Schiit Audio’s “Jotunheim R” is a unique, modular, amplifier designed specifically to drive the RAAL-requisite SR1a - itself a unique, ribbon-driver, “EarField™” monitor/headphone.
Those that are aware of the SR1a are no doubt also aware that, to date, the SR1a require the use of a proper speaker/power amplifier (100w into 8 Ω/150w into 4 Ω) and a dedicated interface box to drive (lots more detail is already available here on the main SR1a thread).
The “Jotunheim R” is a direct-drive amplifier for the SR1a.
Direct-drive means that the SR1a “Amp/Ribbon Interface” box is NOT required here. Nor is a speaker amplifier. You plug the SR1a straight into the Jotunheim R, connect a source to one of it’s inputs (or use the optional built-in source, be it phono or one of two DAC options) and off you go:
This has the potential to open up access to the SR1a to a much broader audience, and make them much easier to integrate into existing systems.
When this thread was originally created, Jotunheim R was not yet shipping, but that has now changed (as of 01/21/20)!
So the first part of this thread deals with the pre-production (production-qualifier) unit, and coverage of the production/release version starts here.
Original Production-Qualifier Disclaimers
I should note, here, that this is not a shipping product quite yet, but interest is high enough, and Schiit & Jason have been open enough about the project, that coverage here makes sense.
In that vein:
NOTE: The unit here is what is referred to as a “production qualifier” (the last stage in R&D before a product is sent to formal production). What that means is that this unit is fully “production intent”; it is using all the same design, parts, spec, and suppliers/manufacturers as the production units will. And, unless issues or problems are found with these units, the next step is simply “Build more, just like these.”:
(Note the “Production Qualifier” label next to the IEC socket).
If changes do occur between now and release, they’ll be identified specifically. The changeover point will also be clearly indicated (and linked) in this thread. Until then, any commentary is based on this “production qualifier” unit.
And with those caveats out of the way, this is the spot to discuss this unique device …
*This is a provisional thread, based on “production qualifier” hardware (defined above), and will lose its “provisional” designation when final product is shipping. This will be clearly noted in the thread, so it is easy to determine where commentary shifts from “production qualifier” to “shipping retail product”.
