Hi guys
I’m new to DIY and modding and I have a question regarding changing stock ZMF cable (similar to Audeze) from 6.3 TRS to 4pin XLR termination. Mine came with 1/4" stock and I’ve bought a Neutrik 4pin XLR
What he said. After you have completed making the cable you will need to test it first anyways. So, get a cheap multimeter from Amazon. Search for multimeter and then price less than $10. Then purchase one with red and black leads that uses the battery type you want.
For example here is one for $8.39 https://www.amazon.com/ProTechTrader-Large-Screen-Digital-Multimeter/dp/B07FN8XN13/
There are even $5 meters with analog needle if that is your thing.
