Resolve's Headphone Ranking List
Bear in mind, many different paradigms of speaker design can yield “a flat response (measured under specific conditions)”. The Olive and Toole research on speakers showed that speakers with flatter ('“constant”) directivity were preferred to those without, but Olive’s separate work on preferred in-room loudspeaker response implies that the inherently omni-at-low-frequencies behavior of conventional “monopole” speakers is prerequisite for a flat-on-axis-in-an-anechoic-chamber speaker to be preferred. An axially flat dipole or omnipole would be heard to be quite bright.
Also, note this line from that blog post:
Listeners Prefer Headphones With An Accurate, Neutral Spectral Balance
When the listening test results were statistically analyzed, the main effect on the preference rating was due to the different headphones ( slide 15 ). The preferred headphone models were perceived as having the most neutral, even spectral balance ( slide 19 ) with the less preferred models having too much or too little energy in the bass, midrange or treble regions.
Olive’s research shows that there are strong trends to what people tend to like, in terms of frequency response, and that a preferred frequency response is typically heard as “neutral”.
Edit:
No, it’s both listener preference and breaking the circle of confusion, because the two are corelated goals. Consider his appeal in this older blog on the topic for a standard for rooms and speakers - the Harman target represents such a standard for headphones. If “good” headphones may be presumed to perform roughly within the Harman bounds, which in turn aligns with how “good” speakers in “normal” rooms are heard, then we have a target for subsequent recordings which also matches what people prefer with current recordings, which is about the best balance you’ll find on the circle of confusion.
Listener preference? Its like Marilyn Monroe was the ideal in 1960 and Twiggy in 1970. I don’t want either preference to color my sound. These days and for at least 25 years bass is the rage. So sure you get more visceral impact by dropping a +6 db at 100 Hz and down change to the EQ. What about fat midbass so its harder to hear bass guitar and drums clearly? Or male voices getting chestier. Or violas and cellos sounding wrong? I don’t want this shifting with the tides FASHION to get in the way of the absolute truth. All of those Harmon types do it. Let the listener decide what if any “special sauce” they want. Or produce two charts - one altered in the modern fashion and one for the truth.
As wrong headed is the average room trope. Nobody has that room. I spent lots of time and money refining my various rooms until my efforts got me into doing redesign and new room design for others. In an effort to remove/negate negative audible features in rooms in service of the music. Why would I want my headphones to sound like a 11x14 room with suspended wooden floors and overly reflective surfaces? It’s rubbish. Tip: you want centerfill and imaging from your speakers - get rid of the totemic stack of equipment you have between them - and take off your glasses and close your eyes - than compare. Your ego doesn’t need to be stroked by looking at your equipment and pretty rack or cabinet.
As for just spinning 1 or 2 of 4 knobs to improve sound? OK, your choice. But if you want your cans to sound their best - consider that there is unit to unit variation, and of course the nonsense added by say crinicle to get past. Then you can get down to it. It can takes 20+ cuts of different well recorded music to use your ears to fine tune the settings of ones digital paramtric EQ. Fixed frequencies will never work at this level of detail - nor I assure you will you ever get as close to correct if you just flick a couple of Loki knobs to a slice of one song.
This is a common mischaracterization of the Harman research, and I think in some ways this was bound to happen as a result of the piecemeal publication model - they’ve only got themselves to blame on that one I think. I’d encourage you to read through the research, but I too at one point approached it with this same kind of “why should we care what the unwashed masses like” notion. Turns out it’s actually a lot more sophisticated than that, even though there are also places to scrutinize.
A precursor to this would probably be to watch the video I did recently on the various stages of reading headphone measurements, for a bit of context as to the landscape for this discussion.
The Harman target we commonly use is based on the summing of free field and diffuse field head-related transfer functions (HRTFs) on a head and torso simulator, using the anthropometric pinna (GRAS KEMAR). This is why you see the rise up to 3khz and then it comes back down towards 10khz. These results will be unique to every human and every ear, but using a head and torso simulator they were able to get a simulated result.
Now it’s not incorrect to say that the bass to treble tilt is based on listener preference, and this is where two of the studies were influential - the 2018 one included the ‘untrained listeners’ group, which also resulted in more bass overall (although it was only by a small amount). I don’t include this bass shelf in the target I use because I tend to think perhaps a bit highly of those interested in high end audio. But also, given that a lot of us are interested in open-back headphones, I don’t think it’s realistic to expect open-back acoustic designs to be able to achieve this.
