Howdy, DocStefan, if you (or anyone else) have any of the following or other similar open-back headphones, I’d be curious to know how you think the HD550 stacks up with them for comfort and sound quality…
Audeze MM-100
AudioTechnica R70X or R70XA
Beyerdynamic DT900 Pro X
Beyerdynamic DT990 Pro
Drop+Sennheiser HD6XX
Fiio FT1 Pro
Focal Hadenys
HFM 2020 Sundara
HFM Edition XS
Sennheiser HD490 Pro
Sennheiser HD600
Snnheiser HD650
Sony MDR-MV1
Any other impressions of the 550 would also be appreciated.
Hello ADU, I do not have any headphone from your list, I can only compare it to my Hifiman Ananda OG and Sennheiser HD560S. But up to now I only compared the HD550 to HD560S, a comparison to my Ananda will follow later.
After a long weekend of listening with the HD550 I can state the following:
The HD550 sounds full and rich, with a lot of body and rumble, has enough bass (at least) for me, with very natural sounding voices, details and separation is also very pleasing, there are details in the music I can here directly with the HD550 whereas with the HD560S I have to focus on.
In all aspects the HD550 is the better headphone compared to the HD560S, the one thing I complained earlier (“S” and “T” are more pronounced) do not bother me anymore, maybe because I’ve gotten used to it or because the other aspects are just so amazingly better.
Appreciate the additional thoughts. Comparison to the Ananda would be great too. Thanks for weighing in on this, and giving us your impressions of the 550.
These are amazing headphones for their price. I have heard better, but you’d have to spend 3X the price. These greatly accelerate the concept of diminishing returns. I love them!
Any recommendations on a some small EQ tweaks would be great. Don’t want to change the many things this headphone does well, just a little minor shaping of some of the minor flaws in the treble and a touch more bass. Been playing around on Listener’s squiglink with the preference tilt, but not sure i’m doing it right without altering the things this headphone does very well.
I don’t own the HD 550. So bear that in mind. Based on the available graphs though, there are a couple minor bright spots that could probably come down a couple dBs at around 1.25 and 9 kHz. Bass really begins to sag at around 50-60 Hz. So you could try lifting that area a few dB.
Looks like there may be a little brightness in the 5-6 kHz area as well.
I am curious how pad wear changes the sound of the HD 500 series headphones. I know it makes the HD 600 series headphones warmer and darker, but will the same happen to this headphone?
Based on Resolve’s measurements the treble is reduced relative to the bass and lower mids as the pads wear in on the 6 series headphones. So the headphones start to sound less bright, and warmer.
That’s not unusual at all btw. As pads become worn in and compressed, and your ears get closer to the drivers, the treble tends to be reduced in favor of the lower frequencies on many headphones. Whether the HD550 will follow this same pattern though, I can’t really say.
I now have the HD560S and HD550 here, to give them both a listen btw. And tryin to decide whether to get the HD6XX and a couple other headphones, like the FiiO FT1 Pro, for comparison to these as well. Both of the Senns were brand new in the box, and the HD560S was $140US+tax, and HD550 was $200+tax. So the price differential is about $60. Those seemed like reasonable enough prices to warrant giving both a try to me.
I believe it is possible that the HD560S was revised after 2022, as a DIY Audio Heaven article has suggested btw. Because it sounds warmer and less sibilant than the original measurements would have led me to believe. That is one of the reasons I decided to give it a try, along with the noticeably reduced pricetag.
Cosmetically, these two headphones seem pretty similar. The main difference is that the HD550 lacks the cloth “dust covers” on the drivers inside the cups. And it has a pleather pad on the headband with no divot. And there’s supposedly a bit less clamp. The HD560S feels a bit more plush though due to its cloth headband pad, and cloth covers in the cups.
The velour pads on these Sennheiser 5 series headphones are also not as comfortable as the more plush velour pads on my Beyer DT770.
The amp I’m currently using is a solid state ~1 ohm Bellari HA543. I’m also considering getting a JDS Labs amp and DAC. The Bellari has plenty of juice to easily drive both headphones though.
You’re right. I don’t have Resolve’s measurements in front of me but in checking others at squiglink I see a bit of sub-bass roll-off, but it’s more pronounced above 3k.
I’ve not tried the 550, but I have the 560. Measurements show a little peak at about 4k, the kind of thing I might find annoying. I don’t hear that, though I have the ZMF pads on it, which are nice. Recommended.
Still listening and experimenting with both headphones. I seem to be leaning more toward the post-2022 HD560S though, both in terms of fit/comfort, and also sound quality and FR out of the box. YMMV of course.
I’m not liking the brighter tuning in the treble on the HD550 though, or the pleather headband pad without the divot as much. And don’t feel much difference in the clamp. The HD560S also seems to stay put on my head better where I want it.
Both headphones need a little more sub-bass, and a few tweaks to smooth out the mids and treble a bit. But so far, the HD560S seems to be more pleasant to listen to without EQ.
I also like the jet black colorway of the HD560S better. It really doesn’t seem like such a bad little headphone. Especially if you can pick it up when it’s on the cheaper side.
