Repair question
I’m looking for advice on where I can send the stock cable for my Focal Utopias to be mended. I managed to screw up one of the connectors so that I’m getting no sound in one side. I suspect a wire came loose. Just wondering if there’s a homebrew cable guy in the forum who might be able to do what I assume is an easy fix for under $50. I use a 3rd party cable anyway because the stock is too damn long at 10 feet, or whatever it is, but it does come in handy if I move to the living room and want to sit on the sofa. ANyway, just thought I’d ask …
You might reach out to Val at Arctic Cables. I’m sure he’d repair your cables for a fee.
Great, thanks — I’ll drop a line.