But in any case, what’s interesting about the preference tilt, is that there’s a lot that goes into the specific places where the adjustments were made. That is to say, this result for where the bass shelf is didn’t occur at random - or where people’s preferences happened to fall. They specifically targeted the bottom part of the ear gain for where the rise up to 100hz shows up. Or in other words, they put the adjustment there for good reason. This is also generally where the crossover for subwoofers would ideally be.
Now, as far as the level of the preference adjustment goes… all of this actually agrees with the generally more well-understood results for ‘good sound’ in speakers, which also has decades of research behind it. This is where any individual looking at this stuff has to recognize that this is a ‘reference’ curve for a reason. There is a cluster analysis that’s done in one of the papers:
Segmentation of Listeners Based on Their Preferred Headphone Sound Quality Profiles
This obviously means that it’s up to us to recognize that just because the majority prefer certain bass levels and bass to treble balance, that doesn’t mean we individually do.
The mistake that often gets made here is that the reference curve we end up using (the largest grouping), gets treated as prescriptive rather than descriptive. It’s not saying what you SHOULD like, merely what people DO like. It’s up to the manufacturers to decide what to do with that information.
So any analysis of a headphone’s frequency response in relation to this target should be thought of as “in relation to what most people happen to like”, not necessarily how all headphones should be tuned. Now, this is also where my own misgivings come into play. I think the other reason why that statement is correct (beyond just the question of bass and treble balance), is that the target isn’t fine-grained enough for us to know what the frequency response should be above 5khz, given the human ear and its effects. But for a general target, it’s still quite useful.
I think there’s an argument there for manufacturers to aim for the largest group if they want to sell lots of headphones, but beyond that, this says nothing about what you individually like, it’s just a reference point.
Very complete answer. Thanks for that. Now I have to read up. I do add 1.5-2.5 db under 40 Hz for my open backs with no rear screening, but some of the recommended shelves at 100 Hz muddy up the sound to an uncomfortable/unmusical degree to me at least. I guess all those years at the BSO as a child and my fathers Quad ESL’s stick with me. But I did own a the ML CLSIIz with Griadient woofers and the Verity Parsifal II which were hardly bass shy.
But my main concern is weening my youngest son from cheap AT cans to the HE-6SE v1.
Lucky boy! You want to adopt an older son? :innocent:
That’s admirable haha.
I’m watching @resolve Andrew’s video right now and I thought to myself, “I’ll just make him a visualized pleasure” :stuck_out_tongue_winking_eye::rofl::rofl:
You’re missing @Resolve 's favourite headphones, the DT1990 :smile:
The 1990s are too much, even for me :exploding_head: (maybe the Tesla Driver :man_shrugging:)
I was able to tame the 990s quite well:
Wow, Beyer should pay you for your loyalty to its products! :slight_smile:
and Sennheiser:
or Grado:
maybe Koss:
or should i call Camppfire:
……………etc.
When I think about it seriously :thinking: :
Man, could I make a bunch of money…..
One could make good $ just selling your name to hp manufacturers. Thats quite the collection.
Taming the 1990s
I love iFi, do you have the Zen Dac and Zen Can there? What do you think and should I get the V2 or the signature set?
:laughing: :+1:
If you want the option of using an integrated headphone amp, the V2 is the solution, if you only need the DAC, the Signature is a little more nuanced.
Updated the list with these two:
Ovidius tx-901
RODE NTH-100
I have been extremely impressed with these. Excellent headphones for the price. Definitely punch up in my opinion. So far they seem to be a great pairing with the mojo 2 as well. A nice portable setup for around the house or office when I can’t be at my main chain. A solid recommendation.
I think I may need to make some EQ adjustments. With the stock tuning, the midrange sounds muffled to me.
What are you using them on? And what are you coming from (other headphones/iems)? I wouldn’t say these are muffled at all.
TOTL IEMs and a Focal Clear. I don’t think I’m holding it to those standards though, since it’s a closed-back—I’ve gotten the Radiance to sound better, to my ears, with a little EQ (I think I boosted the midrange and treble, but frustratingly, don’t remember the specific ranges).
I haven’t invested much in sources and primarily use the Apple dongle and the Qudelix 5k.
