Here is the right spot.
I suppose that depends on how “high-end” is defined. And I don’t really find the notion of “tiers” based on price to be terribly useful nor at all accurate.
For example, I feel the HPA-1 is somewhat overpriced for what it is. I think some of that is down to the front-panel/volume knob and the name. Not that it isn’t an excellent amplifier; it is, but I’ve heard units I thought bettered it technically and/or were more enjoyable for much less.
This, of course, is subject to personal preferences and biases.
The HPA-1 may be a better unit, technically, for a primary diet of regular headphones simply on the basis of its lower output impedance and higher power output. It’s a more neutral sounding piece. Where the HSA-1b has some color to it and more explosive dynamics.
I really like the Utopia from the HSA-1b. More so than I did from the HPA-1, though not as much as from various tube amps. That’s part synergy and part personal preference. If we were talking about, say, the Meze Empyrean, or an HE1000SE, I might lean towards the HPA-1.
It’s not clear to me if you’re running the HPA-1 as a pre-amp into the Jotunheim R, or are feeding both amplifiers directly from the dual outputs on your DAC. If it was me, I’d do the latter; I think the HPA-1 as a pre is not going to do what I’d want in combination with the Jotunheim R, especially compared to the HSA-1b.
But if you really want the BEST out of the SR1a, you’re back to using the interface box and MUCH more expensive speaker amplification.
As to the $4,500 price tag … you have to look at the overall functionality of a unit, and how much of that you’ll use, as well as qualitative factors and intangibles (e.g. how much single-box convenience is worth vs. cost or performance, aesthetics, form-factor) when considering price vs. value.
I can’t make those calls for someone else.
It was more than worth it to me to get close enough to my favorite solid-state amplifier (I’ve heard most of them at this point) that I wasn’t going to miss it with my collection of regular cans and was markedly preferable with the SR1a. Thus I shed a box and got a more compelling overall result into the bargain.
If you didn’t have the HPA-1 and Jotunheim R already, I’d say go for the HSA-1b. As is, you’re better off doing the home-trial with the HSA-1b and seeing what you think for yourself.
