Yes. I apologize for any confusion on that.
My comment re the reduction in bits was mostly related to changes in volume. When you lower volume in the digital domain using either a software-based volume control, or preamp/pregain filter in a digital EQ (like EAPO), you are effectively reducing both dynamic range and also the number of bits that are available for rendering/playing back your audio content. For every -6 dBs of decrease in volume, you effectively lose or waste about 1 bit’s worth of resolution in your audio rendering. That doesn’t sound like much, but I’ll give you a couple real world examples where it could potentially be a problem.
There is a prevailing myth among audiophiles that 16 bits, 44.1 kHz is the most you really need for good sounding audio. And if you are using content encoded at that resolution, it’s best to keep it at that native depth and rate until it’s converted to an analog audio signal (in a DAC). As long as you’re not changing or playing around with the volume or EQ before it’s converted to an analog signal, then you’re probably on fairly safe ground with those assumptions.
If you are following the “native depth/rate” assumption though, and reducing the volume or gain of your 16/44.1 audio content on a digital device (such as a PC) that is also set to render/playback the audio at 16/44.1, then you’ll lose about half of the potential resolution of your audio content if you reduce the volume by -6 dB (or 1 bit). Here’s why… 16 bit audio has about 65,536 possible levels of amplitude for each sample. If you reduce that by only 1 bit, to 15 bits, the number of possible levels for each sample is effectively cut in half to only 32,768. Drop the volume by another -6 dB, and you’ve cut the number of possible amplitude levels for each sample to 1/4 of the original content, or 16,384 levels.
Let’s look at a potentially even more problematic scenario than this. One that is also from my own personal experience.
When I first started using digital EQ’s, I was largely unaware of the audio settings for bit depth and sample rate on my PC, and the potential impact they might have on the sound quality of the digital content I was streaming from the web. This was the primary source for most of my music listening btw. And by default, the audio device settings on my PC were set to 16/44.1, which was normally just fine for CD’s, MP3’s, and some other audio streaming services back then… provided you were not using them with a digital EQ or software-based volume control, as described above.
That’s not what I was listening to though. I got most of my audio content from streamed YouTube video clips, which are encoded at the standard bit depth and sample rate of digital video, which is 24 bits, 48 kHz for the audio layer. So my PC was essentially downconverting everything I was listening to to 16/44.1. And then I was further exacerbating that down conversion by reducing the volume in a software EQ.
24-bit audio has about 16.7 million possible amplitude levels for each sample. Many of those levels are probably out of my normal hearing range, because the dynamic range of 24-bit audio is around 144 dB (24 bits x 6 dBs). And I never listen to audio at dB SPL levels that loud. I wasn’t just cutting the potential resolution in half though in this case. If I reduced the volume on my PC by -6 dB, I was cutting the number of possible levels for each 24-bit sample by 1/500th! And the audio settings on my PC were also reducing the sample rate from 48 to 44.1 kHz.
I didn’t learn how to rectify that from the folks on Head-Fi, because the prevailing wisdom by most folks there was that 16/44.1 was enough. And it was best to keep things at that rate until D/A conversion. And I’m afraid that there are probably still many audiophiles that continue to cling to this belief.
The highest the current audio device settings on my PC can go are 24/48. And switching to that rate made a subtle, but noticeable (imho) improvement in the sound quality. And it was such a simple thing to do. I’ve noticed though that whenever my software is updated or reinstalled, the audio settings on my PC will sometimes revert back to 16/44.1 automatically. So I continue to check that setting whenever there are new updates on my system.
Not all YouTube content is encoded and streamed at the standard video rate of 24/48 btw. But that is the recommended encoding format for best sound quality. YouTube content usually streams at a variable bitrate though (VBR). So the streamed bit depth varies, and can be less than 24 bits.
