A loss of what? Dynamic range? Bits? Quality, as in an audible negative impact on sound quality?
Here’s Chat GPT’s input (I’m not saying Chat GPT is 100% accurate on this):
- Inside the Digital Domain
If you’re working with integer PCM audio (e.g., 16-bit or 24-bit WAV):
• Turning volume down is just multiplying each sample by a factor less than 1.
• This reduces the maximum amplitude but also reduces the signal-to-quantization-noise ratio (SNR) because the same quantization noise floor is now closer to your audio.
• In 16-bit audio, this is rarely audible unless you lower the gain drastically (e.g., -40 dB or more) and then re-amplify later.
• In 24-bit audio, the noise floor is so low that even large reductions won’t matter in practice.
If you’re in floating-point (e.g., 32-bit float inside a DAW):
• Volume changes are mathematically lossless until you export to integer format.
• You can turn gain up/down repeatedly without losing quality — rounding only happens when converting to fixed bit depth for playback/export.
- On Playback Devices
If you adjust digital volume in software before sending it to a DAC (digital-to-analog converter):
• You’re lowering the amplitude before conversion, so the DAC uses fewer bits effectively.
• Good modern DACs with 24-bit depth have more than enough dynamic range to handle this without audible degradation, unless you’re pushing volume extremely low (e.g., background whisper levels).
If you adjust analog volume after the DAC:
• The digital signal stays at full resolution; no digital quality loss occurs.
• However, analog circuits introduce their own noise and distortion, so the quality depends on the amplifier design.
- When Problems Happen
You can cause quality issues if:
• You reduce gain in a low-bit-depth format (like 8-bit audio) — noise becomes obvious fast.
• You lower gain a lot in 16-bit audio and then boost it again later — the quantization noise floor gets amplified.
• You’re working in a poorly implemented playback pipeline where digital scaling adds rounding errors.
Rule of thumb:
• In a professional workflow (24-bit or 32-bit float), you can digitally reduce gain without worrying about degradation.
• In 16-bit, moderate reductions (e.g., a few dB) are fine, but big reductions followed by re-amplification can expose noise.
• If you’re only lowering volume for playback and not re-amplifying later, you won’t hear a loss in quality with any modern setup.
