bananas. Can even run 2.5 balanced out but that wouldn’t help with the magni. It’s a very versatile piece of hardware
Funny you mention that, as I previously had a BTR5 that I could’ve used. But I just ended up going with the Drop SDAC, which is performing quite well.
I think I hear a difference between the SDAC and the Hidizs Sonata that I was using at first, but haven’t done a formal A/B test.
That said, what you’re saying makes sense. I’m starting to appreciate how versatile a discrete dac/amp setup is, since the option to upgrade either one is there without getting an entirely new device.
Hi everyone,
First of all I want to mention that I’m new here. Since I can’t create a new thread, I’ve searched on the forum and this topic seemed to be the most relevant to my questions, so sorry (maybe) for replying to an almost 6 year old thread.
This paragraph is more of an introduction, so feel free to skip reading it if you don’t want to haha.
I recently moved and found my old set: a Technics SU-X933 integrated amplifier, Technics SL-PG340A CD player and two Technics SB-FW12 speakers. I know this isn’t high end, but back in my student years I absolutely loved it. I used to also have a Sennheiser HD598 (which I unfortunately don’t have anymore) and if I played CD’s and plugged them into the amplifier, that gave me a sound quality I hadn’t heard before in my life. In the more recent years I’ve mainly used a soundbar in the house (since it’s more convenient and easier to set up) and several lower quality headphones (currently a Sony INZONE H3 MDR-G300NW, that has a small USB YY2967 DAC included - for gaming on my PS5 and listening to youtube videos it’s more than enough for me), but finding my old set makes me want to dabble in the audiophile zone again, at least when it comes to listening to music.
Now, for my actual question: the amp (Technics SU-X933) is oldschool and doesn’t have an integrated DAC from what I could find. My phone (a Nokia XR20) has a 3.5 jack plug, but also doesn’t seem to have a DAC. Based on theoretic information that I found - and this is also why I came here, since google seems to be getting worse and worse, and the gemini answers can often not be trusted - connecting this digital source to my analog amp with a RCA to jack cable, shouldn’t work without putting a DAC between them, but it does. I do still have a bit of a library of 320kb/s mp3’s on my phone, so that’s what I would use it for. I know that for streaming it would probably not be worth the hassle. Would adding a separate DAC between them make a big difference, or is the system (including the Technics SB-FW12 speakers) too old and entry level to be worth it?
I’m thinking to buy some better headphones in the near future and I think that for playing CD’s my system would still be more then fine (for me at least), but I’m curious how it would sound if I played the music from my phone through the amp and if the DAC would start making a difference then.
Or should I just enjoy what I have and expand my CD collection after I get the good headphones, instead of using my phone? And maybe in the more distant future, buy a new set of gear?
Thanks for taking your time to read this and responding!
Welcome to the forum!
When a piece of gear has a digital input and an analog output - two rca connectors or a headphone jack - the unit has a dac inside, even if it’s not specifically mentioned.
So your cd player and phone have a dac inside which is why everything works.
From what I can tell the cd player does not have a digital output so there is no place you could attach a dac, since the dac needs a digital input.
It looks like your phone has a usb connection which could be connected to a dac, which could then connect to your amp. You would then be using the external dac instead of the dac that is already built into the phone. But this would not apply to playing cd’s since your cd player does not have a digital output.
It sounds to me like sticking with your current gear and putting the money into good headphones makes sense. Then you could buy new gear when time/money/motivation comes along.
Thanks a ton! This is exactly why I came here. I didn’t trust what I found, as it didn’t seem to make sense, and it turns out it was indeed just an AI hallucination.
For now, I will stick with what I have and start looking at headphones. I’m sure I’ll find a lot to read about those on this forum, and maybe I’ll ask a question or two when I get closer to pulling the trigger on a pair. If after that, I find the speakers to be lacking in comparison, maybe I’ll look for a new pair of those, but that’s a concern for another time.
For my phone I was thinking of one of those cheap dongle type DAC’s, but since my phone is starting to get old, I’m probably going to wait with that one as well. Maybe when I’ll change it, I’ll look towards something that has better sound output, like a Sony Xperia. But this is also for later.
I’ve also dug some more regarding my current amp and cd player, and they might not be as bad as I thought. After all, if I’ll like the way they sound, that’s all that matters.
Cheers!
