Problem with Meze balanced cable Denon AH-D5200
Hi
I just bought the Meze 99 upgrade balanced 2.5mm cable to replace my standard cable. I want a shorter cable as well as the possibility to connect to a balanced amp at some point.
To connect with my DF Cobalt 3.5mm input I got a 2.5mm - 3.5mm stereo adapter. I know I will not get the balanced sound.
Unfortunately there is only sound in one side of my headphones. Have I done something wrong?
Thanks for a great forum!
I would check to see if the problem exists in the adapter by plugging it in to another source, like the headphone output on your computer/laptop or phone.
If you have a multimeter, you can just test the continuity on the cable itself.
