Recommendations for replacement AirPods Max ear cushions & replacement AirPods Pro 3 ear tips?
Do you have any recommendations for replacement AirPods Max ear cushions & replacement AirPods Pro 3 ear tips?
I don’t own the AirPods Max, but for the AirPods Pro 3 I had to replace the stock tips because none of the sizes stayed seated in my ears. I went with the Azla SednaEarfit Max. They are a huge upgrade to the terrible stock tips, as now the seal doesn’t break and the earphones stay in place during workouts.
